Question about Intel D845HV (735858149143) Motherboard
3 beeps no mouse keyboard display - Intel D845HV (735858149143) Motherboard
  • 4,281 Answers
For that open cpu cabinet .Refix RAM memory .Also clean dust from all parts of motherbord.
Refix processor and it's fan.
Remove PCI card from PCI slot.
Also pull cmos cell from motherbord for 10 minutes so all settings are defaults.
Let me know if you need more assistance.
Thanks.
Posted on Oct 01, 2009
Optiplex 330 beeps 6 times, no display
It could be that either the graphics card or the memory modules may need to be re-seated. Those would be the first things to try.
May 25, 2012 | Dell Optiplex 330 Desktop Computer Pentium...
My Dell Inspiron does not boot up only the solid amber light on the Motherboard on I try everything and still nothing works please help
Not so sure about this but I hope this will help.
-try to disconnect all the cables from the back (monitor, keyboard, mouse, usb's, power cable, etc.)
-then disconnect all the card (video card, sound card, NIC) if all are integrated then you dont have to.
-connect just the power cable
-try to turn on the computer and check if it beeps
-if it does not beeps need to replace the motherboard but before you do this check if the fan will spin even for a single second if does not spin then you also need to replace the power supply as well
-if it beeps then turn it off again.
-connect the video card and connect the cable of the monitor, keyboard and mouse
-turn on the computer then check if theres any display
-if theres no display check for any beep indication. and right it down on a piece of paper on how many times it beeps and if its long beep or short beep.
kindly provide an email if this things does not work so that I can give you a resolution.
Apr 01, 2011 | Dell Inspiron 530 Desktop Computer
Intel d 865 gsa mother board is working but not display no beep what is the problem
i thinks it's not working, check again.....
no display, no beep.....simple symptom of a dead MB
the quality of the MB is all components will work together, even if one component in it fails the MB is dead.....
this rule is not applicable to the following devices in the MB
inbuilt sound cards, or
either of the USB ports or
mouse port, keyboard port
As you can use an external device like a USB sound adaptor insted of the internal sound card for your speaker/sound.
The same goes for mouse and keyboard, you can buy keyboards/mouse that work thru USB
The same is of a USB port, if one of the USB ports fail you have the other ports to use, if all of the USB ports fail then you can use a external USB connector to a LAN port and make the LAN port a USB device.
also.....there is no option..... that you can change one of the components.....they all are embeded in the circuit board, it's cost effective to get a new MB than repair the defective component.....
all the best
Nov 18, 2010 | Intel Motherboard
My Computer Beeping when star-up. The Beeping sound is continue such as Beep...Bee...Beep...Beep..until I force it by pressing the start up button to stop it total. I think due to the new mouse and...
Beeps always indicate error excluding a one single beep only which indicate process.Every manufacturer has its own beep setting. it comprises on short and long beeps. If previously it working good, then your idea may be correct. replace both the keyboard and mouse with existing. start computer if now it not giving beeps it meant that one of them is causing problem. connect one by one and start computer you will reach. AND if even after replacing keyboard and mouse it gave beeps then shut down your system. Open casing remove processor and memory chip out and connect them again it will work now INSHALLAH.
Sep 24, 2010 | Computers & Internet
Am5640 with blue light on, fan, cdr and hdd speens but not display, mouse and keyboard. I checked PS, all tensions are there, new RAM anD HDD. need help, please.
remove ram then switch on pc if u hear rappid beeps then ur motherboard is ok !. if not reset BIOS and on it. if beep comes ur ram is not working properly .
Jun 24, 2010 | Computers & Internet
My mouse works, but whenever I hit any key on the keyboard, the computer just beeps.
Check that the PS/2 keyboard is *NOT* plugged-in to the PS/2 "mouse" port on your computer.
Or, borrow a keyboard, and see if that keyboard is "beep-free".
Nov 27, 2009 | Logitech S520 Mouse
Computer beeps when first turning on
If your computer is still under warranty, the company should replace them. If not, you can buy them really cheap.
Or you could just return the computer. This is what I would do, because it might not be the mouse/keyboard that is causing this. It could be that you just have a bad motherboard.
May 20, 2008 | Compaq Presario 5000 PC Desktop
Continuous beeping sound
you can see out put in screen if no you must chek ram's
else you should remove your keyboard and mouse in test ather
Dec 16, 2007 | Packard Bell iMedia SL 9553 (P660401806)...
Keyboard and mouse problem!
I've had this problem happen lots of times before. usually restarting the PC with the switch enabled to the PC that is booting will solve this problem. For some reason, sometimes the drivers don't load for the mouse and keyboard when starting up the PC.
Dec 16, 2006 | D-Link (DKVM4K) (dkvm-4k) 4-port KVM...
Intel D845HV (735858149143) Motherboard Logo
97 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
