Can not connect to the internet via router
When trying to connet is says settings saved on this computer for the network do not match the requirements for the network how do I fix this
    Genius:
  • 1,144 Answers
Use the network set up wizard, new connection.
Posted on Oct 01, 2009
Our laptop won't connect to our network set up on our desktop home computer. The desktop is running Windows XP Home Edition V2002, and the laptop is running Windows Vista Home Premium V2006. When we try to...
In your laptop Open Control Panel > Network internet > Network and Sharing Center > Set up new connection or network > match with setting in your PC > Finish. Try to reconnect.
Feb 02, 2011 | Acer Computers & Internet
Settings saved on other computer for the network do not match the requirements of the network now
This error message usually occurs in windows vista & win7 if the settings saved on the computer doesnt matches with the settings in the router...
You can get rid of this message by deleting the list of preferred networks from your computer...
To delete the preferred networks, follow the method given below...
Open control panel > open Network & Internet(double click) > open Network & Sharing center(double click)
On the far hand side left you will have an option called "Manage wireless networks" If you click that, you will see the list of preferred networks that are already saved in your computer... Now select your network, make a right click and select "Remove network" Select "ok" for all the warnings...
Thats it..! you are done..! Now search for the list of available wireless networks in range, you must be able to see your network name without any error mesages... Select your network and click connect, it will ask for the network key(if you have setup one)... Enter the key and get connected...! You must be able to go online now..!
Dec 14, 2010 | NetGear WNR2000 Wireless Router
The settings saved on this computer for the network do not match the requirements for the network
1.Log into router
2. Verify wireless router name( on the computer) >>> ( on/off)
3.Note router name you are connecting to.
4.. Check the laptop do ipconfig /all to see current IP addresses.
5. Set the laptop up in the router by WEP KEY or MAC address.
6.Note router name you are connecting to.
7. Move the laptop about 20ft away and try to log on to the internet.
This is for all routers to set up wirelessly.
Jul 19, 2010 | Netopia 2247NWG-VGx Wireless Router...
The settings saved on this computer for the network do not match,
You need to remove the wireless network from your preferred networks list and reconnect to it.
1. Right click on the wireless icon (picture of a computer) on your system tray.
2. Click on Network and Sharing Center.
3. On the upper left hand side of the page , click on Manage Wireless Networks
4. Right click on you network name and click Remove/delete
5. Now reconnect to your network.
Jun 09, 2010 | Belkin Wireless-N Wireless Router with...
My power went out and now I can't connect to the internet. In the select a network box it says (The settings saved on this computer for the network do not match the requirements of the network. I have a...
Use an Ethernet cable to connect a computer to one of the LAN ports on the router.
Access the router's built-in web-server, and rerun the Network Configuration Wizard, and the Wireless Network Setup Wizard.
Dec 27, 2009 | Linksys Wireless-G WRT54G Router
Icouldn't access the internet. Your help tam, via
Please go in to your router and change the wireless setting from WPA2-PSK to WEP. Ansd then try to connect your laptop.
To windows after you change setting to WEP
(XP bottom right hand side you have system tray in that you have a wireless sign click on it. It ask for the password which you will change put that password click connect)
For laptop also same in case it not work then
(window icon>control panel>network and sharing center>wireless connection>properties>put the password click connect (then it will check out the wireless signal after sometime you will'be able to connect).
Hope this will resolve your issue.
Oct 15, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
I just cant recieve internet signal alhtough all of the cords are in the right spot. Im not setting it up right on my computer my network is telling me that the saved settings on my network do not match...
You can access your router's programming by hooking straight up via ethernet cord, and typing 192.168.1.1 If it asks for username and password, type admin for both. Make sure internet settings are all set to automatic settings and no proxy if you are using cable.
Sep 10, 2009 | Belkin F5D7234-4 Router
I used to connect to my Netgear Router at home. I went to work and they installed their Netgear router. Now I can't connect to my home router. It says "The settings saved on this computer for the network...
The techs must have configured via the routers web page. you will have to either reboot the router, or hold in the reset button for 5 sec, then you can reconfigure.
Sep 05, 2009 | Computers & Internet
Laptop wont connect to wireless belkin router
If you connect the laptop wired, does it work correctly?
If your Wireless router has password protection, try resetting it to factory defaults, and connect it that way.  If you can connect with the factory defaults (with no security), it's likely an issue with the security on your router.
I'd suggest starting again. Reset to factory defaults, re-secure the network and try a different SSID name this time, and try again.
Mar 18, 2009 | Gateway 802.11g Wireless DSL/Cable Router...
Computers & Internet Logo
94 people viewed this question
David Payne
David Payne
