I'll bet the machine uses a belt drive, and the belt is probably worn, slipping, and chipped. The slipping makes it hot which makes the burning smell, and the rattling is the spring-loaded tensioner pulley banging against its limit because it hits the damaged part of the belt every time it comes around. Before you look anywhere for a new belt, take my advice and look in an autoparts store first. We went everywhere to find a belt for my friend's machine, which was expensive and would have to be ordered, then we got one at autozone for $5. You can probably just take off the front of the machine to open it but you might have to move or disconnect the motor from the machine to get the belt free.
The water pump has cloth built up inside causing the impeller to shift. The shim that holds the pulley on to slipped and was causing rattling until it eventually jammed up completely. I removed the water pump cleaned the inside out and realigned the impeller and pulley assy. no parts needed.
SOURCE: washing machine making loud rattling noises and
Your washing machine has a belt on a pulley and that belt is being stretched. That belt is attached to a motor that turns your laundry tub. Your washer if out of balance will shake and rattle and the tub might be locked in place and the motor is forcing the belt to turn but the tub is not turning. If you are not mechanically inclined call a washer service repair man.
Hello Todd, thank you for your post!
From my understanding your Frigidaire washer made a loud noise then stopped working and you also smelled burning rubber. This could be a possible issue with your moto, belt, or pulley. I would recommend contacting a professional technician for proper diagnosis and repair. Since it could be anyone of these underlying issues a technician would be able to pinpoint the problem without multiple part purchases. A technician will have the appropriate tools needed to verify which component may need to be replaced. Hopefully this information is helpful to you. -Matt
