Question about NetGear WGR614 54 Mbps Wireless Router - Wireless router - EN, Fast EN, 802.11b, 802.11g
Setup with a 64-bit vista system on a WGR614v9 router
I can't get the disc to start the setup because it keeps telling me that because I have 64-bit vista. Is there a way to install the router without having a 32-bit system?
  • 1,272 Answers
Router works independent to the OS used. You do not require installation CD to configure the router. Follow the steps below to reconfigure the router:
RESET:
At the back of the router you will find a small tiny hole (which says restore to factory default settings). Press the button with the help of a paper clip and hold it down for 30 seconds. After 30 seconds, please release the button and power off the router for 5 seconds then power the router back.
CONNECTIONS:
1. Connect a Ethernet cable from the modem to the WAN port of the router (isolated port).
2. Connect the computer to the router using any one of the 4 available ports. Please make sure that there is no direct connection between the modem and the computer (either using Ethernet cable or USB cable).
3. Power off the modem and the router after making the connections.
4. Power on the modem and wait for the lights, then power on the router.
RECONFIGURE:
1. Open the browser (Internet Explorer, Mozilla Firefox or Safari).
2. Access the router, usually with http://192.168.1.1 or http://www.routerlogin.com.
3. Login to the router with the Username as "admin" and Password as "password" (please note that the Username and Password are case sensitive).
4. Click on 'Basic settings' from the left menu and select 'Use Computers MAC Address' from 'router MAC Address' section.
5. Click Apply.
6. Once it updates the settings then power off the modem and the router. Power on the modem and wait for the lights, then power on the router.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Posted on Oct 02, 2009
  • hollywooddee Oct 11, 2010
    I found lots of solutions on the internet, all of which left out key points. Your post is very comprehensive and I was up and running in no time! I originally called Netgear because I purchased a new computer and the router software was not compatible with a 64bit computer. Netgear wanted $100 for their support and never mentioned at any time that I didn't even need the software. Thank you so much!
  • 30 Answers
Its so simple configuring your router.just run the initial setup after getting into routers page
192.168.1.1
admin
password
I keep getting setup error which says You cannot install the 64 bit version of Office 2010 because you have 32-bit Office products installed. These 32-bit products are not supported iwht 64-bit insta
If you have downloaded it as a free trial, go to the office page and get the office for your system.
Remember to check what system is yours: Start/Computer/View System properties/information/32/64 bit system.
Apr 14, 2013 | Microsoft Office Professional 2007 Full...
How do we find the WEP key for my WGR614v9
Configuring WEP:
  1. Use an ethernet cable to connect a computer to any one of the four LAN ports of the NETGEAR router.
  2. In a web browser, enter the router's IP address - either http://192.168.0.1 or http://192.168.1.1 by default.
  3. When prompted for a Username and Password, enter the default username and password (admin; password) unless you have already changed it. NETGEAR recommends changing the default password to increase the security of your network.
  4. Select Wireless Settings from the Setup menu in the left-hand navigation bar. n101675_image001.jpg
  5. Under Security Options, select WEP (Wired Equivalent Privacy).
  6. From Security Encryption (WEP) > Authentication Type, select Automatic.
  7. From Security Encryption (WEP) > Encryption Strength, select 64-bit or 128-bit. NOTE: You will need to configure your wireless computers with the same setting.
  8. From Security Encryption (WEP) Key, select Key 1 and enter a key.
    • Note: WEP keys are entered in hexadecimal digits, which are any combination of 0-9, A-F.
      • If you selected 64-bit under Security Encryption (WEP) > Encryption Strength, then enter 10 hexadecimal digits for your key.
      • If you selected 128-bit under Security Encryption (WEP) > Encryption Strength, then enter 26 hexadecimal digits for your key.
    • SAVE or KEEP NOTE of these values - they will be required to connect wirelessly to your network.
  9. Click Apply to save the settings.
Feb 21, 2011 | NetGear WGR614 Wireless Router
Trying to connect netgear wgr614v9 router to new toshiba computer with windows 7 ....setup says unsupported operating system....what do I do
As netgear setup disc doesnot support Win 7.
U need to manually setup the netgear product
-- hard resett the router using a restore factory setting hole on the back of the router
-- open the netgear router page using www.routerlogin.com
-- Username - admin , Password - password
-- run setup wizard
-- if it detects dynamic ip then press next
-- and on the left u will see wireless settings under setup .
-- secure the network using WPA_PSK(TKIP)
-- and then apply .
In case if it will detect static or fixed ip .
Then click on " Basic settings "
-- Under router MAC address
-- select "use computers MAC adress "
-- Apply
-- And then Powercycle the network..
-- And u will be able to go online ..
Jan 02, 2010 | NetGear WGR614 Wireless Router
Can't get the setup disk to setup. Says
No you just need a Vista 64bit driver. Try this download:
http://kb.netgear.com/app/answers/detail/a_id/784
Oct 04, 2009 | NetGear WGR614 Wireless Router
Netgear wnr2000
You should not need any software to connect to the router. Use connection wizard in VIsta to setup the internet connection
Aug 16, 2009 | NetGear RP614 Router
New computer with Vista operating system
You can download the setup wizard here:
http://www.linksysbycisco.com/US/en/support/WRT54GX2/download
Mar 24, 2009 | Linksys WRT54GX2 Wireless-G Broadband...
I can't to install Windows vista 64 bit within a 32 bit
hi,
If you have a 32-bit version of Windows XP and want to install a 64-bit version of Windows Vista, you must boot the computer from the 64-bit Windows Vista DVD and then perform a custom installation of Windows Vista. Back up data before you start the custom installation.
Dec 16, 2008 | Toshiba Satellite A215-S7422 Notebook
NetGear WGR614 54 Mbps Wireless Router - Wireless router - EN, Fast EN, 802.11b, 802.11g Logo
1,600 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
