Question about Dell Latitude C400 Notebook
Internet card Hi my c400 stopped detecting any card I incert in the ethernet port. Is there a test I can run? or do I have a missing driver or something? Any help would be wonderful.
  • 2 more comments
  • tonyarenee Dec 20, 2007
    it's actually not the card because nothing works in the port. no device detected.
    I am refering to connecting a PCI card thin metal rectangular box into a PCI slot on a laptop. I use it for wireless Gcard or GSM card and a card the has a 2 highspeed USB ports on it. None of them respond.
    Windows Xp. It is more than one card...I have tried four differant kinds of hardware in there. I believe its the port it's self.
  • tonyarenee Dec 22, 2007
    Worked! I went to the site like you said and did some downloads. works great thank you.
  • 556 Answers
Please excuse starting with the basics but I cannot see what is happening on your end and am limited in my understanding to what you say here.
First, generally ethernet ports are used to connect a cable for communication between ethernet devices with a similar connectors generally network adapter in a computer to a switch or hub (which may be part of a router) or directly to a single ethernet port in a cable or DSL Modem/Bridge or other compatible device. This cable is thicker in diameter that a phone wire and the connectors at the ends are wider than a phone wire with 8 connection points instead of 4 of which only 2 may be used in a phone wire.
Is this what you refer to when you indicate you are connecting a card to an ethernet port?
are you connecting a PCI card thin metal rectangular box into a PCI slot on a laptop?
are you inserting a memory card into the slot of a reader?
are you inside a desktop computer case inserting a card into a slot inside your computer?
Given the explanation of the above -- after you perform this action what doesn't work that you would expect to work?
All of the above (excluding the memory card (but it's reader could)) could have driver issues associated with them.
A PCI card insertion into a slot where it had been previously configured would not necessarily generate another detection and addition of hardware prompts as the drivers may well be configured and ready for reinsertion of the PCI card into the same slot from an earlier configuration.
Please respond with as many answers to the above that you understand and I will attempt to provide next steps for the resolution.
Posted on Dec 20, 2007
  • david Dec 20, 2007
    OK good so far. This PCI card you are inserting does it have a manufacturer and model number on it somewhere. And what operating systen is your computer running? This may be as you suggested a missing driver.
    Use the following link
    Enter the service tag off of your machine assure OS is Win XP of change it, if possible -- this will make the list specfic to your hardware.
    Under communications there are numerous GPRS downloads that may be needed. Note relation to PCI.
    If you use the following you may get some drivers that will not install on your machine because the list was not tailored to your hardware.
    If you do not have service tag or cannot change OS try this link
  • 482 Answers
You can call the provider where you got the card and they can tell you where to go on the net to download the program that connects it. Its free if you can find out what the card reads or what kind it is.
I cant install my router. The internet, power, WLAN, and DMZ lights are all on, but none of the Ethernet port lights are on, but when I try to complete the install I get the following error message: Unable...
If the ethernet light is not coming that means your router is not detecting your computer. Try to plug the computer on any other port.
To check if your ethernet ports are fine you can perform a loop back test. You can take a cable which is not connected to anything. Than put one end of the cable to one ethernet port and put other end of that same cable to any other ethernet port. If the light on the ethernet ports led up means your ports are fine and u need to reinsatll the drivers of the ethernet card on your computer. Else your routers ethernet port are not functioning. If that is the case you can try to reset the router.
Let me know your finding.
**If this works please rate else let me know in case of further help.**
Jul 03, 2010 | Linksys Wireless-G WRT54G Router
I recently had my hp pavillion dv 2000 with windows 2000 crash and it has been repaired but I am unable to connect to the internet. Turns out after a check I am missing my Ethernet card what can i do...
I the Ethernet card removed complete from your system or you mean to say your system do not detect your Ethernet card.
If the system do not detect your Ethernet card, then it is more of drivers related issues.
Re-install the drivers of your Ethernet card and try to connect.
This should solve your issue.
If there is no Ethernet card in laptop. Then, get one, install drivers for the same.. and try to connect. It will work.
Nov 04, 2009 | HP Pavilion dv2000t Notebook
I canot connect to the internet using a broadband some devices are missing, for example the ethernet controller, PCI device, PCI modem...
Hello Friend,
Since the ethernet controller is not installed that means the Ethernet card is not installed and you will not be able to connect via ethernet port. Also if you have wireless, you should install it first to be able to connect wirelessly.
You can try this software "Driverupdaterpro":
it scans your computer and detect your hardware and give you the best drivers to use.
Best Regards,
Oct 30, 2009 | Acer Aspire M3200 19" 2.5GHz Athlon X2...
Ethernet/lan missing so i can not connect to the internet
Download and install the driver from the manufacturers website. Use an external hard drive or flash drive to download from internet (working computer) and install from there.
Oct 03, 2009 | Foxconn 915P7AC-8KS Motherboard
Ethernet port not "active"
Hi there.
Restart the PC and go into the bios to make sure the on-board LAN is enabled, if it is try as jery says and try another ethernet cable.
Post back please and good luck
Apr 21, 2009 | Dell Latitude C400 Notebook
Ethernet port on laptop does not detect wire
That message always comes up if you have the driver loaded for the ethernet port but no cable connected to it. If you are not actually using the port, don't worry about it. Everything is fine.
Mar 04, 2009 | HP Pavilion dv6000z Notebook
Latitude c400 no longer detects internal wireless card
device driver's are different from one operation system to need to find the driver for the current operating system...
Sep 06, 2008 | Dell Latitude C400 Notebook
Network card
  • Click Here
  • Select your OS
  • And then you can download all the drivers including LAN
Apr 23, 2008 | Intel D845GRG Motherboard
The ethernet port is not working, and the network card is not being detected in device manager
My system Network adapter is not working. so i checked another one external card connect , at the time internal card automatically worked? how ? pls tell me i am very confuse
Feb 10, 2008 | HP Pavilion dv6000z Notebook
Dell Latitude C400 Notebook Logo
113 people viewed this question
Alun Cox
