Question about SmartDisk FireLite 40 GB Hard Drive
SmartDisk FireLite 40 GB Hard Drive makes a clicking sound..
Firelite external HD 40gig makes a clicking sound when firewire is pluged into mac. The HD will not load in finder either.
    New Friend:
  • 21 Answers
You will need to recover the data using something like this data recovery program.
http://www.asoftech.com/adr/
I've had to use it many times in the past but in this case you need to take out the hard drive from mac and put it into a Windows computer as an external drive or slave drive and run the software from there. It will rebuild the drive and hopefully recover the files.
Good luck.
Posted on Dec 05, 2012
    Scholar:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 27 Answers
The clicking sound is called 'the sound of death'.So your hard drive is probably dead.However there are still hopes for hard drive data recovery.
Put the hard drive in a plastic bag to be compatible for the freezer. Freezing sometimes works to revive a dying hard drive, at least for a short time(Probable just about 20 minutes), but be sure that the bag is sealed tightly so that condensation and ice crystals don't form. Put it in your freezer for 24 hours that will do the trick. While it's still cold, plug it into your computer.And you may be able to view it in 'my computer'. And you may act quickly,because you may only have 20 minutes to recover your data off it and after that the hard drive is completely dead.
If it fails, you will have to go to a recovery office where supply data recovery service but let's hope not because it will cost you a lot of money and whether they can recover data is not guaranteed.
Here is a tutorial to guide you how to recover data from hard drive.
http://www.any-data-recovery.com/recover-data-from-hard-drive.htm
Posted on Jun 15, 2012
  • 32,281 Answers
A hard drive that makes a clicking noise is faulty.
It cannot be fixed, you only can replace it.
If you need the data on the hard drive, it is gone. There are companies that can recover data from faulty hard disks BUT it will cost you an arm and a leg for their services.
Posted on Oct 01, 2009
I have firelite external and it's not working. There's light but no spinning sound. what can I do?
This a firewire drive and needs to plugged into a firewire port to spin up. If you do not have a firewire port on your computer (most PC's don't) it will not work. I don't believe a firewire to USB connector will pass enough power to the drive to spin it up.
Mar 12, 2012 | SmartDisk FireLite 60 GB Hard Drive
Reconfigure firelite for PC
you will need to reformat the drive. it sounds like it was just formatted for MAC only.
to do this open computer management and select disk management under storage. select the firelite drive and click format. please note these are settings for windows 7.
Feb 13, 2012 | SmartDisk FireLite 40 GB Hard Drive
How do I reformat my smartdisk firelite external hard drive for my new mac?
Go to the applications folder and then utilities open Disk Utility in the left box select you firelite and then clcik on the erase tab to your right. You can then select how you are going to format the hard drive standard for using with Mac only machines is Mac OS Extended (Journaled) or if you want to use with both PC and Macs is MS-DOS (FAT). Then name your drive and click on erase. Hope this helps.
Feb 01, 2011 | SmartDisk FireLite 80 GB Hard Drive
I'm having problems connecting FireLite portable hard drives to my mc.
1. Check operating system version sometimes its just the version not all mac versions like externals.
2. Under disk manager if the drive does not appear 9 times out of 10 its not compatable with the os your using.
Thanks
Sep 17, 2009 | SmartDisk 160GB FIRELITE PORTABLE FIREWIRE...
Smartdisk Firelite 120 GB wont delete
Try to reformat the external hd thru the disk utility.
Sep 03, 2009 | SmartDisk FireLite USBFLB120 120 GB USB...
Computer not recognizing external HD
1st try a different computers make sure its not your Hard drive!
2nd if that works then go to the hard drive maker and download a software driver for it that should fix the problem
Aug 10, 2009 | SmartDisk FireLite 40 GB Hard Drive
Firelite 60gb external hd
to clear all the unused data from your computer you need to do to things Disk defrag and Disk cleanup located
Programs> Accessories> System Tools if this is a externul drive with no Os on it Rigth click on the device icon select Format this will to erase Data bypassing your desk top bin
Jun 24, 2008 | SmartDisk 160GB FIRELITE PORTABLE FIREWIRE...
Formatted hard disk on pc now it won't run on mac
Try plugging your hard drive into your mac, open "Disk Utility" select your hard drive in the list on the side, Click RAID, change the Volume Format to MS-DOS (FAT), and it should work.
Hope this helps!
Apr 03, 2008 | SmartDisk 160GB FIRELITE PORTABLE FIREWIRE...
External hard drive
Check your device manager for any errors or conflicts.
Dec 16, 2007 | SmartDisk FireLite 40 GB Hard Drive
Smartdisk firelite
please use a recovery program for mac and then once all files are recovered then repartion hdd in disk utility then copy back all files to hard drive or change your external drive as you are the fourth person to have this problem with firelite hard drive for the mac sounds like a compatabilly issue with mac os systems
Jun 01, 2007 | SmartDisk FireLite 40 GB Hard Drive
SmartDisk FireLite 40 GB Hard Drive Logo
310 people viewed this question
Top SmartDisk Computers & Internet Experts
Sunday Ojelabi
Sunday Ojelabi
 Ian Kayhan
Ian Kayhan
Are you a SmartDisk Computer and Internet Expert? Answer questions, earn points and help others
