Will not turn on. Smells like burning rubber. May have overloaded. What is broken?
  • monster_tech May 11, 2010
    What make, model ?????
  • 250 Answers
There may be a problem with the motor or with the drive train. If the washing machine uses a belt drive, you might need to replace the belt. I found a new one for my friend's washing machine at autozone for $5. If the belt is ok or the machine uses a gear drive, there might be a problem with the motor. If the motor doesn't turn but still causes a burning smell, it's either jammed or has a problem with the starter circuit. A motor that big takes a a big jolt to get started. I fixed a newer washing machine by opening up the control panel and reconnecting the starter circuit for the motor that come off. The motor was making a burning smell so we knew it was getting power, but we knew it wasn't jammed because I stuck my finger in the water pump (for goodness sake unplug the stupid thing) and could easily turn the motor with my finger. If you think the problem is with the motor, double check all the motor's connections and realize that it may have two or more seperate cables connecting it to various places. If the motor gets hot, turns freely, and won't start, you could also try testing or replacing its starter capacitor, a black tube connected to or attached to the motor.
Posted on Oct 01, 2009
Runs, Smells like it is burning up
If it smells like burning rubber then it's possible that the belt is broken.
Feb 11, 2011 | Hoover U5753-900 WindTunnel Bagless...
Dryer part, smells burnt and is extremely loud
If you notice a burningsmell in your washing machine, the cause could be any number of things. Regardless, this is one smell you shouldn't ignore. It's important to quickly diagnose the problem and find the solution.
The "Burning Belt" Smell
Older, top-loading washing machines use a belt drive to transport energy from the motor to the transmission and pump. The belt can prevent costly repairs to the motor or transmission by slipping, stretching, or breaking if there is a malfunction in the machine. If the belt slips, stretches, or breaks, it can cause friction and a burning smell, most likely a burning "rubber" smell.
The solution is actually quite simple: you need to replace the drive belt on your washing machine. You can call a repairperson or, if your washer is under warranty, the manufacturer. If you or someone you know is handy, you can replace the belt yourself. The belt is located either from the back access panel or from the underside of the washer.
Most new washing machine models are "direct drive." This means they do not use a belt. The motor is directly connected to the transmission. If you have a direct drive machine and your washer smells like it is burning, read on.
Electrical Problems
If your washer smells and you have a direct drive machine, it may be the motor, transmission, or both. If these are shot on your washing machine, the result may be an electrical burning smell. Both are necessary to run your washing machine and can be costly to repair. The first thing to do if you notice an "electrical" smell in your washing machine and not a "rubber" burning smell, is to unplug the machine and call the manufacturer or a repairperson.
An electrical burning smell may also be caused by a water leak coming into contact with electrical wiring. Both are major concerns and should be addressed immediately. A water leak can cause structural damage in your home and can short out the electrical wiring in your washer and cause additional damage to the machine.
Other Causes
Another more likely cause of a burning smell in your washer is overloading. Adding too many clothes to your washing machine can stress the motor or transmission, causing them to overheat or malfunction and emit a burning smell. For top load washers, overloading can cause the agitator to freeze or malfunction, stressing the drive belt and causing friction, which could emit a burning rubber smell.
To prevent overloading, know the size of your washer. They are measured in cubic feet. In addition, know how many towels, pants, shirts, and other items you can safely load. When it doubt, do smaller loads. Not only will this prevent overstressing the machine, it will also ensure clothes are thoroughly cleaned and rinsed.
Nov 07, 2010 | EuroTech Washing Machines
Smells like burning rubber as if belt was broken but on inpection, it is intact. What else could cause this?
the belt could be snagged and stuck as the motor is turning. i had this problem when i put a belt on my vacuum that was too small then again when there was hair caught in the belt turning mechanism
Sep 16, 2010 | Vacuums
Did not go into the spin cycle and smells like something burning
when m/c goto spin the motor load is maximum i hope no thing with your motor
also if you smell like rubber burning maybe the belt , you will surprise every thing you see come after heavy overload clothes
Jul 06, 2009 | Washing Machines
Our vacuum smells like burning rubber. Does it
Burning rubber smell means the brush belt need attention. Make sure the brush is turning freely and replace the belt
Jul 05, 2009 | Eureka Vacuums
Burning rubber
hi! we have read your problem at Fixya! since you have specified that it smells like burning rubber, the belt connecting the motor and the tub accelerator might have been wearing out.this is a problem which occurs when you overload the motor frequently.if you get the smell continuosly, open the cabinet and get the replaced.hope your problem is tackled.have a nice day
May 25, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Washing machine spins slowly and smells of burning rubber
The belt could be worn and will be slipping on the pullys, as it spins up the rubber , rubs against the pullys and that is what creats the burning rubber smell, the belt needs replacing.
regards jonno
Apr 21, 2009 | GE WBSR3140DW Top Load Washer
The vacuum turns on but wont run smells like burning rubber I took the bottom off and the belts dont appear to be broken but the one connected to beater bar seems like it may be loose
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=542493
Generic problem for all Vacuums
Posted by mmetcalf on Apr 24, 2008
the vacuum turns on but wont run smells like burning rubber I took the bottom off and the belts don’t appear to be broken but the one connected to beater bar seems like it may be loose
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
In answer to your question, the reason it smells like burning rubber is because the belt is too loose and it is burning the inside of the belt because it is to loose, the average belt change for a Kirby vacuum is every 4 to 6 months, the tighter the belt the better the cleaning and always use the genuine Kirby belts because they are designed to work with the Kirby, there are replacement belts that will work and are less but they are made to the correct size but Kirby vacuums always s work better with genuine parts. If you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://kirby.com Contact Us by Phone
United States and Canada 1-800-494-8586
Between the hours of 8:00 am to 5:00 pm EST
Monday thru Friday
www.A-1Vacuum.com 1-800-657-1874 If you cannot find a local dealer near you they can ship you the parts UPS.
Thanks, Don – The Vac Man
Go Ahead. Use Us.
Apr 24, 2008 | Vacuums
Washing Machines Logo
211 people viewed this question
Top Washing Machines Experts
