Question about Sub-Zero 690 Side by Side Refrigerator
Sub Zero 532 - How do we remove wooden front panels for refinishing? Please advise, Thank you.
  • 358 Answers
You have to take the metal fames of the sides of each door.
Posted on Oct 01, 2009
Sub-zero model 532 side-by-side icing on inside panel
I would get in touch with SUB-Z customer service, they are the only company that still cares about customers
800.222.7820
They will be able to get it fixed
Jun 08, 2010 | Refrigerators
Describe how to replace a solenoid valve on a subzero 532
easy.. disconect power . important. remove the kick plate. the water valve is locate in the left side. its a blue color. inside a bracket or attached whit 2 screws ( depend on the serial break) remove the water valve from bracket. disconect the plug and the and the line and thats all.............................................. NOTE. MAKE SURE TURN THR WATER SUPLY MOST LIKELY IS THE COOPER LINE . CLOSE FROM THE WATER METER OUSIDE YOUR HOUSE OR CLOSE TO THE WATER VALVE....... DO NOT TRY TO REMOVE THE FRIDGE.............. good luck... LEAVE YOR COMMENT IF IT WAS GOOD FOR YOU... THANKS
Oct 06, 2009 | Sub-Zero 632 / S
Sub Zero 532 freezes up behind inside back panel on fridge side only. When this happens inside temp goes up to 50 degrees. Removing back panel and rmelting ice only stops the problem for about 8 days. Any...
You have a defrost problem. You need to have the defrost thermostat and heater checked. Once you defrost it, it will take a week to frost up again.
Sep 22, 2009 | Refrigerators
532 sub zero evaporation tray is filling up with a
This is only normal in an environment of high humidity. My question is the condenser fan blowing over the condensate pan and is the air hot enough to evaporate the water that is in the pan? Has covers been removed on the rear of the refrigerator that may cause a different flow of air. Are all covers in there correct place and not missing panels that could change the flow of air over the pan? Let me know, Thanks, Sea Breeze
Aug 26, 2009 | Refrigerators
Power requirement sub zero 532
115 volts on a 15 amp circuit
May 19, 2009 | Sub-Zero 632 / S
Refrige is 48 and freezer is 0 model 532
Fixing Freon Leak by replacing evaporator coil on Sub Zero refrigerator
May 19, 2009 | Sub-Zero 642
Removing Door Panels on Sub Zero 532
Hi, there is a metal strip that runs down the middle of each door the entire lenth. It is held on with two magnets. Once you pull that strip of metal off, you will see five screws that hold the door handle on. Remove thos five screws and the entire handle comes free. Slide out the panel and replace the handle, screws and metal strip ion reverse order. Take your time removing the magnetic metal strip as it is a very soft metal and could possibly bend or kink up on you.
Hope this helps. I'm having some trouble locating any company that makes stainless stell to match the appliances. All of the metal companies say the appliance manufaturers have a propriety type of lock on the appliance metal finishes. I also have the 532 model.
Good Luck
Mar 25, 2009 | Refrigerators
Sub zero 532: noise increasing.
We have the same SubZero unit and the water leak is the ice maker line or the pan that catches condensation. If you unscrew the panel at the bottom, you will be able to take the pan out and see if the water is from there. If it is from the ice maker line (which was plastic on ours), you should fix this right away as we didn't and we ended up having a $10,000 flood that ruined our hardwood floors. Also, the increased motor noise happened to us as well, but when we had the motor replaced, it is not much quieter.
Nov 15, 2008 | Sub-Zero 632 / S
Need panel sizes for a 532
www.subzero.com or call 800-222-7820 for the specs.
Oct 17, 2008 | Sub-Zero 632 / S
Sub-Zero 532 (About 18 years old)
First do the simple things like cleaning the condensor coils and turning the defrost timer a few times, also check the evaporator motor or just listen to the fan by opening the freezer door. Also check the light switch, make sure it turns the light off every time you close the door.
Jun 26, 2008 | Sub-Zero 632 / S
Sub-Zero 690 Side by Side Refrigerator Logo
158 people viewed this question
Top Sub-Zero Refrigerators Experts
ACME Sub Zero...
ACME Sub Zero...
Sal DeAngelo
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
