Question about Kidde Home Security
Low battery warning, how do i stop it as it is now the middle of the night and I can't go to a store till next morning?
  • 250 Answers
Remove the battery. If it has a low battery because it have no online power, restore that power. If it has online power and stills complains about not having a battery, cut power to it. If there's a silence or clear button, try that. If it's a monitored system, the company may be able to silence it for you.
Posted on Oct 01, 2009
My perguote 208year will not start until 34 turn over have to put foot on excelarater in mornings to start after that no probplem start right away till next morning same problem.
get ignition coil checked. If it is EFI DO NOT press on Accelerator when starting it.
Could have a leak in fuel and it evaporates over night
if carby fuel may be leaking out over night as vapour. In mornng you are fuel pump refilling fuel into carby until it starts again.
Mar 12, 2016 | Cars & Trucks
Crank sensor
During the night or after the car sets for a while. The battery voltage will drop from the normal 13.6 to 13.8 volts when running and Charging, to between 12.3 to 12.6 volts. If the Crank Sensor is going bad, it may not operate correctly with the lower voltage. Check your Battery Voltage in the morning with a Volt Meter. If the Battery Voltage is lower than about 12.3 to 12.5 volts. You may need a new battery. Try leaving the battery on a low current Battery Maintainer overnight and see if it starts in the morning. I have seen many cars that shut down with Low Battery Voltage. Darn these New Fangled Cars and their Computers! FYI, we have never seen a Crank Sensor fail in this manner..... Check the RESTING Battery Voltage.
Aug 17, 2014 | 2001 Dodge Stratus
1999 dodge dakota sport 3.9 v-6 just stops running while driving?
Probably some sensor is failing. Have your engine codes scanned. many auto part stores will scan your vehicle codes.
Jul 23, 2014 | 1999 Dodge Dakota
2005 chrysler 300 limited needs jumping every morning now cause it wont fire up...rke battery is low
One of the many low drain "always on" circuits is drawing too much current, taking the battery down at night. Security and memory functions are likely candidates. You are going to have to get this diagnosed as it will never fix itself. The poor man's way to fix it is to pull out one fuse at a time every evening when you come home. Eventually you will remove a fuse and find that the car starts the next morning as it should, without a jump. That means you have identified the circuit the bad component is on and you make a choice as to get it fixed or live without it.
May 03, 2011 | 2005 Chrysler 300
Battery not charging message. Took battery to have tested was told battery good. I charge battery every night and starts next morning last about 10-15 mins driving. I am not getting service 4wheel drive...
Most likely you have a bad alternator. The alternator maintains the the charging system. you have the option to remove the alternator and take it to the parts store and have it tested too!.
Feb 04, 2011 | 2003 GMC Yukon XL
I can't turn my olympus digital voice recorder WS-450S on, even with a new battery, i hadn't used it in a while, so i was shocked that it didn't work. It only turns on if i plug it in to the computer, but...
I've got this same problem :( Turns on when I plug it in to the USB, stays on when I disconnect it but if I turn it off I can't turn it back on again. It is showing a "battery low" warning and I tried to charge it via the USB last night, but it seems to stop charging after a while and despite being left for a good time last night, this morning it is the same and I've had another battery low warning.
I've just found the full pdf manual online, and have found (on page 80) a reference to it not always behaving stably when connected via a USB hub. I'm going to try to charge it via a direct port and see if that fixes it.
Oct 17, 2010 | Olympus WS-100 Digital Voice Recorder
Env Touch backlight stays on
go to your settings choose backlight and turn it off
Sep 16, 2009 | LG enV Touch VX11000 Cell Phone
Crappy battery length
One replace the battery.
2 when you get your new battery for the first time charge it for almost 24/hrs
over the next week use it till its almost dead then charge it at night from about 10 or 11 at night till you wake up the next morning. You may have killed you battery by not doing this in the first place.
Mar 19, 2009 | HTC Touch Diamond Smartphone
Home Security Logo
510 people viewed this question
Top Kidde Home Security Experts
john h
Are you a Kidde Home Security Expert? Answer questions, earn points and help others
