Dell Inkjet 720 Printer
Problem for Dell Inkjet 720 Printer
Can you help me install my dell 720 printer with
By dbowen25 on Oct 01, 2009
Can you help me install my dell 720 printer with the drivers download from dell?
My 720 dell printer installation disk was lost and I have had NO success reinstalling the printer with the drivers download from dell's website.
Best Solution
posted on Oct 01, 2009
Very Helpful)
john_yap
Rank: Guru  Dell StaffDell Staff
Rating: 96%, 57 votes
you can follow these steps:
1.Check if the firewall is blocking any printer services
2.Check what port the printer is using (reenable the bi-directional support) and if it's on online mode
3.Disable all the firewalls
4.Uninstall the printer driver and software
5.Delete any items under the ff keys:
HKLM\System\CurrentControlSet\Control\Print\Environments\Windows NT x86\Drivers\Version-2
HKLM\System\CurrentControlSet\Control\Print\Environments\Windows NT x86\Drivers\Version-3
HKLM\System\CurrentControlSet001\Control\Print\Environments\Windows NT x86\Drivers\Version-2
HKLM\System\CurrentControlSet001\Control\Print\Environments\Windows NT x86\Drivers\Version-3
Optional***
6.Delete any non default items under the ff keys:
Note: ONLY THE NON DEFAULT ITEMS SHOULD BE DELETED
HKLM\System\CurrentControlSet\Control\Print\Monitors
HKLM\System\CurrentControlSet001\Control\Print\Monitors
Default items are as follows:
AppleTalk Printing Devices
BJ Language Monitor
Local Port
PJL Language Monitor
Standard TCP/IP Port
USB Monitor
Windows NT FAx Monitor
7.Delete any items under the ff keys:
HKLM\System\CurrentControlSet\Control\Print\Printers
HKLM\System\CurrentControlSet001\Control\Print\Printers
8.Completely remove drivers by doing the ff: (Option for comm failure because of the upgrade from xp to vista)
Ensure there are no documents in queue.
Disconnect printer’s USB cable.
Click the Start pearl, then click All programs, Printers, Dell xxx (where “xxx” is the printer model number) and then Uninstall. Complete the uninstall utility.
From the start search box type spool and press .
The spool folder located at c:\windows\system32\spool opens.
Rename c:\windows\system32\spool\drivers\w32X86 to c:\windows\system32\spool\drivers\backup.
Rename c:\windows\system32\spool\prtprocs\W32X86 to c:\windows\system32\spool\prtprocs\backup.
9.Restart the computer.
10.Check th services status
Start-Run- Type Services.msc and Click on Open
You will see long list of services
You need to make sure following 4 Services are set to Automatically start
Remote Procedure Call RPC
Remote Procedure Call RPC Locater
LexBce Server
Print Spooler
11.Reinstall the latest printer driver
12. Make sure the driver you downloaded from support.dell.com is compatible with the operating system that you're using, for example windows xp or windows vista.
Was this helpful?
Yes
No
2 people thought this was helpful
Popular Solutions for Dell Inkjet 720 Printer
Questions and Unsolved Problems for Dell Inkjet 720 Printer
Do you recommend Dell Inkjet 720 Printer?
Answer
Answer
I have a HP Compaq laptop that I am having trouble getting the Dell inkjet 720 printer to work. I... (More)
Answer
Cartridges are new, paper feeds and cartridges advance to various ranges as usual when printing, but... (More)
Answer
Cant get my Dell 720 Printer totalk to my SonyLaptop Windows VistA iT SAYS READY BUT WHEN i REQUEST... (More)
Answer
When I print with my Dell Inkjet 720 the page comes out blank with just a few very light lines. My... (More)
Answer
the wheel inside is loose and it will not **** the paper in or the the track with the cartridges... (More)
Describe your Printers problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Printer Experts
Top Printer Repairmen
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(918) 583-5483
Elite printer Services, Inc. is a full service HP...
Elite Printer Services
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
