Magnovox 13 inch color tv. RR1337-W101
HI everyone,
I have an old magnovox 13 inch color tv (RR1337-W101 Chassis 13S401-00AA) and I was wondering how to program channels automatically. When I press menue it will give me the add and delete menue but I cant see how to auto search.
Thanks,
mike
  • 905 Answers
SOURCE: RCA 19-Inch Diagonal XL-100 Color Television
you have to manually add and delete channels
Posted on Dec 09, 2008
sharptech1
  • 29 Answers
SOURCE: sony trinatron has no menu control, can't auto add channels
YOU NEED TO GET INTO THE CONSUMER MENU AND ACTIVATE THE AUTO PROGRAMM MODE. I BELIEVE WALMART CARRIES A UNIVERSAL SONY REMOTE WHICH WILL ALLOW YOU INTO THE MENU.
APGONZO
30 YR SERVICER
Posted on Jan 12, 2009
SOURCE: 3 Digit Product Code for Magnavox tv RR1337 W101 (13S401-00AA)
0807 works with a Philips Universal Remote on my Magnavox RR1337 101
Posted on Jul 04, 2009
  • 864 Answers
SOURCE: I have an older magnavox
If the cable provider is sending digital signals a TV that old will not be able to receive them. If they are not digital signals they may be encrypted. You may need a cable box from the cable provider or use a DTV box to get free over-the-air digital broadcast signals.
Posted on Aug 22, 2009
Mas Baz
  • 177 Answers
SOURCE: Is there any way to add more channels or delete
Haier HLT71 is a digital TV, that meanthis tv can recive digital broadcast.
A digital tv have 8 program each channel. Not like analog tv that only 1 program each channel.
So, if you want to save 1 channel , 8 channel will automaticaly saved as well.
Thats imposible to save or delete from your program.
Posted on Mar 21, 2011
I have a magnovox 52 inch hdtv and i deemed all the contrast color abd brightness so that the room would be dark, now the problem is i cant see my screen to get it back bright
Hi Edwin.
The exact procedure depends on the TV model. Start disconnecting the power cord for five minutes. That works only with old models. New TVs retain settings even after disconnecting power.
If power own reset does not work, please give me detailed info on the TV's make and model, so that I can give you the exact reset procedure.
Regards.
Ginko
Oct 30, 2011 | Refrigerators
Hello, my 25" Magnovox (#mt2501c)
Tv fell off about 3 feets or more?Yes,turn on the tv see if u getting any power to the unit?Might have broken main PCB board too.If unit still have power,check see if tv get statics screen have colors shaded in red or mutiples colors,mean the tv CRT(tv tube) yoke is dead and damages scrambles radiation.Or the tv getting power but have high pitch sqeeling noises or rattles noises,tv have the CRT-(tv tube) is crack by the neck or broken totally.CRT have damages problems or dead tv is worthless,beacause of CRT(tv tube) is dead,not fixable even that antena connector input is replaced.
Feb 17, 2011 | Philips Magnavox MT2501C 25" TV
Philips Magnovox FP5240 W101 color is washed out and NO brightness. has to be near dark to see picture
ll projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 12, 2011 | Philips Magnavox 9P6034C 60" Rear...
I have a 52 inch RCA projection tv. Where are the color adjustment screws on the back of the tv that everyone keeps telling me about?
This is Chassis PTK195-There are screen/focus adjustment knobs (red green and blue) at the front of the set - behind the speaker grill and front access panel.
Oct 11, 2009 | RCA P52926 52" Rear Projection Television
How do I shut off the Closed Caption feature?
Bluffy you should access the menue on your remote and be able to shut it off!
Feb 16, 2009 | Philips Magnavox 27MS343S 27" TV
New TV won't ''talk to'' old VCR
using the magnovox remote, reprogram the vcr's channels. set it up to use cable not air. when the vcr was unlugged it lost it's channel memory. don't buy new cables, you're getting a picture and sound so that means your rca cables are ok.
Jan 20, 2009 | Sharp Aquos LC-32D40U Television
Magnavox RR1337 W101 skipping stations
Main system control memory IC fault. This is a very small IC; have 8 solder terminals, and can be located very near to the main system control-chroma IC. Check and replace it. Be sure to replace it with the same number printed on it; in all respect. Otherwise, it won't go. http://electronicshelponline.blogspot.com/ Before replacing it, try a reset to this set, and then check.
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here.
Aug 26, 2017 | CTX Televison & Video
Apr 28, 2008 | Televison & Video
I need to take the smartlock off
so silly. All I needed was to get a universal remote. I went online to magnovox.com and they gave me the code to use to take the code off. Thanks for contacting me back. My computer has been on the blink. Still not working right.
Queen
Feb 12, 2008 | Philips Magnavox 13MT143S 13" TV
Color problems at top and bottom of screen
Repair Kit for Hitachi convergence Chassis DP-14G
KIT10 Includes 2 pcs STK392-150 , 1 each of the following 1W axial lead fusible resistors:
http://www.eserviceinfo.com/
http://www.digitalhome.ca/forum/search.php
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 17, 2006 | Hitachi 42V715 Rear Projection Television
Televison & Video Logo
50 people viewed this question
Top Televison & Video Experts
