Question about GE Cooktops
My wife had a boil over on our GE cooktop (model# JGP336WEV3WW)and now the electronic igniter/s tick all the time. I unplugged the unit to see if it will dry out over night. If this doesn't work I'll be looking for suggestions. Thanks in advance, Ron
  • 250 Answers
This is most likely caused by a wet or dirty spark gap or flame sensor and will probably be fine if you let the unit dry out for a couple of days. You could, at your own risk, light the pilots or burners with a lighter and let the heat dry out the components. They may have to be cleaned.
Posted on Oct 01, 2009
Testimonial: "Thank you."
I have a frigidaire cooktop FFGC3613LS two top buners do not ignite.
Hello hgodoy2 - If you only have an issue with two burners not lighting, then you might have a clogged valve. This is not something you should clean on your own if you have never done this before. I would contact a professional or your manufacturer first. You could also have a blocked or bad valve which would require a full repair service call.
Nov 24, 2012 | Cooktops
Hi, We have a GE profile cooktop (JGP975SEK1SS ). Last night, the boiling water spilled on the bottom right burner, so I turned off the stove. But since then every time we turn on the stove, the two...
Hi shadnaz,
A common issue with water causing the problem. I'd suggest following my below Tip on fixing the problem:
GAS COOKTOP CLICKING PROBLEM...
Kind Regards
JEDMEYER1
* If this solution helped you, please rate it
Aug 08, 2011 | Cooktops
My ignition for the gas cooktop is clicking without being in the on positoin. will this be caused by cleaning with water? is it going to cause problems?
One of your burner ignition switches is fried. To see which one it is you remove a wire from each one till the ticking stops. Or plan be just unplug the stove and light it with a match.
Mar 12, 2010 | GE Profile JGP636 Gas Cooktop
The igniter on the right front burner of my GE Gas cooktop does not work....I must use a lighter or match to ignite....What can I do? There is no clicking sound when I turn on the burner?
all burner igniters work at the same time - you may have a faulty electronic spark unit. change the spark unit. go to repair clinic dot come for the unit. also would be wise to check the ingniter start switch on the gas burner control knob
Oct 17, 2009 | GE 36 in. JGP628 Gas Cooktop
Ignitors keep making ticking sound, all burners turned off, won't go in lock position, and one burner will not ignite gas despite constant ticking
Probably a spillage or boil over has clogged the burner and some of the liquid has dampened the shank switch mounted on the burner post. Get a shop vac and clean the burner. Wait a day or 2 and see if the switch stops. OR disable the ticky ticky by removing the bottom drawer and looking for the spark module. Remove one of the hot wires and tape it up. Light the burners like granny does with a match. LOL
Jul 17, 2009 | GE 30 in.Profile JGP945 Gas Cooktop
NO cooktops will fire (ge monogram). All sparks stopped at once.
The problem is the spark module has gone bad. See this post for a similar electronic ignition cooktop for tips on how to solve your problem:
http://www.fixya.com/support/t1445987-mgc5430_none_burners_spark
Dec 25, 2008 | Cooktops
Ticking sound from GE cooktop igniter
Under each gas control is a switch that will turn on the spark module when rotated to the light position. One or more of these switches has failed. Some models these switches are individually replaceable, others the switch is an assembly of all four.
May 25, 2008 | GE 36 in. JGP628 Gas Cooktop
Ticking Sound of spark igniter persists
Our GE cook-top burner igniter has started ticking even when the oven is shut off. Even after cleaning the bottom of controls the ticking persists. Any suggestions? Thanks
Aug 27, 2007 | GE 36 in. JGP628 Gas Cooktop
Electronic ignition
Alien, one of your burner switches either got wet or shorted out. These switches are located on the burner valve itself. Sometimes you can take a hair dryer, pull the knobs of the control valve and dry out the switch. If this doesn't work, more than likley one of the switches gone bad. Catriver...post back.
Sep 23, 2006 | Jenn-Air JGC9430 Gas Cooktop
Cooktops Logo
250 people viewed this question
Top GE Cooktops Experts
Dan Webster
Dan Webster
Jim London
Jim London
Are you a GE Cooktop Expert? Answer questions, earn points and help others
