My computer doesn't boot up, all it does is beeps three times and nothing happens.
  • Jaipal Nair May 11, 2010
    Did you check the memory, it is recently removed or altered. try getting out the all the memory and refix it. also any other cards recently inserted.
  • 1,165 Answers
Sounds like memory problem but to be sure contact the manufacture and find out what the 3 beeps mean.
Posted on Oct 01, 2009
3 Suggested Answers
  • 124 Answers
SOURCE: Motherboard beeps three times, computer won't boot up
Three Beep Code is an indication of RAM Failure or incompatibility.
If you recently added memory, I would remove the new stuff and see if the beeping goes away. Try the new stuff alone, see if it goes away. Maybe (if you added new stuff lately) they are incompatible.
If you have not changed anything lately, you may have a stick of RAM that has croaked on ya.
This link explains the beep codes for you.
http://support.gateway.com/s/Servers/COMPO/MOTHERBD/WME859199/WME859199faq2.shtml
Posted on Jun 13, 2009
crok41
  • 621 Answers
SOURCE: The computer will not boot up when power button is
This will be a memory / ram problem. If you have more than 1 module installed first try switching another module to the first bank if still not working try 1 module at a time until you find the defective one. Memory is pretty cheap nowdays or you may find you didnt really need the total amount of memory installed. Hope this helps........from Scott
Posted on Dec 13, 2009
Power_LED Buzzer on Mainboard continues to beep every 3 seconds fans are operating but system doesn't boot or show nothing on monitor(which is ok)
well you didn't say what the beep code was, is it just one beep every three seconds? Or is there long beeps, short beeps, and long and short time between them before they repeat?
If it is one, beep, every three seconds and the beep is one second long, there is a problem with a connection somewhere. Typically it happens in older computers that are in dusty environments. You can try to (only if your comfortable with how to do it) unplug the memory modules from the motherboard and keep track which socket which is plugged into, and mix them up so they are in different slots from their original positions, then try to reboot.
If that does not work and there is no display at all (even POST information) it could be a bad card (modem, sound, video, etc.) remove all but the video cards and try a boot again, if you can boot then plug only one card in each time you try to boot and when you find the offender replace it with a new one (that is if you use that card, if it is a modem and you do not use dial up internet you do not need the modem card plugged in.
But one, one second long beep every three seconds typically means there is a connector problem somewhere, if the computer is older carefully clean out the dust and unplug and re-seat all of the connectors and hopefully that will solve your problem
Jul 31, 2013 | E-Machines eMachines Desktop PC
Tip
Computer beeps
If you try to power on your computer and nothing happens but a bunch of beeps there is something you can do. The beeps actually mean something. To make sure you can hear the beeps check in the bios options. If there is an option for a silent boot you won't hear any beeps. If you hear one beep every time your computer starts then you don't have to worry about this.
If you want to check this setting refer to my other tip on how to enter bios and change boot settings.
If you try to boot your computer and nothing shows up on your monitor do these steps first.
1-Check all your cables in the back of the computer.
2-check your power source and power cord to the monitor
3-try another monitor if possible
4-If on a power bar try to turn off the power bar and reset the breaker
If you try to boot your computer and nothing happens and you hear beeps look at this website. The beeps you hear are actually telling you what is wrong. Look at the website by clocking on the link below and click on the computer beep codes link. If you want to scroll down past the link it will show you bios codes to enter the bios in your computer
http://www.michaelstevenstech.com/bios_manufacturer.htm
on Jan 28, 2009 | HP Compaq Presario SR1500NX (PX786AA) PC...
Memory upgrade on gx280 beeps on boot but doesn't start. memory beeps 1 234 5 6
When your computer emits beeps when you power on the computer, it's usually means that you have a memory issue. Try re-seating the memory modules and power on the computer. If you have more the one module, insert one at a time and power on the computer. The other issue is if that model supports 4 gig memory.
Aug 30, 2012 | Dell Computers & Internet
How to fix a laptop that doesn't turn on but beeps 1 long beep and 3short beeps
This POST cade is related to RAM problem
one beep, three short beeps
three short beeps, one beep
  • Memory problem: bad DIMM or bad DIMM slot
Try reseating the RAM, if this does not work then remove the RAM module and take it to your friendly computer repair shop and get them to test the RAM for you.
May 12, 2012 | HP Pavilion ze2000 Notebook
When i try to turn it on it beeps 3-4 times and nothing appearsm on the screen. but i can hear it running
Beep codes will site specific problems. Say it beeps 3-4 times is not specific enough.
One suggestion is to remove the disk drive, memory and any other device. IF the system is OK it should boot to a BIOS screen. If it doesn't, you probably need to replace the computer.
If it boots to BIOS, one at a time replace each component and try to restart. That will identify the failing device.
Hope this information will help.
Your response is very much appreciated. Thank you for using Fixya...
Sep 27, 2011 | IBM ThinkPad T30 2366 Notebook
I have a Compaq Presario SR2020NX. I press the power button and the fan comes on, the green light is bright , the cd drive blinks then stops as if the computer is starting but nothing happens. The fan...
Disconnect the drive and try to boot to the BIOS (usually with F1, F2 or Delete key). If that doesn't work, try removing all cards from the computer (except a video card if the video port is not on the motherboard). If you can boot this way, try inserting back any removed cards to see what hangs it. Do you hear any beeps when the computer is booting (beep codes)?
Sep 24, 2011 | HP Compaq Presario SR2020NX PC Desktop
No video
change the boot sequence from the BIOS and set the first boot to the Hard disk and check.
Nov 11, 2009 | Gateway GT5220 PC Desktop
At start up, before windows loads, a consistent series of annoying beeping occurs....
If they're occurring right as you turn the computer on, it's your Power On Self Test (aka POST) letting you know. Since I can't be more specific, here's a synopsis of POST beeps:
One single beep followed by three, four, or five beeps -- System-board problems, possibly with DMA, CMOS setup chip, timer, or system bus. The computer usually won't boot when this is the problem.
Two beeps -- The POST numeric code is displayed on the monitor, usually nothing to be concerned about, but you might google the code on another computer and see what you get.
Two beeps followed be three, four, or five beeps -- First 64K of RAM has errors. Solution is to replace RAM.
Three beeps followed by three, four, or five beeps -- Keyboard controller failed or video controller failed. Either you won't be able to see or type with this error.
Four beeps followed by three, four, or five beeps -- Problem with serial or parallel ports, system timer, or time of day. Check your BIOS settings (usually F2 at start up) to make sure everything is correct.
Continuous beeps - problem with power supply. Probably won't do much with this error. At the very best, your computer will boot and run very, very slowly.
Hope that helped.
Sep 01, 2009 | Compaq Computers & Internet
Screen won't appear upon start up and I get 3 beeps but no screen
3 beeps POST code (power on self test) means RAM problem.
Reseat the RAM module/s and boot up your computer.
If you have two RAM modules, remove them both and insert one at a time to test them, to determine which module is faulty.
If it still doesn't work then replace the RAM module/s
Apr 02, 2009 | Everex StepNote NC1500 Notebook
Laptop won't boot up. Only 3 beeps.
listen to the beep heres some information on beep code errors
Beep Code: Description of Problem: No Beeps Short, No power, Bad CPU/MB, Loose Peripherals One Beep Everything is normal and Computer POSTed fine Two Beeps POST/CMOS Error One Long Beep, One Short Beep Motherboard Problem One Long Beep, Two Short Beeps Video Problem One Long Beep, Three Short Beeps Video Problem Three Long Beeps Keyboard Error Repeated Long Beeps Memory Error Continuous Hi-Lo Beeps CPU Overheating
Jan 25, 2009 | Toshiba Satellite X200-AA3 Notebook
Computers & Internet Logo
190 people viewed this question
David Payne
David Payne
