Question about LG TROMM WM2688H 4.0 cu.ft. Front Loading SteamWasher
Lg troom washer drum is loose and will not spin properly
Yozzer6821
  • 116 Answers
SOURCE: admiral washer lnc6160b71
If you mean the inner drum - remove the agitator, pull off the sofetener cup and remove the 15mm bolt down inside to remove agitator, then secure inner drum to center bearing.
If you mean the outer drum, check the holding down springs visually, remove the front panel by inserting a flat blade approx 4" from each side at the front to release clips, then remove 2 small bolts to remove front panel.
Also check and replace drive belt, tilt machine backwards to gain access underneath.
Posted on Sep 11, 2008
  • 1075 Answers
SOURCE: loose drum on washer
you do not tell me alot about the problem,so im going to hazard a guess; get your drum belt tightened or replaced this will fix your problemhope this helps.adrian
Posted on Feb 18, 2009
agitateme
  • 88 Answers
SOURCE: Washer drains properly after rinse cycle. The
It would help to know what washing machine we're dealing with.....but I'll just assume it's a standard Kenmore(whirlpool) direct drive top loader. If so, you most likely have a broken motor coupler, which is located between the motor and transmission, that's most likely, although you could have a very bad clutch or tranny too. Check the coupler first. Hope that helps.
Posted on Apr 19, 2009
  • 415 Answers
SOURCE: Loose washer drum, load noise on spin cycle
your basket hub is stripped and to gain has a specific tool to remove and not destroy the locking nut for basket the agitor and items need to be removed it may be best to call a tech in your area
Posted on Sep 01, 2009
  • 185 Answers
SOURCE: MY LG TROMM WM2077CW WASHER
you may have stripped teeth on the motor rotor (plastic) to metal drum shaft. this is found behind rear access cover. you will need a #17 socket and breaker bar to remove rotor shaft bolt. if you have a "LE" CODE displayed, you will need a new hall sensor.
Posted on May 16, 2011
Makes noise in spin cycle and now it started smoking. Tub seems to spin more easy but i don't hear anything like a bearing.
LG WM2688H Front Load Washer Smoking power ... - Fixya
www.fixya.com > ... > LG > WM > LG WM2688H Front Load Washer
LG WM2688H Front Load Washer, smoking power related issues. ... is it worth trying to fix drum loud and rattles when on spin cycle, then smoke started pouring out of ...hi working till smoke came out the back and now no power - Unplug it. ... washer makenoise doing spin cycle smell smoke make the power cord warm to ...
LG 4280FR4048L Bearing - AppliancePartsPros.com
www.appliancepartspros.com > ... > Washer > Kenmore Washer Parts
Rating: 5 - ‎189 reviews - ‎$32.19
Burnt rubber smell at end of cycle from 11 yr old lg wm2277hw front load washer i hand spun inner drum it was ... Appliance: LG Washer WM2277HW ... Our LG "Tromm"washer (a.k.a. "Trommy Baby") started making a horrible ... The bearings were worn and made very loud noise in the spin cycle John A. • Punta Gorda, FL.
LG WM2455HW washing machine problem - YouTube
? 10:29
https://www.youtube.com/watch?v=__abhTwmi1I
Sep 15, 2010 - Uploaded by djmcarter
I also have an LG refrigerator, which makes a loud sound (it's the.... I am watching your video while mopping up water underneath the exact same machine right now. ... How to Fix an LG Front load washer machine that wont spin - Duration: 5:32. ...
Jan 19, 2016 | LG WM2277H Front Load Washer
Lg tromm wm1812cw dum makes load noise when spinning
LOUD NOISES IN MACHINE;
LOT OF THINGS TO CHECK, THE BELT LOOSE OR WORN, THE CLUTCH, THE TRANNY, THE BEARINGS BOTH TUB SEAL AND BEARING, THE REAR DRUM BEARING,
THE DRIVE PULLEY- If the washer is making a loud noise the drive pulley might be worn out, cracked, loose or bent. Remove the drive pulley and inspect it carefully. If it is damaged or defective replace it.
THE TRANSMISSION, THE MOTOR COUPLER, THE MOTOR DRIVE BEARINGS,
THE DRIVE MOTOR- If the washer is making a loud noise the drive motor bearings may have worn out. Washer motors are normally almost silent when they run. If the motor is run without a belt hooked up to it and it's loud it will have to be replaced.
Jun 15, 2014 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
My LG troom washing machine de problem
dE fault code, typically means door error, most common repair is to replace door latch assy and check for proper operation.
Nov 05, 2013 | Washing Machines
Wont spin correctly, burning smell
Sounds like the belt is loose and or worn. Take off the back and inspect the belt.
Nov 30, 2011 | LG WM-2277HW Front Load Washer
Ok my LG front loading washer agitates but when it comes to spin it makes a very irritating high grinding noise and does not spin. There is no error displayed but that may be because I stop it before it...
I have a similar problem. The washer was showing error code UE, but would tumble when empty in test mode, but would not spin and made a grinding noise. The bolt that attaches the rotor to the motor was loose and the rotor was spinning on the spindle that rotates the drum. I tightened the bolt, and it spins when empty, but still gives a UE error code when full. Remove the rear cover and check the tightness of the center bolt.
Dec 16, 2010 | LG WM-2277HW Front Load Washer
Front loading LG washer WM0532HW squeeking noise as drum cannot seem to spin with clothes full of water
the belt that spins the drum could be worn out or loose. you can adjust it by moving the tenstioner by moving it an tietening it. you may have to use an apropriate spanner
Aug 15, 2010 | LG Washing Machines
WM1832CW has stopped spinning. Tries to spin but
If the drum is loose it probably means that the bearings at the rear.....OR...The arms that connect the drum to the pulley shaft have broken.....Major job....Sorry.....Nomess
Apr 18, 2010 | LG WM-1832C Front Load Washer
Vibration on 1400 spin
If it does it with no clothes in then :
Drum Loose, Suspension leg shot
Inner drum out of shape
Feb 28, 2010 | LG WM2277H Front Load Washer
Washer drum very loose even when empty. shakes when loaded on high spin. noise also
It sounds like one or more of the shock absorbers is broken or has come loose from its mount.
Feb 20, 2010 | LG WM-2277HW Front Load Washer
Lg troom dle 3777w dryer does not turn on!!!
Sounds like you have 110 volts going to the dryer, you need 220 volts for a dryer to operate normally, check for propper voltage at the back of the dryer where the power cord connects to the terminal block, then if all is good there check at the receptacle on the wall that the dryer is plugged into for correct voltage there, look for bad wire connections, or burnt wire connections or obvious signs that don't appear normal, also don't forget to double check your circuit breaker at your homes electric supply panel. Good luck and Merry Christmas!
Dec 25, 2009 | LG DLE3777 Electric Dryer
Washing Machines Logo
281 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
