Coffee and Espresso Makers
Problem for Coffee and Espresso Makers
Generic problem for all Coffee and Espresso Makers
Kenmore Elite 14 cup Coffee Maker
By truck31 on Dec 20, 2007
We are having trouble with our Kenmore Elite Coffee Maker. Worked fine for two months and then acts like it will start to brew. You get the BREW sign for several seconds and then beeps for several seconds and then turns the BREW display off and then nothing. Hot plate does not get hot, no water in the filter, etc. The filter appears to be clean, no heat, no water, no coffee!!!
Same Problem
Nov 07, 2008
-   Yes, it seems that we all have the same problem with the Kenmore Elite 14 cup Coffee Maker. Mine no longer brews and the warming plate is not hot. I am very disappointed with this Coffee Maker. Please be aware that there is a RECALL on Model #100-900006. -   MMKomar
Oct 02, 2008
-   My unit was only about 5 months old when it suddenly just stopped working. Wont do anything at all.-   Guest
Jul 21, 2008
-   ive unplugged it, re set the time dumped out the water refilled it dumped out the coffee refilled it set the auto and the brew light comes on and that god awful beep happens no coffee no nothing and i need it to work now-   biofly
Jul 05, 2008
-   same thing for me! -   Guest
Jun 26, 2008
-   does exactly the same thing brew light comes on for a couple sec. then shuts off and does nothing. The problem is its my first time using it I havent even used it once-   jimmysmom
Popular Solutions for Coffee and Espresso Makers
Questions and Unsolved Problems for Coffee and Espresso Makers
Answer
Where in North-Central London can I purchase a replacement gasket for a 1-2 cup vigano stovetop... (More)
Answer
How do you disassemble the black and decker undercounter spacemaker coffee maker. I've removed the... (More)
Answer
My Keurig one cup maker has been malfunctioning and water and coffee grounds gush up and out the... (More)
10 Other Users Have The Same Problem - Continued
Comment by courtenaybra, posted on Jun 18, 2008
We are having the same problem, turns on for a few seconds then beeps and turns off. What solutions has anyone found?
Comment by dfoskey, posted on Jun 15, 2008
I bought mine off Ebay and it to worked fine despite some minor light blinking issues and now it will not brew at all. The brew indcator comes on then 4 beeps then it shut's off. Very dissapointed. Kenmore use to be a very good brand. Probably a comuter chip issue. The housing may get damp inside since it's located by the brewing mechanism.
Comment by Guest, posted on Feb 04, 2008
the same problem FEB 4/08
Comment by eegam, posted on Jan 23, 2008
  1. We have the same problem with our Kenmore Elite 14 cup Coffee Maker.
Comment by hbaby_girl, posted on Jan 08, 2008
We are having the same problem! Electronically it goes through all the motions as though coffee should start brewing any minute but the water does not move, presumably does not heat either but haven't checked that yet. About to do more troubleshooting/research and will post again if I find anything.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Coffee and Espresso Makers:
Top Coffee and Esp... Experts
Rank: Guru Guru
Solutions: 898
Experience: im the jack of all trades but a master of none! and being an old git you get to learn a fuw tricks
Ask Me
Find more Coffee and Esp... Experts
Top Small Appliance Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
