Question about GE Spacemaker JVM1640SJ Microwave Oven
My Chefmate microwave beeps every 1hr and says it is a Code 250
Just started tonight when I was using my microwave.  I microwaved 3 things for 60 seconds each.  The Code 250 screen goes away after I push random buttons on the key pad.
MicrowaveSvc
  • 9047 Answers
SOURCE: microwave
F3 occurs if the controller detects a key shorted for more than 60 seconds. Luckily, on this model, the "keypanel" as it's called is available as a separate part. If you or a friend decide to work on it, we have *critical* safety & disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering the model number here: http://tinyurl.com/gv383 The "keypanel" is shown as reference number 44 on that exploded view.
Posted on May 23, 2007
SOURCE: A part for a chefmate microwave
customer service 800-856-8977
Posted on Jul 11, 2008
najah
  • 180 Answers
SOURCE: Chefmate microwave model no.P70D20AL-D4 not working and beeping.
You have to replace the key pad .
Posted on May 24, 2009
SOURCE: chefmate microwave oven won't start, only flashes numbers.
Well I had the same problem. It made me start unplugging a microwave when it wasn't in use, which is always a plus.
When it does the whole 6666 thing, press 5 and then stop/reset. It usually allows me to input what I want after that.
Good luck people.
Posted on May 27, 2009
likha
  • 790 Answers
SOURCE: How many watts on my microwave?
Hi
The wattages of your microwave is 800 watts.
Thanks!
Posted on Jun 15, 2009
New unit used 3 days. Microwave beeps and screen goes to menu, or set time screen. Sometimes changes the date all by itself. Does this in the middle of the night all night long.
I advice you to contact service if it has guarantee. This seems to be a psychological problem about your oven(!). Technical person need to do an electronic research surgery on its board to see if there is any wrong thing.
Nov 05, 2012 | Whirlpool GH7208XR Convection / Microwave...
F3 flashes/beeps. I see it says its a damaged keypad that needs replacing--"a simple DYI project." I'm willing to give it a try, though I haven't a clue or ANY experience how. I mean not...
HELLO.
THERE IS SOLUTION TO THE PROBLEM.
GE microwaves with a digital display will show an error code when there is a problem or malfunction with the unit. One type of error code that will be displayed on a GE oven and require troubleshooting is a code F3.
An F3 error code indicates that the keypad for the control panel is bad. This will cause the microwave to beep continuously after the set clock message appears.
Need things
* Phillips-head screwdriver
* Hair dryer
* Key panel
* Key membrane
1 Unplug the power cord for the microwave from the electrical outlet. Pull the microwave out from the wall and set it on a table or the counter.
2 Find and remove the two screws from the top of the grille, on the font of the unit, with the Phillips-head screwdriver. Pull the grille off of the microwave.
3 Find and remove the screws that are used to secure the control panel to the microwave frame. Lift the control panel unit up and away from the microwave.
4 Find and remove the screw that is used to secure the green ground wire. Pull out all of the connectors and ribbon cables from the control board.
5 Apply heat from a hair dryer to the front of the control board for at least 30 seconds. Make sure the hair dryer is at the low setting. Pull up on one corner of the top membrane, then peel it off of the control board.
6 Repeat Step 5 for the other membrane that is on the control board.
7 Insert the pliable circuit of the new membrane through the opening in the control board. Remove the wax backing to expose the adhesive for the membrane. Place the membrane onto the control board.
8 Peel the wax backing off of the top membrane, then place it on the control board.
9 Place the control board back on the microwave and secure it with the screwdriver. Reattach the grille, and set the microwave back in place.
10 Plug the microwave back into the power outlet and reset the clock.
Willing to help on other problems.
Thanks.
Sep 14, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
I inherited a 1986 J.C. Penney Microwave and can't figure out how to program most of the features. I need an operating manual or a gnome.
The clock must be set before you can use the microwave. When you plug it in, it should read all zeros. Enter the time, and press "Clock Set." Time is in 12-hour format. There is no daylight saving time.
For basic microwave use:
1. Press "Power."
2. Press the keypad corresponding to the desired amount of power, e.g., "High," or "Defrost." (The numbers on the keypad have little words on them, like "Warm," "Med," and "High".)
3. Press "Time."
4. Enter the desired cooking time, e.g., "1-0-0" will be 1 minute; you could also do "6-0" for 60 seconds. You can do as little as 1 second, up to 99 hours 59 minutes. "1-0-0-0" would be 10 minutes. "2-0-1-2" would be 20 minutes 12 seconds.
5. Press "Start."
NEVER operate the microwave when it is empty. Put at least a glass of water in it. Never put a glass in it empty; make sure the glass has something in it, like water. Be careful when taking out a glass of water that's been heated; the water has been known, in rare instances, to "explode" and severely scald people.
It is okay to use the approved metal rack (it's coated with ceramic to prevent arcing) when using the microwave in microwave mode. Of course, the metal rack is also fine for use in the convection/combination mode.
"Defrost" cycles between microwave and nothing, microwave and nothing, microwave and nothing. You can hear the cycles. If defrost takes too long, try "Low." Try to avoid using "High," as it kills most nutrients in the food. Opt for "Medium" for slightly longer time; it'll be more evenly heated and healthier. Some things, like popcorn, require "high" power.
To stop the microwave in the middle of cooking, simply open the door. (There's no such thing as microwaves escaping the oven and bouncing around the kitchen and zapping you. I have a microwave tester, and the moment you open the door, all microwaves dissipate; the reading at the door is "Zero" once it's opened.) Or, press "Cancel." If you open the door, you may test the food, and if it needs further cooking, you may close the door and press "Start," and it will resume where it left off. If you're all done, just press "Cancel."
There is no way to disable the 5 beeps at the end of the cycle. If the baby is sleeping and you don't want to hear the beeps, simply open the door right before the beeps when the countdown is at zero. Pressing "Cancel" will give you one beep.
If you have the Combination feature, that cycles between microwave and convection heat, giving the best of both worlds (cooking inside with microwaves and outside with convection), for things such as a whole meats.
To use Combination:
1. Press "Combination."
2. Consult the chart on the microwave (below the keypad) and choose a number from 1 to 4, depending on what type of food you're preparing (i.e., lamb, pork, etc.).
3. Press "Time."
4. Enter the desired time, using the method described above.
5. Press "Start."
The Convection feature simply blows hot air across the food, at the temperature and duration that you set. It's a great way to toast slices of bread for the whole family at once, or bake a pizza.
To use the Convection feature:
1. Press "Convection."
2. Choose the temperature (the degrees are printed on the keypad, such as "350 degrees."
3. Press "Time."
4. Enter the length of cook time, using the method described above.
5. Press "Start."
Be sure to cover foods (with a paper towel or suitable plastic cover) that are prone to splattering. Don't let foods explode and get up into the motor. Clean the inside regularly with a soft sponge and mild detergent, NOT harsh or abrasive chemicals like Comet. Then rinse the soap off with a clean sponge.
Be sure to close the door firmly before cooking, but don't slam it. Slamming it will wear out the latching part, but being too gentle in closing the door may cause the safety switch to not engage, and the microwave won't work (it'll count down and the light will turn on but the motor won't run).
Note: the Convection feature uses more wattage than the microwave counterpart. The volts and amps are listed in the door jamb; multiply them together and you get total watts (although the actual amount will vary depending on your "power" settings).
Aug 07, 2010 | Microwave Ovens
Our GE Profile started beeping and flashing f 3. None of the buttons will work now.
This code will occur if a shorted key panel is detected continuously over 60 seconds. Replace key panel (also called touch pad). Once the key panel is replaced, the issue will be solved.
Nov 25, 2009 | GE Profile Spacemaker Over-the-Range...
Been cursed with the 666's
You have a shorting membrane keypad.
If and when an oven is coming on or doing anything by itself, this is very dangerous and can result in a fire.
So until it is repaired, please leave it unplugged or leave the door open when it's not in use, and of course one should never leave a microwave unattended while cooking.
Sep 08, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Chefmate microwave P70D20AL-D4 beeping
After calling many numbers, I was put in contact with the manufacturer, Galanz Microwave, and was told that that beeping is due to a burned out part in the keypad that is not servicable. I, too, have this annoying model!
Jul 19, 2009 | Danby DMW1153 Microwave Oven
POSSESSED MICROWAVE!
wow.......... an exorcism may be in order.......Sadly your microwave circuitry is malfunctioning which is a costly repair. I would seriously consider trashing that possessed unit and purchasing a new one. the new ones are greener too, use quite a bit less electricity
Jul 14, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Chefmate microwave oven won't start, only flashes numbers.
Good luck people.
Jan 01, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Satanic microwave
Dude, that totally happened to my boyfriend and me! He woke up in the middle of the night to the beeping and went downstairs to check it out. It was like 3am and the microwave started displaying all 6's. Then a helicopter flew right over our apartment and he started really flipping out. Talk about scary.
May 01, 2008 | Microwave Ovens
GE Spacemaker JVM1640SJ Microwave Oven Logo
448 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
