Question about Samsung LE26R72B 26 in. HD-Ready LCD Television
No Signal On D/TV
Hey i have a similar tv to yours and we are having the same problem. DTV has worked fine since day 1 of installation of the TV. However now they have started to mess about with the retune we cannot even get a single channel. I searched through with auto tune a few times and nothing comes up or about 48 services are discovered but when scanning is complete i go onto the channel manager which informs me there is no channels. So i went into the signal info and its says 0% Signal with a 10 BIT error length. Now obviously it isnt my tv thats broken because yours is the same aswell and it isnt the ariel because i can run a freeview box of the same ariel. So the only things left are the freeview inbuilt into the tv or the signal itself. Personnaly i think its an issue with the in built freeview that needs fixing there maybe a firmware update from samsung soon but i wouldnt hold my breath tbh samsung are pretty bad when it comes to firmware and updates.
    President:
  • 1,653 Answers
You may lose some channels when you retune the TV as the channels have been rearranged. To locate them look at the EPG although you may still find that some channels are no longer available on FREEVIEW. See the following link for additional information
http://www.freeview.co.uk/_retuneinfo/
If the above process does not work then check the link above for additional information and also visit the accompanying site links below to find more information for your model of TV / FREEVIEW box.
For troubleshooting the retune procedure visit http://tvretune.co.uk/troubleshooting/
For specific model information visit http://tvretune.co.uk/productmanuals/
Posted on Oct 03, 2009
I cant get a singal for my antnna
Tv does work for HD but must have cable or satellite tv signal.Yes,this tv able to play HD signal,but it is a CRT-(tube tv) design was built before the DTV switch over and never added the DTV tuner in it board circuitries.Sorry antena free DTV this tv must have to added the converter box to get the DTV free air signal.
Feb 17, 2011 | RCA P61310 TV
How can I move a receiver to another room that has . For example, downstairs i have my two receivers with 1 DVR that controls 2 TVs the one downstairsTV#1, and 1 upstairs TV#2. The other dish, controls TV...
Hey there! Becki Barned from Dish Network customer service here!!! If you want to do this! You would need a tech to come out and install the DVRs in the new rooms. If you try to move the reveivers, you will only get an Acquiring Satellite Signal message. If this has not been resolved, you can find us on Twitter, or blog back!
Nov 28, 2010 | DISH Network 311 2-Room System DTV...
I have a 32" flat panel. Am only receiving one local TV station channel at this time. All other channels show "No Signal". We hooked another TV to the cable and it works fine. What could the problem...
The tv is good,just some LCD tvs some models require a very strong broadcasting signal to get a picture.U getting a free DTV air broadcasting signal wright?Tries getting a roof antena or a digital design antena.Tries this tv out again,will get all the DTV free air broadcasting signal.Should not get anymore "No Signal" result.
Oct 13, 2010 | Polaroid FLM-3201 Television
I change the tv # 2 and now I can't get to set the signal
Hey! My name is Becki Barned, and I am with Dish Network customer service! You have already gotten this issue resolved, but here are some steps in case you haven't! On tv2, try channel 60 and then 73. if that doesn't work, try to go to tv#1, press menu 6-1-5. Here, change (under tv2 out) the MODE setting from AIR (if it is on air) to CABLE, and vise versa. If the tv cannot go up past 69, make sure that the MODE is set to AIR. That's changing the setting for the TV#2, and with a new tv, this will usually fix it! Blog if any troubles!
Aug 21, 2010 | DISH Network 322 DTV Receiver
Toshiba 46HM95 wont display 720p from dtv antenna other tv works
lets start with the easiest first.does your tv in the menu option offer an input output source like 720p or 480p?on my set i can change to any format.maybe yours does too.let me know and we go from there.
Mar 04, 2010 | Toshiba 42H81 42" Rear Projection...
Digital Signal on my Conia TV has gone. Cant access menu for DTV
I would guess that you are using either cable or satellite for reception. If that is the case, the signal is already a "digital" one. The digital reception you are attempting to receive is the over-air broadcast signal that was implemented recently. This change-over only effected those using external antenna connections. Cable and satelite systems have not changed.
Hope this helps,
Dan
Jun 18, 2009 | Televison & Video
DTV signal will not come up on start up but after warm up
Was just the DTV card replaced only or the mainboard? Replacing the entire mainboard should do the trick.
May 22, 2009 | Vizio L32 32 in. LCD HDTV
No video output from Magnavox VCR (MDV560VR)
You need to tune a chanel on your tv to the vcr signal, using an RF cable (aerial cable between vcr and tv). That is if your tv has an analogue tuner.
May 09, 2009 | Philips Magnavox DVD/VCR Dual Player
Re: 322 DTV Receiver - snowy screen on tv 2
Lets check the modulator set up at the main location TV 1. Press menu - 6-1-5 this will display how the TV 2 IS SET UP. It should say 22 air and if not use the arrow keys on the remote to change that info. Once you are done click done and go to the TV2 and see if it is working. It should be if you are set to view air or antenna channels on the TV2. If not there needs to be a few more things done to isolate the issue. Let me know and we will go from there. Thhanks for using Fix Ya.
Apr 11, 2009 | DISH Network 322 DTV Receiver
On-screen Menu
Actually, it is not a Projection TV Problem. The problem is with a Mintek DTV-265 26" flat screen digital TV (not projection). I have not yet resolved the problem by unplugging the set, pressing the eject button and replugging in the set nor have I had any other suggetions. The manual clearly indicates Mintek DTV-265 26" (not Mintek DTV-263) but I feel they are very similar; however, the manual does not mention losing/restoring the on screen menu.
Feb 28, 2008 | Mintek DTV-263 26 in. LCD Television
Samsung LE26R72B 26 in. HD-Ready LCD Television Logo
621 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
