Question about Sharp AR-M205 Copier
ERROR L6 the indicator light L and 6 is flashing and the copier will not operate on a AR-205,i press and hold down the Start key and let it flash through the fault sequence, it show 10
    Scholar:
  • 118 Answers
An L6-10 code is a polygon motor failure in the copier's laser unit. It's what flashes the image to the system drum. If it won't clear after shutting down/unplugging the unit for 30+ seconds then the laser unit (the LSU) needs to be replaced. You'll need to contact a trained Sharp service representative to facilitate the repair.
Posted on Oct 01, 2009
What is the pairing security code for xx3 plantronics
The following are detail instructions on how to Pair (sync) a Plantronics Bluetooth Headset to your Bluetooth Cell Phone:
1 - You need to go into the device you wish to pair it and turn the Bluetooth feature first.
2 - Then you need to place the headset in pairing mode so your phone will find it.
Find your model headset in the instructions below. Once the headset is in "Pairing" mode you will then need to follow the instructions in your cell phone or Bluetooth device's user guide on how to go it to your phone and search for the headset & pair it to a Bluetooth headset.
The passkey is 0000 (4 Zeros) except models M1000 and M1500 (see below for their number )
For the Plantronics M3000/M3500 (discontinued):
Pressing and holding down the volume up key and the talk button at the same time. Hold them in together until the indicator light on the headset starts flashing red then green.
For the Plantronics 510 Voyager:
Pressing and holding down the call control button and holding down the volume up at the same time until the indicator light on the headset starts flashing red then blue.
Plantronics Explorer 320,330,340 & 350
Begin with the headset turned off. Press and hold down the silver call control button in for 6-10 seconds. The light will flash blue first. Continue to hold the button down then release the button when the indicator light starts flashing red then blue.
Plantronics 655, 665
Plantronics Discovery 640, 645, 640e
Plantronics Pulsar 590/590e & 590A & a Bluetooth device:
Begin with the headset turned off. Press and hold the call control button then power the headset on and when the indicator light flashes red and blue, release the call control button. Once the headset is paired successfully the headset will flash blue.
pulsaradapter.jpgFor the Plantronics Pulsar 590 & 590A & the Universal Adapter: Begin with the headset turned off. Press and hold the call control button. Power the headset on and when the indicator light flashes red and blue, release the call control button. Turn the Universal Adapter on. Press and hold the adapter pairing/connect button for 7-10 seconds. When adapter starts flashing red and blue release the buttons. The headset and adapter will flash blue when paired successfully.
pulsar_260_128.jpgPlantronics Pulsar 260
For the Plantronics Pulsar 260, Begin with pendant powered on.
Press and hold both the mute/play/pause button and the power on/off/pairing button simultaneously. When the
indicator light flashes red and blue, release buttons. While pendant is flashing red and blue, use the phone menu to search for Bluetooth devices and select "260 Plantronics." When prompted for passkey,
enter 0000.
For the Plantronics M2500 (discontinued):
Start with the headset powered on. Press and hold down the call control button while also rotating the multi function dial upward (away from the light) until the indicator light on the headset starts flashing red then green. When prompted for passkey, enter 0000.
For the Plantronics M1000 (discontinued):
Hit and hold the volume/mute switch in until the indication light starts blinking.
For the Plantronics M1500 & A500 adapter (discontinued): Turn the headset on and the adapter off. On the headset push in and hold the mute/volume dial until the indicator light begins to flash. On the adapter press and hold the blue power button for 10 seconds. The light on the adapter will flash once after 3 seconds- continue to hold the power button for another-7 seconds until the light flashes red. If the pairing is successful, the headset will sound a tone and both the headset and adapter lights will turn off.
For both the Plantronics M1000/M1500 (discontinued): If you remove the battery cover from the headset and then remove the battery itself. On the Green PC board itself there will be a letter followed by 4 numbers. These 4 numbers are your personal PIN code.
You can also use the Plantronics Bluetooth Pairing Guide
Feb 05, 2011 | Cell Phones
Sharp AR M-205 Blinking U 2
E prom error
Hold down the START button and retrieve the SUB-CODE,
EXample 04 or 11 or 12 or 40 ,
To clear:
Press #(button) interrupt(button) C(button) interrupt(button) within 5 secs.. then press one six (16) start (key)
Jul 10, 2010 | Sharp AR-M205 Copier
Flashing L 6 error
Press clear
press *
press #
press *
enter 14
press the start key
I may have the * and the # swapped, it has been a while since I worked on one.
please let me know if it work and if it did please rate my help
Thank you
Bob
Apr 15, 2009 | Sharp AR-M205 Copier
On Canon S9000 A3 inkjet printer error light flashing to indicate 'waste ink tank nearly full'. Can I fix this myself?
1. Turn off power.
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let the
Resume button go.
4. Press Resume button 2 times then let both
buttons go.
5. Green light will flash then stop blinking.
6. When Green light is solid, press Resume button
4 times.
7. Press the power button and the printer should turn off. If not, press the Power button 1 more time.
8. Done.
Dec 04, 2008 | Office Equipment & Supplies
Error code e10
Communication failure =E10
1. Rotate the CYCLE SELECT KNOB to the 3 O’clock
position.
2. Press and hold the Select and Pause Cancel
buttons simultaneously for (6) seconds.
3. Immediately after, press and hold the START and
Pause Cancel
buttons simultaneously for (4)
seconds.
4. Rotate the CYCLE SELECT KNOB to the 2 O’clock
position.
The STATUS indicator lights will flash the number of
times for the first digit of the code and the START indicator
light will flash the number of times for the second digit.
The code is obtained by counting the number of times
the lights flash. Example E24: the STATUS indicator
lights would flash twice indicating the 2 and the START
indicator light will flash four times indicating the 4. The
STATUS indicator lights and the START indicator light
will start flashing at the same time. The control will then
pause for 2 seconds, then repeat the code.
Troubleshoot the problem by using the chart on next
page.
To move to the next code, press the OPTIONS button.
To clear code, press the Select botton.
To exit this mode, simultaneously press and hold the
Select and Pause Cancel buttons for (6) seconds to
reset.
if this does not work need to replace control
Sep 07, 2008 | Frigidaire Washing Machines
L 6
L6 error on AR-M160 - Polygon motor problem.
I would suggest repairman service for this one as it requires stripping the unit down.
Try reseting the error first though.
"#" "interupt" "clear" "interupt" "1" "4" "start key"
Jul 02, 2008 | Sharp AR-M160 Laser Printer
I had the error message L-4 .can you halp to fix this problem?
L6 is a laser polygon motor fault, you need to replace the polygon motor in the laser unit, but try the reset code first sim 14
May 19, 2008 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-M205 Copier Logo
386 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
CheckitRight
CheckitRight
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
