Question about RTO Alternator/Battery Tester
New battery went flat - RTO Alternator/Battery Tester
    Brigadier General:
  • 4,090 Answers
You have not provided much information to base a diagnosis.
My battery went flat !
What was connected to it, was it charged and then connected to some unit and went flat or went flat after charging, by itself?
If its new and was unconnected after charging return it to the seller for an exchange.
If it was connected to an vehicle or some other object and just went flat then you have a short circuit somewhere .
Plwase use the rating for our help++++Thank's for using FIXYA
Posted on Oct 01, 2009
  • 250 Answers
The battery was running the car's electrical system but not getting charged when the engine was running, indicating a problem with the alternator or charging circuitry.
Battery went flat radio wont work now.how do i get code?
Search Results
    Car Radio Stopped Working after the Battery Died
    cartech.about.com > ... > Car Radio Components FAQs, and More
    First your battery went dead, and now your car stereo is dead, and it's really ... or charge, and you're lucky, then you may find that your car radio fuse is blown.
    radio won't work after new battery installed - Car Talk
    community.cartalk.com/.../radio-wont-work-after-new-battery-installed
    Nov 30, 2011 - Today the dealership did a tuneup, replaced the timing belt, and put in a new battery. I started my car and the radio did not work. They went out ...
    Another Flat Battery - Radio No Longer Works - Hyundai Forums ...
    www.hyundai-forums.com/.../128744-another-flat-battery-radio-no-long...
    Jul 18, 2011 - Also now the battery has been recharged the redio will not work. .... Mybattery went flat, took it out and went to a battery shop who charged it up ...
    Dead battery..now radio won't work - Honda CR-V Owners Club
Dec 09, 2015 | Cars & Trucks
How do I stop the hazard lights randomly coming on while driving
Maybe you need a new battery
Did you have it tested
Do you know how old it is
or how many times it went flat
Aug 16, 2014 | 1994 Hyundai Excel
Battery keeps going flat
Check alternator voltage output, might be low. obd2 scanner
Jun 12, 2013 | Cars & Trucks
Mitsubishi lancer battery keeps going flat is there any common cause for this? brand new battery went flat within 2 days
Interior light or inside hood light. Sometimes an alternator can short inside and drain a battery. A pinched wire touching a ground.
Feb 07, 2011 | Mitsubishi Lancer Cars & Trucks
The battery on my 2000 Porsche Boxster is dead and the car is locked. How do I access the interior to release the hood?
The easiest way is to buy a cheap battery charger, one that plugs into your cigarette lighter socket. Allow the battery to charge for a few hours and then release the trunk when it has come up enough. The most likely reason for your battery going down is a faulty alternator. I just went through this problem with a friend. He bought a new battery and it went flat over night. He replaced the ignition switch (common problem), still went flat over night. Even though the alternator was charging great when the car was running, it was drawing current when the car was parked. We ended up getting a brand new alternator off ebay for $135., the dealer wanted $1900., local parts stores about $500.
The alternator was pretty easy to install and it solved the problem.
Jan 23, 2011 | 2000 Porsche Boxster
Car won't start. Replaced battery. worked 3 days. They said it was the alternator. REplaced with new. worked another 4 days. had it check with advance auto said battery good, starter cranking normal....
if there is no charging then its back to the alternator or the way its hooked up? did you recharge your flat battery with a mains charger after it went flat the first time? as no alternator will charge a battery from flat to fully charged,,,,even if you drove around the world none stop! the new alternator may have given up working becouse you overloaded the voltage regulator trying to recharge a flat battery witch would mean it was very week to start with?
Nov 15, 2009 | Pontiac GTO Cars & Trucks
Short battery life
Use the best name brand batteries you can find. Energizers and Duracell work best. Chance the size of your pictures to the smallest you can. At 300 X 300, you can still make 8 X 10 enlargements clearly. The larger the pic, the more power it takes to process it.
Aug 09, 2009 | Canon PowerShot A570 IS Digital Camera
Car used 2 days ago fine. Went to start today and the remote only opened the driver door. Put key in ignition and hazards went off then made a clicking noise when tried to turn over and the lights on the...
Yes, this sounds like a flat battery. You could try to get a jump start off someone else, so that you know it is definately not the engine. Otherwise, purchase a new battery and you should be fine.
Jul 25, 2009 | 1999 BMW 328 Series
Battery going flat on car daewoo leganza 1997
hi for a battery to go flat means your altenator isn't doing its job in charging it. all cars are different but it has to charge at a certain rate in order to keep it going. if the charge rate is very low then yes the battery wont last. if alternator is ok then possibly a wirring fault somewhere.
Dec 23, 2008 | Daewoo Leganza Cars & Trucks
RTO Alternator/Battery Tester Logo
139 people viewed this question
Top RTO Measuring Tools & Sensors Experts
jdthefixer
Steve
Tim Venetis
Are you a RTO Measuring Tool and Sensor Expert? Answer questions, earn points and help others
