Question about RCA HD52W59 HDTV Projection Television
55 inch mitsubishi rear projection tv red lamp out of adjustment
55 inch mitsubishi rear projection tv red lamp stuck out of convergence, cant use fine sadjustment for convergence in tv menus to fix. when i look at the rough adjustment the red lamp is about a half inch high from the center. i get destortion in the picture both top and bottom of the screen
  • SD Tech
    SD Tech May 11, 2010
    Mitsubishi? what is model number?
    Genius:
  • 1,112 Answers
Have convergence IC's replaced. I believe this unit uses STK-392-570 convergence IC's Only one has gone bad but replace them both, because if one has failed then the other is not far behind, for Blue and Green. One handles Red, One handles BLUE and Grn. There are only two of them in the set, They are the two largest IC's in the entire set.
Posted on Oct 01, 2009
I have a 55 inch rear projection mitsubishi tv. it recently has started showing what looks to be white spots when viewed at a distance on a dark screen. when you look at it closely it actually is red green...
It is called Convergence. You have three CRTs. Red, blue, Green. When they are not aligned, you will see the individual colors. See if you can do some alignment in the users menu. Look for Converge or Convergence in the menu. Either under video or setup.
Mar 09, 2011 | Mitsubishi WS-55511 55" Rear Projection...
Mitsubishi TV VS-55601S Convergence Problem
Convergence it dead.Must replaced convergence,know how to solders?Tries these websites for convergence kit.Tv repair World.com,or Tv Repair Kits.
Nov 17, 2009 | Mitsubishi VS-55601 55" Rear Projection...
We have a 52 inch rear projection Mitsubishi not sure of the model number and the picture is starting to go blurry with reds and greens at the bottom of the screen
Here is another similar problem with a Mitsubishi Rear Proj. TV and it has some things to try and an estimate if that is the problem.
"Cost of convergence repair is always around $400"
http://en.allexperts.com/q/TV-VCR-Stereo-1749/Mitsubishi-WS55511-Projection-TV-1.htm
You could also try messing around in the menu for convergence adjustments. Usually it will let you adjust at 8 points on the screen.
Oct 26, 2009 | Mitsubishi VS-50607 50" Rear Projection...
Picture was fine, then lines diagonally, now light
Projection sets have two very common problems outlined below.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. The TV can also shut down when the convergence starts to fail.
Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith, RCA and others.
You can more info and a DIY convergenece repair kit with instructions from TV Repair Kits using the link at the end of this article.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped or bowed
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 10, 2009 | Mitsubishi WS-55909 55" Rear Projection...
Out of focus
You have a convergence problem, probably the convergence electronics are going out or the TV has been violently moved and needs a mechanical alighnment. Small adjustments can be made from the menu.
May 17, 2009 | Mitsubishi WS-55859 55" Rear Projection...
No Red, can't adjust Red convergence, Blue works fine
looks like the red "bulb" has blown.
you need to replace but can be expensive.
Apr 28, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Mitsubishi WS55511 Convergenc
REPLACE THE CONVERGENCE IC (OR IC'S). A FUN JOB I CHARGE ABOUT 200 FOR.
Jun 25, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi 55 inch 1080 tv
Is it flashing a two digit code such as 34 as thats a common fault with the WD52525 V26 chassis for a lamp abnormality caused by two bad capacitors on the PWB PCB
Jun 17, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Red convergence wont move
if the red line is blurry and you have adjusted the screen focus control and does not work then you prob have a bad red CRT or bad red CRT fluid.........
convergence STK have nothing to do with the red being blurry
Dec 09, 2007 | Mitsubishi WS-55809 55" Rear Projection...
Blue color lamp cannot converge
GO TO THE CONVERGENCE MENU (MENU 2 3 5 9) AND CHECK THE ADJUSTMENT SETTINGS FOR CONVERGENCE. IF ALL ITEMS ARE SET AT "127". THE EEPROM SETTINGS ARE AT DEFAULT.
Nov 30, 2007 | Mitsubishi VS-55601 55" Rear Projection...
RCA HD52W59 HDTV Projection Television Logo
674 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
