Question about Royal Sovereign Heating & Cooling
I have an air conditioner model ARP 1000 ES. It was purchased in August 09 and now it won't come on. there is a red light that blinks right above the on and off switch. Can you tell me what could possibly be wrong?
  • 24 Answers
It is possible the fuse is blown inside of furnace or air handler it should be a 3 or 5 amp car fuse also check the fault code inside of door panel there is a list of fault codes listed
Posted on Oct 01, 2009
Window kit for RS ARP-9411
I assume you are looking for the window kit for ARP-9411 Portable Air Conditioner. If so, contact
Royal Sovereign Customer Support 1-800-397-1025 .
Hope this helps you & thanks for choosing FixYa.
Aug 19, 2011 | Royal Sovereign ARP-1000EX Portable Air...
Just bought a 12000 btu standing air condition. Plugged it in and water light comes on . Took out drain plug to check water, no water. light keeps blinking. checked reset and test, light still blinks....
I checked your Owner's Manual and according to it, you have done all the right things. I will suggest one other thing. Turn the unit OFF and unplug it for 15 minutes. Then plug it back in and turn the ON/OFF Switch to ON. During that 15 minute timeout, the electronics should have reset and reverted back to the original factory settings. If it did, the full light should not come ON. If it does, contact Royal Sovereign Customer Support (in the USA) 1-800-397-1025. In Canada 1- 866- 961-6673.
I hope this helps you and thanks for choosing FixYa.
Jul 28, 2011 | Royal Sovereign ARP-3012 Air Conditioner
Water keeps on spilling out the back of the ARP 1000 ES Unit. I don't know how to empty the water container that must be located on the inside
The drain plug for draining accumulated water is located on the back of the unit's lower left side (as you're facing the back just to the left of the cord keeper. Unplug it, disconnect the exhaust hose and roll it to a drainage area. Unscrew the plug and let it drain. Securely replace the drain plug when draining is complete.
Hope this helped you.
Jun 09, 2011 | Sovereign ARP-1000E Air Conditioner
Model # m6p09s2a portable maytag air conditoner unit...red light keeps blinking at the unit where power button is located....unit will not turn on. the light just keeps blinking
Greetings,
I have the same model air conditioner, and had the same symptoms. As you've probably discovered, Fedders is the company that actually built it, and went of business. No one is supporting it any more.
However, you may be in luck. I fixed the problem by simply tipping the unit almost all the way over on its back (leave a little gap) and letting the water drain out of the hose and the filter. After that, it started right up.
Hope that works for you. Stay cool. :)
Jun 16, 2010 | Maytag Portable Air Conditioner M6P09S2A
Model arp-900e wont start keeps popping breaker
Sounds like you have a short or a groud in a fan motor or compressor motor. You can unhook one component at a time and turn it on after each component is disconnected to figure out which one is grounded.
May 03, 2010 | Royal Sovereign Portable Air Conditioner
A red light came on and the unit turned off
see if you can push water from the other end to see if you have something that stuck inside
Sep 08, 2009 | Royal Sovereign ARP-1008 Portable Air...
Royal Sovereign not keeping the room cool.
electronics give off alot of heat you need larger unit
May 19, 2009 | Royal Sovereign ARP-4009 Portable Air...
Heating & Cooling Logo
256 people viewed this question
Top Royal Sovereign Heating & Cooling Experts
jdthefixer
Bill Long
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Royal Sovereign Heating and Cooling Expert? Answer questions, earn points and help others
