Question about Poulan 1630 16" Chain Saw
Leaks bar oil
We have a poulan farm hand chain saw and when we put it in the case to store it and go to bring it out again, there is a pool of bar oil there i cannot find why it keeps leaking when we store it if you have any ideas please let me know!
    Guru:
  • 597 Answers
The chainsaw squirts oil into the oil hole in the bar. The chain picks up the oil and carries it all the way around the bar lubing it and the chain. When you quit running the saw there is still a lot of oil on the chain and all away around the chain guide in the bar. Once you quit running it and it sets a while all the oil will follow gravity and run to the bottom of the bar and drip out into the case. It's just another one of life's little nuisances. Have a nice day! Obwhon
Posted on Oct 01, 2009
Saw dies when giving it gas
It dies because it's flooding as you increase the amount of flow, a small carb adjustment is needed. As far as the leaking bar oil, if the saw has a pump replace the gaskets between the motor and the bar and reduce the amount that the saw puts out when running. Let me know if that cures the problem.
Sep 17, 2012 | Poulan Pro Chain Saw 46cc 20"
I have a Poulan 2750 Farm Hand 2.8 ci saw with 20" bar. Been a great saw but this last winter all the oil leaked out of the oil tank and made a real mess. What does it take to fix that and is it...
Quite honestly the cheap solution to the problem is to either empty the tank before you store it, or put it on top of an oil pan.
If it isn't the cap that's leaking, your looking at a heck of a lot of work. The tank is integrated into the frame. If you want to replace it, you'll be tearing the whole saw apart.
Aug 31, 2011 | Poulan Pro Chain Saw 46cc 20"
It won't automatically oil the chain. I've put very thin oil in and it sitll doesn't oil. I've taken the breather tube out and cleaned it. Not sure what else to do.
Release the chain brake, then remove the bar and chain. Clean the engine where the bar fits up to, start the engine, and look for oil oozing out of a small port in the engine side. Make sure to replace the thin oil with regular bar oil. If the oil does ooze out, then clean the small oil passages in the drive end of the bar--they run from the large holes out to the chain groove on each edge of the bar. If no oil oozes out, check the oil filter inside the tank. If ok, then the oil pump requires service--it is located just behind the clutch drum on the crankshaft. The clutch has left-hand threads and can be difficult to remove--you might wish to farm the oil pump repair out to a service shop that has the proper tools and procedures. Hope this helps!
Nov 06, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Chainsaw bogs down when trigger is pulled
Check the fuel filter, air cleaner, and muffler for plugging. Check the fuel lines for decay or other damage. Make sure the carburetor fasteners are tight. Try to pull the chain by hand. If not possible, remove the bar and chain, then clean the entire area where the bar fits to the engine. Run the engine for a few moments--oil should ooze out of the port in the side of the engine case. If nothing, then you need to investigate the oil pump, lines, and oil tank for blockage, or other failure to deliver oil. If it does ooze out oil, then clean the bar drive-end small oil passages that feed oil out to the chain groove and the entire chain groove. Make sure the sprocket tip turns freely and is undamaged. Re-assemble the bar and chain making sure the teeth cut toward you on the bottom run. Bring the chain up to the bar with the tightener, but not so tight that the chain can't be turned by hand. Hope this helps!
May 29, 2010 | Poulan Pro Chain Saw 46cc 20"
16" Electric Chain Saw: what kind of oil is used for electric chain saw...
I assume you are asking about the oil for the chain. Any good quality "Bar and Chain Oil" will do fine. Do not use motor oil you use in your car engine as it will not properly lube the chain and will result in quicker dulling and early demise of the chain.
You can get the "Bar and Chain Oil" at most hardware stores or Farm Supply stores.
May 17, 2010 | Remington 16" Electric Chain Saw
Bar oil leaking constantly. How do I fix it?
My wildthing does it too but if i lay it on its side(bar on ground)it doesnt.I have stored mine this way for years and i dont have that problem.
May 13, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
These saws are of the self oiling type there is no tip or bottle it consists of a tank and a channel the oil flows thru and on to the bar by gravity. There is a type of bar oil system on some saws that come with a button you push which In turn pumps oil onto the bar. But the poulan is not one of them. I have a 15 year old farm hand 20" bar and a two year old poulan wild thing 18" and both leave there oil in the case when sitting I beleive the fix would be drain it after use and clean up.
Mar 21, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
I have a Poulan 20" chain saw that keeps leaking out the bar oil every time I put it in the container and store it. What causes this and can it be fixed by myself?
Most chainsaws have an adjustment for bar oiling and its quite normal for a chainsaw that is stored for long periods of time (weeks or even days) to leak out the bar oil. This is normal for chainsaws stored for several weeks or more.
Some of it may be reduced by adjusting the rate of flow for the bar oiler, read your manual carefully before attempting to adjust it. Adjust to too slow a flow rate will have adverse effects on performance and can lead to premature chain or bar failure.
Recommend that if you are going to store your chainsaw for more than a couple of weeks, drain the bar oil back out if it into a container (strain it through a paper towel before returning to your bar oil can). Also, you really should drain almost all the fuel and then run it until it shuts off if you are storing it for a month or more.
Aug 05, 2009 | Poulan Pro Chain Saw 46cc 20"
Poulan-Pro 295 leaks excessive bar-chain oil
It's a seal somewhere either on the reservoir, or the 'feed' to the bar.
But in the short term, if you must use it, the simplest way of stopping the leak, is to not store it with any oil in it, until you locate the source of the leak.
That should help, but I'll wish you good luck never the less ;)
& plz don't forget to rate, thankyou :)
Jul 18, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
POULAN CHAIN SAW MODEL 1420 ''Chain came off track
Chain is probably stretched. SAFETY FIRST. Electric saw, make sure power is unplugged. Gas saw, make sure sparkplug wire is removed. Remove the cover where the bar is attached to the saw. U should see an adjustment screw for chain tension and one or more bar lockdown screws. Loosen the lockdown screws and turn the tension adjustment screw to permit the bar to slide back toward the motor. Put the chain back in the bar track all the way around. Adjust the tension screw to tighten chain enough you can't pull it out of the track at any spot. Slide the chain by hand at least one complete revolution feeling for any rough spots. If it moves freely, turn the tension screw enough to tighten the chain properly. Correct tension should allow you to pull the chain appx. 1/16 to 1/8 inch from the bar. Tighten the lockdown screws, replace the cover. Rotate chain by hand a couple of revolutions again to check for smoothness again before starting the saw.
Jun 26, 2009 | Poulan 952801953 Electric Chain Saw
Poulan 1630 16" Chain Saw Logo
802 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
