Question about Acer Computers & Internet
Laptop randomly shuts off
I have an Acer Aspire 3650 and for some reason I don't understand it doesn't charge the battery, it will turn off if you move it slightly (the battery won't charge so it's only on ac power), and if I watch a video on my computer (file) or something on the internet (like Hulu) it will turn off after a while. This is very frustrating because it keeps turning off without shutting down, and once one of the system files got corrupted and I had to reinstall my Windows XP installation. Can someone please tell me why this is happening and what I can do to fix it?
  • navokraer Oct 02, 2009
    Well, I forgot to mention that I did buy a replacement battery thinking that my old battery was just bad. Now, when I got the new battery it did have power. The computer would still stop using the A/C power from the cord, but when the computer would go off A/C power the battery would work. However, since the computer won't charge the battery, it just died over time. If I had an external battery charger ($78 bucks!) it wouldn't be that big of an issue. I don't know whether it's worth fixing or to just to buy a new computer.
  • 448 Answers
Since, the Battery is not inserted in the Computer and it turns off automatically even with a slight movement when running on the AC Adaptor, it shows that the issue is with the DC-in jack on the Computer.
Now, to ensure if the issue is with the DC-in jack or internal power circuitry, it's required to diagnose the Computer after running it on the Battery power.
Remove the Battery pack from the Computer and clean the metal contacts on the battery and the compartment then, reinsert the Battery and check if it's charging. If not, try using a replacement battery.
If the Computer keeps turning off even if running on the battery power then the issue is with internal power circuitry.
Bye and take care.
Posted on Oct 01, 2009
I used it the night before it was fine i plugged in the charge and it wont turn on at all
laptop charger for acer aspire 3600 3680 series 3650 3610
www.amazon.com/LAPTOP-CHARGER-ACER-ASPI...
Amazon.com, Inc.Amazon.com: LAPTOP CHARGER FOR ACER ASPIRE 3600 3680 SERIES 3650 ...When I was looking for a charger cable for my laptop, i was not sure whether I ... it was really good and worked, it heats up a little bit but for now its working ...
When your acer aspire 5738 z laptop adapter is not working ...
docslide.us > Business
Aug 18, 2015 - When Your Acer Aspire 5738Z Laptop Adapter is Not WorkingA ...Quicker Charging of Laptop Battery with an Acer Aspire 3600 AC Adapter ...
batteries-store.pblogs.gr/.../when-your-acer-aspire-5738z-laptop-adapter-...
Jan 14, 2016 | Acer Aspire 3600 Laptop Charger...
Acer Aspire 4830T battery behaving vaguely.
Are you using the provided charger, or are you using an after market "Universal" charger?
If you're using a universal charger, it could be charging the battery too hot and the computer just doesn't understand why the battery is putting out more than the system is expecting.
It could also be that the battery is wrong type. The voltage may be the correct, however the Ah may be too high. This being the case, the computer doesn't understand what why the it's getting a higher Ah reading than it's expecting. The system can not reason that that if it detects more amp-hours than the it should have that it has that much more charge time. It just sees "ERROR" and since you're dealing with a system function that is designed to prevent loss of data the default action is to shut down to prevent loss of data.
You may be able to fix by resetting the Power Management Options. Unfortunately, with out doing test on the machine, it is impossible to tell. I could be software or hardware. If nothing else works, try replacing the battery again.
Oct 11, 2014 | Acer Aspire Timeline X 4830T 14 Inch...
My laptop is not getting enough power?
that is always an issue bout the battery of the laptops of ACER....any kind of acer...you should buy a new battery....and when you buy a new one...make sure that you don't use when you're charging it...cause that is the number 1 reason why the battery is not charging... :p
Dec 01, 2011 | Acer Aspire 1360 Notebook
BATTERY DOESN'T CHARGE ON MY ACER ASPIRE ONE MOD#KAV60
Sounds like the battery might be bad. Try another battery in the laptop and see if it charges. If it does then you know the other battery is bad.
If you try another known working battery and it still wont charge, then try another AC Adapter. If you still cant get the laptop battery to charge then at that point the motherboard is bad because you will have tried another working batter and another working ac adapter.
May 15, 2011 | Acer Aspire One Netbook 8.9" Notebook
Acer Aspire 5742, Completely Shuts off, error free, randomly.
If your computer is shutting off randomly, there could be a multitude of issues. Most of the issues are hardware related.
1. If you're able to use your computer for a little while, and it randomly shuts off, it could be one of a few things.
a. Overheating processor: You may need to replace your processor, or clean out the inside of the computer.
b. Fans not working: Your fans could be disabled, and keeping the computer from receiving cooling which can overheat the processor as well as other vital components.
c. Dying battery: The battery in your laptop may be going bad, and could need replacement. Does it charge completely, or does it only fill up partially after a long period of charging? If it's the latter, you will need to replace it.
d. Dying hard drive: While this one isn't as likely, and usually doesn't cause the computer to shut off instantly, it's still something to consider.
2: If your computer shuts off before the desktop even loads, it's most likely a hardware problem.
a. Dying battery: Again, your battery may be dying, try removing it and keeping the laptop plugged in when you turn it on.
b. Broken hard drive: Your hard drive may be broken, try finding an external hard drive with Linux or another operating system installed on it, and go into the BIOS when your computer first starts up. Find the "Boot devices" option, and tell it to make the primary boot device the external device with the operating system installed on it. If the computer starts up fine after that, you may need to re-install your old operating system, or replace your hard drive.
May 04, 2011 | Computers & Internet
My acer aspire 1690 suddenly shuts down randomly. is not an overheating problem I'm sure. I have also been checked by a technician but can not find the solution
Hello, the major reason of laptop randomly shutdown is Overheating, you said it is not over heating...
I will suggest you couple of things that you can try:
1) remove the battery and plug the laptop on direct power supply, then place the laptop on a flat and hard surface and then boot the laptop.
or do a complete virusscan of the laptop.
or reinstall the OS...
Apr 15, 2010 | Acer Aspire 1690 Notebook
My laptop is always crashing
are you getting blue screen are does it shut off
Mar 29, 2009 | Acer Aspire 5630 Notebook
My labtop is an acer aspire 3680 and it randomly turns off
the problem could be your battery... how long do you have the laptop? try to plug out the battery.... and then plug it back, and see if its charging. the other problem could be the charger, or the voltage of your house. have you tried to charge the laptop somewhere else? i think, and i 90% shure that is the battery. if is that, you have to change it for a new one.... plz excuse my bad english.... i'll wait your comments.... bye!
Mar 23, 2009 | Acer Aspire 3680 Laptop
Battery
Nothing to worry about mostly all the laptops do this,
Sep 10, 2008 | Acer Aspire 3680 Laptop
Acer Aspire 9300-3655: Shuts Downs When Idle
does it just shut down randomly? and then when you turn it back on it shuts down nearly straight away? if so then it sounds like the processor is overheating and as a saftey mechanism it shuts down. which could be a big problem.
or you just need a new battery. because you are supposed to only charge it when it is dead. if you keep it on charge and plug it into the mains randomly,then the battery will eventually lose it capacitence (basically how much charge it can hold) and then it wont last long atall. you want to hope its the battery.
hope this helps.
Aug 20, 2008 | Acer Aspire 5500 5570-2609 Laptop
Computers & Internet Logo
335 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
