Question about Facebook Social Network
I cannot log in, it laways give me an error message
    Problem Solver:
  • 9 Answers
Clear your browser history, cookies etc and then try...
and also check ur email which is registered with facebook...
Posted on Oct 01, 2009
Rw 240 scantool, gives the following error message:Could not create directory ...The filemane, directory, or volume label syntax is incorrect.This is my first time using this plotter/scannerRicoh RW 2
Check the folder name & location of the directory at the end of the error message string, then check to see if that directory actually exists and if you (logged in user) actually have full read/write privileges to that directory.
May 08, 2014 | Ricoh - RW-240 Print Controller - 411737
My printer is giving me this error message "Batch
That's a batch error, more than likely due to a communication issue between the pc and the printer. If you reboot the printer, THEN reboot the pc you should clear that error.
This error sometimes occurs when the printer has been shut down whil logged into your software, which disables communications between pc and printer. The error indicates that the printer didn't receive enough data to properly print the batch of labels/tags.
Sep 14, 2011 | Paxar Monarch 9825 Thermal Label Printer
After 20-30 prints i got this error.. error 6A80 can you help me about this my printer is PIXMA iP4760... i laways plug in an d out the power cable.. can i have a long time solution with this problem...
In the service manual write this
1) Foreign material or paper debris
around the purge drive system unit;
remove foreign material, and
confirm that the ink absorber right
beneath the purge drive system unit
stays in place and does not contact
the unit.
2) Foreign material or paper debris
around the ASF unit;
remove foreign material.
3) Cable connection
4) Part replacement:
- Purge drive system unit
- Logic board
As technician i say to replace the purge unit.Pls give me a vote I have been helpful.
Mar 06, 2011 | Canon PIXMA iP4700 InkJet Photo Printer
Upon trying to log on to Yahoo messenger I got an error message that read " your access is denied because you logged on by another computer. I did not log on another computer. What can I do?
If you were logged into your mail page and didn't properly log out you have to go back in and log out properly.
Hope this helps.
If I have helped you resolve your problem, please
consider giving me a good rating and a quick
thanks or good job.It will help me as well Thank
you.
Oct 23, 2010 | Yahoo Messenger
Photoshop Elements 7 is not working on my vaio with vista 64 bit
Starting Adobe Photoshop Elements, the Editor returns the error message "Unable to continue because of hardware or system error. Sorry, but this error is unrecoverable," and the Organizer returns the error message "Interface not found."
Solution: Enable the Event log service.
1. Choose Start > Settings > Control Panel.
2. Double-click Administrative Tools, then Services.
3. Right-click Event Log and select Start.
Note: The Event Log can only be disabled in the Microsoft System Configuration utility (msconfig) under the Services tab, but should never be turned off.
Background information
The error messages "hardware or system error..." or "interface not found" when you start either the Editor or Organizer indicate a system level problem. These messages display if Event Log is disabled. The Event Log is a Microsoft service that should never be disabled.
If you found this information helpful, please give me a big thumbs-up when you rate my answer. Thanks!
Sep 23, 2009 | Adobe Photoshop 6.0 for PC
SQL Invalid cursor number 135 error
The error is being generated because you are trying to order on a value not in your selected fields e.g EFFECTIVE_DATE
You only have TRANSACTION_TYPE in your select statement
Sep 24, 2008 | Gupta Team Developer for PC
System Error (-1) in my 6670
well, i have , all i do just erasing all the logs, and its back to normal again
Mar 25, 2008 | Nokia 6670 Handheld
Microsoft updates
Most of the time when updates cannot be installed, is because you have installed a file that is newer than the one provided by Microsoft, or you already have the "update" and Microsoft gives you the error.
Essentially when your computer communicates with the Windows Update website. It uses TWO technologies called:
Active X - to interact with the Microsoft site. The first time you visit the Update website, using your profile, you are asked if you will accept the Windows Update Control Package (the Active X control) onto your machine.
SSL (Secure Socket Layer) - A method of data encryption used by Internet Explorer.
Now this general error message 0x800A138F, that some folks get when they visit Windows Update, has been around for a while. BUT, when the MSBlast virus was unleashed Microsoft changed a few things at the main update website. One of them was to use Akamai for additional bandwidth and this connectivity is exclusively using HTTPS (SSL) for the downloading of the update catalogue. It is since then that we have seen an escalation in the number of 0x800A138F error messages!
The following steps will help many of you... BUT
What would be REALLY helpful to anyone trying to support you, is if you go to the "Windows Update Log" and look for any "Errors". This gives a clearer indication as to the exact nature of the problem. (The 0x800A138F error message is a "General" error THE real error number is in the log. A list of possible error messages is in a table at the bottom of this page.)
The windows update log is in the following places:
C:\Windows\Windows Update.log (Win XP & Win98/Me)
C:\WINNT\Windows Update.log (Windows 2000)
Just copy and paste the above in Windows Explorer to open the log file...
Feb 26, 2008 | Microsoft Windows XP Professional With...
Facebook Social Network Logo
70 people viewed this question
Top Facebook Computers & Internet Experts
David Payne
David Payne
Are you a Facebook Computer and Internet Expert? Answer questions, earn points and help others
