Question about Linksys WRT54GX2 Wireless-G Broadband Router with SRX200 (LS-WRT54G2)
How do I get rid of the router using an automatic private address which keeps disconnecting?
I have a WRT54GX2 wireless router.
The internet works fine when I directly connect to the modem because I can either use a PPPoE connection or a LAN connection which always gets me an IP address assigned by a DHCP connection.
But when I connect to the router, it always uses an automatic private address which keeps disconnecting.
How do I get the router to use an IP address that is assigned by a PPPoE connection?
How do I get rid of the router using an automatic private address which keeps disconnecting? I want to be able to use the PPPoE connection through the router.
Is it better to have a DHCP or a PPPoE connection?
  • Anonymous Feb 13, 2008
    everything :
    flashing with new firmaware
    Resetting the router
    power cycling the modem/router
  • Anonymous Feb 25, 2008
    My router was disconnecting as above, but now simply will not connect to the internet at all.
    Novelist:
  • 173 Answers
The router will give you a private address , that is the functionality of the router, the problem is not with your connection, try to upgrade the latest firmware inthe router and reconfig the router in a pppoe mode that will fix your problem..
Posted on Dec 20, 2007
Can't connect to my linksys wrt54gx2 router and even when I do, it tells me there is an ip address conflict and disconnects me
try to connect using a LAN Cable (Wired) connection. and then try to access 192.168.0.1 you should be able to see wireless settings there.
IP address must not be the same with the IP Address of other computers in your house. look for the Range and Increase it so that the router could have a wider range of IP Address to choose from.
Oct 02, 2010 | Linksys WRT54GX2 Wireless-G Broadband...
I can't connect to the internet using my Linksys WRT54GX2 router
is your pc wifi enabaled? if so then do these seps>>
this is the easyiest way.
click connect to(or the connection buttotn)>>connect to the router/internet accesspoint>>after getting connected right click on the connection>>
status>>properties>>networking>>(double click)internet protocol version( u will see two of them do both of them one after one)>>check obtain ip address automaticaly(both)>>check obtain dns address automatically(both).
now close the windows and try to connect again.
let me know what happened
Mar 05, 2010 | Linksys WRT54GX2 Wireless-G Broadband...
My xbox 360 disconnects my Linksys wireless router - i.e. - i have no wireless. Router still shows that I'm connected to the internet, but my wireless goes down whenever I try to automatically find the...
Its the issue with NAT settings,,,you need to login into the setup page of the linksys default address is 192.168.1.1,,,,change the mtu to 1365 ,,,,,disable the firewall and uncheck the block anonymous internet request under the security ,,,,,upgrade firmware under administration tab,,,,trigger the ports under application and gaming,,,,,port 80,88,3074,53...do these four things ,your problem will resolve
Dec 30, 2009 | Linksys 4-port Wirelss Router W/srx200...
Moved router to connect directly to the Comcast modem that also provides VOIP. Comcast activated modem and internet works when computer is connected directly to Comcast modem. Router does not connect to...
Your ISP should have given you the following information...
Static IP, Internet IP Address, Subnet Mask, Gateway, Static DNS 1-3.
With that information at hand, follow tis link to the router user manual and go to Page 11 of the manual to go through the step by step process of setting the router up for an internet connection.
http://downloads.linksysbycisco.com/downloads/WRT54GX2v2_ug,1.pdf
Nov 26, 2009 | Linksys WRT54GX2 Wireless-G Broadband...
Linksys Wireless-G not connecting to internet
Make sure you are plugging the SMC into the WAN port on the Linksys router and not the LAN ports.  Your internet connection (which is your SMC) should always plug into your WAN port on the Linksys.  Any computers that you may need to plug in, like Desktops that are "wired" and not "wireless", should plug into the LAN ports on the Linksys.  If you are not using the WAN port on the Linksys for your SMC modem, then that would explain why you cannot get to the internet on wireless or wired computers.
Here's why you are getting the "low connectivity" message:
Computers don't understand why the Internet is connecting or not connecting...so the "low connectivity" message you keep receiving has nothing to do with your wireless signal strength.   To a computer NIC, "low connectivity" means your network adapter could not find a DHCP server and receive a valid IP address.  When this happens, your network adapter assigns an IP address to your computer in the following range...169.254.0.0, and will display the "low connectivity" message until it is able to receive a valid private IP address from the DHCP server.  You can verify this by going to START | RUN and typing "cmd" (without the quotes), then hit ENTER.  A black box will pop up....then type "ipconfig" (without the quotes) and hit ENTER.  This will show you your IP address, subnet mask, and gateway address, and you can verify that your IP address is in the 169.254.0.0 range.  A valid private IP address is typically in the 192.168.0.0 range, but could also be in the 10.0.0.0 range, or the 172.16.31.0 range.    Also, make sure you have DHCP server enabled on the Linksys router for the LAN.  This will ensure your "wired" and "wireless" computers receive a valid IP address.
The WAN port on your Linksys router should be configured to "Obtain an IP address automatically using DHCP".
Cheers!
Apr 19, 2009 | Linksys Wireless-G Broadband Router
Trying to install Linksys wrt54gx2 srx200 on my vista computer
who is your broadband provider? Is this cable or DSL connection? Setting up the router is done via http://192.168.1.1. Leave username blank, password is admin. If you have Cable ISP, then make sure you have "Automatic Configuration-DHCP" selected and MAC address Clone is enabled on Setup > MAC address Clone (click Clone, and Apply). If it's a DSL connection and your broadband provider gave you a username and password, select "PPPoE" for Internet Connecton Type, and enter in your DSL username and password. Next verify if your modem is communicating with the router by going to the Status page and by verifying that you have an Internet IP address. If none, wait for a few minutes and power cycle your modem and router.
Dec 11, 2008 | Linksys WRT54GX2 Wireless-G Broadband...
Can`t get wireless router to connect to pc. Have uninstalled/installed usb wireless adaptor no good. Router works fine on a wired connection on another pc nearby.`Wireless` pc 10m away from router has...
  1. Go to "Network Connection"
  2. Click Right "Wireless Network Connection" Go "Properties"
  3. Click at Internet Protocol(TCP/IP) and click "Properties"
  4. At General bar,. Click on Obtain an IP address automatically and Obtain DNS server address automatically and Alternate Configuration bars, click Automatic private IP address
  5. After all of this click "OK" and "Close"
  6. wait for 30 second and try to connect again
Nov 10, 2008 | Computers & Internet
Any update for l2pt protocol
Hi Milian,
Currently WRT54GX2 does not have support for L2TP connection. You may try to use WRT54GS. It has an option for L2TP connection.
Hope this helps
Oct 04, 2008 | Linksys WRT54GX2 Wireless-G Broadband...
Linksys WRT54GX2 constantly disconnects
I just upgraded from firmware version 1.01.14 to 1.01.22 and I have the same problem, the router just keeps resetting itself. I think the solution is to go back to the old firmware, but I haven't been able to find a copy yet, Once I find firmware version 1.01.14 for the WRT54GX2 router. I will let you know if this is the solution... :)
WRT54GX2
Mar 08, 2008 | Linksys Wireless-G WRT54GX Router...
My router keeps disconnecting the internet
a blinking power light suggest that the device is already broken. Go to the command prompt and ping the roouter. If you can still ping it then i suggest to upgrade the firmware of your router.
Oct 27, 2007 | Linksys WRT54GX2 Wireless-G Broadband...
Linksys WRT54GX2 Wireless-G Broadband Router with SRX200 (LS-WRT54G2) Logo
369 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
