Question about Canon ES8400V Camcorder
No Power My camera battery will not charge I can only use playback function. thanks rdcdcrew
    Problem Solver:
Maybe you have a p[roblem with your plug, if you see the orange light then it is charging
Posted on Jan 06, 2008
I have a Sansui beat box with usb & sd card facilities.May I playback flashdrive or sd card using ac power or must playback only use dc power???
You could plug it to ac and try to play your usb or sd card mp3format. There are some rechargeable equipment that does not work while plug into ac, because the use of the ac adaptor is primarily for charging the battery. Yet like laptop, or portable dvd you can use it while it charges the battery.
Mar 08, 2013 | Cameras
Camera won't trun on or charge.
Follow this procedure to troubleshoot if the power will not turn on.
Ensure you are using fresh or fully charged batteries. Check if the battery using is NPBG1 (supplied)
  1. IMPORTANT: Batteries discharge more quickly when used in cold weather conditions.
  2. Attempt to turn on the camera.
  3. If the issue is not resolved, try replacing or recharging the batteries if available.
  4. Attempt to turn on the camera in Playback/Edit mode by moving the mode switch to the Playback/Edit mode or by pressing the playback button.
  5. Switch the unit to camera mode and attempt to turn on the camera.
  6. If the issue is not resolved, try connecting the AC power adapter to the camera and a working electrical outlet. (Skip this step if the camera being used does not support the use of an A/C adaptor.)
  7. Attempt to turn on the camera.
  8. Try power resetting the Camera. (Remove the batteries from the Camera and then press and hold the POWER BUTTON of the Camera for 15 seconds and then reinsert the battery after 1 minute and check if the Camera works normally.)
The troubleshooting steps listed above should resolve your issue. If you have completed all of the steps and the issue is not resolved, service may be required. If you're located in the U.S, online repair request can be created for getting the unit serviced at the Factory service center by clicking the link below: https://eservice.sony.com or else by selecting your country from Sony Global webpage.
Jul 25, 2010 | Sony Cyber-shot DSC-W80 Digital Camera
My sony digital cam wont turn on or remain on. please help me. tell me what i should do
  1. Ensure you are using fresh or fully charged batteries. IMPORTANT: Batteries discharge more quickly when used in cold weather conditions.
  6. If the issue is not resolved, try connecting the AC power adapter to the camera and a working electrical outlet. NOTE: Skip this step if the camera being used does not support the use of an A/C adaptor.
  8. Remove the Battery, press the power button for 30 seconds.
  9. Please wait for one minute, insert the Battery and turn it on.
The troubleshooting steps listed above should resolve your issue. If you have completed all of the steps and the issue is not resolved, service may be required. [[]]
Jun 25, 2010 | Sony Cyber-shot DSC-W70 Digital Camera
Playback and menu buttons freeze camera
This is a circuit board problem, return the camera for warranty repair replacement.
Please rate my help++++Thanks for usinf FIXYA
Mar 24, 2010 | Nikon COOLPIX S570 Digital Camera
My Canon Powershot SD1000 has a fully charged battery but won't turn on at all.
Does your camera turn on when it's in playback mode? I have a similiar problem with mine. It only turns on in playback mode.
Sep 25, 2009 | Canon PowerShot SD1000 Digital Camera
No record or playback
had the same problem, it seems to do fine without a tape in it :so I took the tape in and out a few times and I guess the alighnment was better so it works for Now..So Give it a try
Dec 12, 2008 | Panasonic Palmcorder PV-DV203 Mini DV...
Only works in playback mode
If when switching from playback to LCD then Viewfinder and no preview display is visible in either LCD nor viewfinder then the switch is not switching. If the red battery light is on try new batteries as some functions are unavailable with low battery power or connect the AC adaptor to see if power is a problem. Does the menu work? Does the zoom function move the lens? If all is functional in the playback mode then the switch may not be making contact internally. Carefully apply pressure to the switch while slowly moving it between all 3 positions while seeing if any display changes both through the viewfinder and the LCD. If you are technically confident you can open the camera case and try bridging the switch poles with a small screw driver to see if the switch is defective or misaligned. EBay has had DiMAGE cameras listed for 'parts only' very cheap but the Z3 would not merit the cost of a camera repair shop. My last successful bid for a Z6 was $200 2 years ago. My first repair on a digital camera was pretty simple since inside the case is a single printed circuit board with little ribbon connectors that can be reseated at ZIF type connectors. Just be careful, slow and keep track of the screws and parts orientation. Any friend who fixes laptops can help you but a shop will cost you more than the camera is worth. Good luck.
Oct 15, 2008 | Konica Minolta DiMAGE Z3 Digital Camera
Lumix TZ3
stick the memory in the camera, select the playback mode, push menu and then arrow up until you find format, then select this function.
May 27, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
No playback on DCR-TRV103
In playback mode the lCD displays the battery time, hi8 symbol and the tape counter. all the functions work the tape will play, rewind, fast forward. The screen stays blank on playback and the tape counter stays at 0:00:00 eventhough I can see the tape turning. I also hooke the camera to my tv and I got no picture.
Dec 23, 2007 | Sony Handycam DCR-TRV103 Digital Camcorder
General malfunction
This is similar to my problem it was working fine and then when i went to take a picture it was all black and sometimes it doesnt even turn on but some icons are present any halp would b egreat thanks
Apr 13, 2007 | Panasonic SV-AV50 Digital Camera
Canon ES8400V Camcorder Logo
101 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
