Question about Dell Photo 964 All-In-One InkJet Printer
Scanner not working ... can't figure out why... need to scan my paycheck to deposit to bank but says scanner not connected (but it is) or not turned on (but it is) ... printer works fine, but scanner does not ... help!
    Sniper:
  • 51 Answers
You can try these steps:
1.Check if the firewall is blocking any printer services 2.Check what port the printer is using (reenable the bi-directional support) and if it's on online mode 3.Disable all the firewalls 4.Uninstall the printer driver and software 5.Delete any items under the ff keys: HKLM\System\CurrentControlSet\Control\Print\Environments\Windows NT x86\Drivers\Version-2 HKLM\System\CurrentControlSet\Control\Print\Environments\Windows NT x86\Drivers\Version-3 HKLM\System\CurrentControlSet001\Control\Print\Environments\Windows NT x86\Drivers\Version-2 HKLM\System\CurrentControlSet001\Control\Print\Environments\Windows NT x86\Drivers\Version-3 Optional*** 6.Delete any non default items under the ff keys: Note: ONLY THE NON DEFAULT ITEMS SHOULD BE DELETED HKLM\System\CurrentControlSet\Control\Print\Monitors HKLM\System\CurrentControlSet001\Control\Print\Monitors Default items are as follows: AppleTalk Printing Devices BJ Language Monitor Local Port PJL Language Monitor Standard TCP/IP Port USB Monitor Windows NT FAx Monitor ***** 7.Delete any items under the ff keys: HKLM\System\CurrentControlSet\Control\Print\Printers HKLM\System\CurrentControlSet001\Control\Print\Printers 8.Completely remove drivers by doing the ff: (Option for comm failure because of the upgrade from xp to vista) Ensure there are no documents in queue. Disconnect printer’s USB cable. Click the Start pearl, then click All programs, Printers, Dell xxx (where “xxx” is the printer model number) and then Uninstall. Complete the uninstall utility. From the start search box type spool and press . The spool folder located at c:\windows\system32\spool opens. Rename c:\windows\system32\spool\drivers\w32X86 to c:\windows\system32\spool\drivers\backup. Rename c:\windows\system32\spool\prtprocs\W32X86 to c:\windows\system32\spool\prtprocs\backup. 9.Restart the computer. 10.Check th services status Start-Run- Type Services.msc and Click on Open You will see long list of services You need to make sure following 4 Services are set to Automatically start Remote Procedure Call RPC Remote Procedure Call RPC Locater LexBce Server Print Spooler 11.Reinstall the latest printer driver
have a great day. :)
Posted on Oct 01, 2009
I accidentally locked out a "grp" and need to get back into it
Not sure if yours works the same as mine, but simply pressing the number button of the bank you've switched off will put it back into the scan again. So if you a dash or "*" instead of say bank #6, simply press the '6' button while it's scanning and it will be back in the scan. At least that's how my old one worked. Let me know if it works for you too. Good luck. You can also go to 'radioreference DOT com' and there is a Uniden scanner forum there I believe where you could also ask your question. 73.
Mar 20, 2014 | Uniden BCD396XT Handheld Scanner
Is Remote Deposit the same thing as Online Deposit?
Online deposit is sometimes called remote deposit but the two are slightly different.
Both actions allow the customer to deposit a check in his bank account without physically bringing it to the bank. However, the remote deposit requires the customer scanning a digital image of the check and sending it to the bank for the money to be deposited. While the online deposit allows an authorized customer to record a check through an online application and then mailing the physical check to the bank, which gives the customer access to the funds before the check clears in the usual way.
Aug 26, 2013 | Finance
What is Remote Deposit?
Remote deposit is the possibility of depositing a check into a bank account from home, an office or a location different than the bank itself. This is done by scanning a digital image of the check and sending the image through a computer to the bank, without the need of physically delivering the check to the bank.
This option has been available since 2004 for businesses and recently to private customers.
Is my HP4315printer/scanner compatible with your language?
No bank with a sane mind will accept a photocopied / scanned / faxed check or anything else that requires a written signature. Its too easy to forge high-quality fakes using image editing programs.
Mar 15, 2013 | Sun Computers & Internet
I have the BC370CRS SCANNER I am trying to clear all the memory and reset it. It is telling me to hold down 2, 9, and hold and turn it on. That is not working. Can you please tell me another way to do...
Locking/Unlocking Banks When you are scanning conventional banks, the scanner displays the digit corresponding to all unlocked banks. To lock out a bank so that the scanner does not scan its channels, press the letter that corresponds to the bank. The bank's letter disappears from the display. To unlock locked-out banks, simply press that bank's letter again. The bank's letter appears on the display and the scanner includes that bank when scanning. Note: You cannot lock out all banks. One bank must be unlocked at all times. Locking/Unlocking Channels To lock out a channel so that the scanner does not stop on it while scanning, press L/O when the scanner is stopped on that channel, or manually select the channel and press L/O. To unlock the channel, manually select it and press L/O again. Restoring All Locked Out Channels You can restore all locked-out channels in a bank only when the bank is selected for scan. Follow these steps to restore all locked-out channels in a bank. 1. If you de-selected the bank, press SCAN then press the bank's letter. 2. Press MANUAL. 3. Hold down L/O for about 2 seconds. The scanner beeps twice and unlocks all To delete a stored frequency, press 0 then press E. Channels with no frequencies are automatically locked out hope this helps
Mar 29, 2011 | Uniden BC370CRS Base Scanner
Pro 82 Scanner from Radio Shack problem!!
While its in scan mode press the # of the channel to select.. you will see the bar go under the # Then it will scan the channel
Jun 04, 2009 | Radio Shack Pro-82 Scanner
Only one bank blinks
Yes that sounds like the case. Every scanner or radio I've ever delt with that is the way it works. Check user manual on how to turn off and on banks. Good Luck.
Feb 25, 2009 | Uniden BC72XLT Handheld Scanner
My owner's manual for Uniden BC370CRS is NO help! Program help!
Find the frequency you would like to store, press "E" pgm, then select the bank you would like to store it in (1 thru 10) by using arrow up or down then hit "E" again and it will save it in that bank. When you hit scan this will scan all your saved frequencies.
For scanning all frequencies not saved, move the switch to scanner and arrow up or down, when you find one you would like to save follow the process above.
Dec 26, 2008 | Uniden BC370CRS Base Scanner
Radio Shack Pro-95 handheld scanner issues
Here is the online programming tutorial:
http://support.radioshack.com/support_tutorials/communications/200-0523/67345.htm
Here is the full manual Should include Quick guide:
http://support.radioshack.com/manuals/ome20-525.pdf
Here is FREE programming software for the PC:
Includes hardware info. You can buy programming cable at Radio Shack to connect to your PC.
http://www.starrsoft.com/freeware/win95/default.asp
Jan 02, 2008 | Radio Shack Pro-95 Handheld Scanner
Dell Photo 964 All-In-One InkJet Printer Logo
143 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
