Question about Cameras
Eumig mark 8 Have the projector but no power cable and cannot be sure of lamp location
2 Suggested Answers
SOURCE: I am looking for a free manual for the Eumig Mark 8 projector
was there any chance of me getting a free manual or is this site just a money making idea, obviously if it sounds too good to be true..it usually is!
Posted on Sep 15, 2009
I need a claw arm for a EUMIG MARK 822 projector.
Sorry we have no parts for sale here.
Jun 27, 2017 | Cars & Trucks
Where do I find a power cord for Eumig Mark 610D projector
Try a radio shack they carry a lot of power cords and for projectors
Nov 23, 2014 | Office Equipment & Supplies
Eumig mark 8 manual
Go to manuals online and down load the manual. I have included the URL: http://office.manualsonline.com/manuals/mfg/eumig/mark_8.html
Nov 24, 2013 | Cameras
Red warning light
follow this steps and fix it. God bless you
  • Secure the lamp cover and the air filter cover of the projector body if the projector does not power on. Ensure that the power cable is firmly connected to the projector and an active power plug. If the projector was turned off and then on quickly--let it sit for 90 seconds before trying to turn it on.
  • 2
    Replace the projection lamp if the projector will not power on or if the lamp indicator is flashing. Turn off the projector and let it sit for at least 30 minutes. Locate the lamp cover and remove or loosen the lamp cover with a screwdriver. Carefully remove the projection lamp from the projector housing using the handle, if available.
  • 3
    Place the new projection lamp into the projector housing and secure it to the projector. Replace the lamp cover and reset the lamp timer. Power on the projector to ensure the new lamp is working correctly.
  • 4
    Remove the projector from the enclosed area to allow air circulation if it constantly overheats. Place the projector into an open area and make sure there is no blockage for the ventilation holes. Unplug the projector for at least 45 minutes to allow it to soft reset.
  • 5
    Clean the air filter to allow the projector better air circulation. Turn off the projector and unplug it from the outlet. Remove the air filter cover and use a vacuum to remove dust from the area. If the filter is unable to be cleaned correctly or is damaged, then replace it. Pull the air filter from the projector and place the new one in the now empty slot. Close and secure the air filter cover.
Oct 29, 2013 | Sanyo PLCXU355 LCD Projector
How do I change my projector lamp?
Instructions
  1. Front Projector
    • 1 Disconnect the power cable from your projector. Allow it to cool for 30 to 60 minutes. Lay the projector upside down on a table.
    • 2 Remove the lamp cover, typically located on one of the rear corners of the projector's underside. Depending on your projector, you will either have to loosen a few Phillips screws or press on one or two plastic release tabs to remove the lamp cover.
    • 3 Loosen the screws holding the lamp assembly in place. Grab the assembly by the handle and slide it out of the projector.
    • 4 Slide a new lamp assembly into the projector. Don't touch the glass on the bulb because it will damage the bulb. Tighten the retaining screws on the lamp assembly and replace the lamp cover.
    • 5 Turn the projector right side up and reconnect the power cable. Power on your projector.
    Rear Projector
    • 6 Unplug the TV from the outlet. Let it cool for 30 to 60 minutes.
    • 7 Remove the lamp cover. On most rear projection TVs, the lamp cover is located on the right or left side of the TV's rear panel. Remove the cover by loosening the screws and pulling the cover away from the TV. Certain manufacturers, like Mitsubishi, have the lamp cover in the front of the TV, near the left speaker. To get to the cover, you must first use your fingers to pry off the front panel below the screen, revealing the speakers and lamp cover. Loosen the screws on the cover and pull it away from the TV.
    • 8 Remove the lamp assembly. Loosen its screws, grab the handle and slide it out of the TV. If you have a newer Sony model, there are no screws. Instead, press the release tab to unlock the lamp assembly and slide it out of the TV.
    • 9 Slide a new lamp assembly into the TV. Don't touch the glass on the assembly, as the oils in your fingers will damage the bulb. Tighten the screws or pop the retaining tab into place.
    • 10
      Replace the lamp cover and front panel, if necessary. Plug your TV back into the electrical outlet and power it on.
Tips & Warnings
  • Touching the lamp assembly before it has cooled can cause a nasty burn.
Read more: How to Change a Projector Lamp ' eHow.com http://www.ehow.com/how_7307928_change-projector-lamp.html#ixzz1rpURlpva
Apr 11, 2012 | Office Equipment & Supplies
I press the power on and the lamp led not the
Hello :
Try to change the bulb .
Here is how :
1:Make sure that your power switch is off and that the power cord is unplugged from the electrical socket.
It is also wise to unplug any other cables and label them in order to restore them in the right way once the lamp is replaced.
2:In order to see the lamp, remove the access handle on the outside cover. You may need to use a screwdriver.
3:Pull out the used lamp and clean the relevant parts using micro fiber products and not paper.
Please note that in some projectors a small inside filter should also be replaced.
4:Insert the new lamp into the projector carefully avoiding touching the glass of the lamp itself.
Touching the lamp will deposit skin oil that will likely damage any new lamp during use.
5:Reassemble the access panel, replug the cables and power up the projector.
Things You'll Need:
new projector lamp
screwdriver
micro fiber duster
Warning:
avoid touching the bare projector lamp.
please rate !
Apr 12, 2010 | ViewSonic PJ458D Multimedia Projector
Eumig 822 sonomatic 8mm dual guage cine projector. Claw fails to engage sprockets in gate. Problem probably due to forgetting about retracting claw when changing formats. Who could service/repair this...
I have a Eumig 824 Sonomatic that needs repair to the claw mechanism, new rotary switch control knob and front sprocket for Super8 mm. Can this repair be effected by you.
Dec 27, 2009 | Cameras
I am looking for a free manual for the Eumig Mark 8 Projector. I have an old projector and want to show film of my late mother. Film is original 8mm film 'not' super 8mm. Unfortunately I do not know how to...
Sep 14, 2009 | Cameras
I can't find the bulb for my old eumig p8 automatic projector, looked every where, it's a 4 pin bayonet 12v 100w blacktop
Have you tried Projector Doctor on the web? Their toll free number is (800)789-9820. They advertise 24/7 support. Also, All Projectors.com...(800)901-8684. Free calls...start there--they probably could point you in the right direction!---Rick
Sep 07, 2009 | Artograph Projector Bulbs 100 watt -...
Name
Hi j cwff
Ok this would be a faulty lamp if you can spot bubbles or vein like looking marks on it in either black or white.
I'm sure you'll solve this by just replacing the lamp and resetting the lamp timer.
May 26, 2008 | Toshiba TDP-S8 Multimedia Projector
Cameras Logo
208 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
