Question about Measuring Tools & Sensors
I want carpenter to put a wood door
I want carpenter to but a wood door
    Scholar:
  • 75 Answers
You'll have to advertise elsewhere if you want someone to install a wooden door into a framed opening. We're not allowed to take money for work done on this web site.
Posted on Nov 06, 2009
I have a vertical rubbermaid shed that snapped together and didn't put anything heavy on shelves and 2 of the shelves fell down. How can I put back up and reinforce?
I'm not a carpenter, but you could get a piece of wood an one by four and drill a hole in the wood and adhere it to the shed on both ends and each shelve for support.
Jul 08, 2017 | Rubbermaid Garden
I want to fix a crack in a drawer. What kind of glue can I use
If it is wood, use carpenters wood glue. If it is plastic, use epoxy glue.
Feb 23, 2016 | Cars & Trucks
How can i add a door frame for a storm door when there is no frame
many a carpenter has done it with good lumber and a miter saw .
Feb 03, 2015 | Cars & Trucks
Why won't my millstead engineered wood floor lay flat
if it does not lay flat after 48 hours of acclimatization, return the material to the seller. Must be a bad batch.
Jun 28, 2014 | Millstead Hardwood Floor Sample: Hand...
Common wood borers
Spray spectricide carpenter bee spray into borer holes. http://www.lowes.com/pd_190359-316-HG-53371_0__?Ntt=carpenter+bee&UserSearch=carpenter+bee&productId=3479819&rpp=32 Use some wood glue to secure the steel wool in place. http://www.lowes.com/pd_88042-18562-62000_0__?productId=3121069&Ntt=wood+glue&pl=1tURL=%3FNtt%3Dwood%2Bglue&facetInfo= This will in effect, kill any borers that are in the hole, keep them from coming out if they hatch. It will also keep bees that were born in that hole from coming back and re-using the hole. Obviously, the steel wood is too much for the borers to penetrate. Keep a watchful eye for bees that return and spray them as soon as you see any sawdust - repeat the process. Ultimately, the bees won't come back. You could always caulk and paint over the glue/steelwool holes. http://www.lowes.com/pd_219921-68-11540_0__?productId=1061075&Ntt=paintable+caulk&Ns=p_product_price'0&pl=1tURL=%3FNs%3Dp_product_price%7C0%26Ntt%3Dpaintable%2Bcaulk%26page%3D1&facetInfo=
May 03, 2014 | Hardware & Accessories
Lamination has come out. Want to find furniture repairer to re laminate the bed.
This is not a big problem if your bed is made either such kind of wood for example malaysian wood like that it easily gets spoiled when water coincides with it and its better for you to see a good carpenter for that cause to laminate the bed with nice wood.
Mar 06, 2013 | Furniture
Toy wooden castle, broken apart. Clean break. What is best adhesive to reattach?
Elmers wood glue with compression during curing. Note this is not white glue and it is sometimes called carpenters glue
Nov 30, 2012 | Toys
What is the miter cut on the wood if I'm making a decagon shaped structer
all shapes angles make up 360 degrees.
square=360/4 = 90degs
hexagon=360/6 =60degs
decagon=360/10 =36degs
Oct 13, 2010 | Carpenter Miter Divider
Faulty Record carpenters vice
Hi pal this is what u have to do, put a plastic garbage bag & about 15 sheets of newspaper on the floor below the vice spray with "liquid wrench" with red tube on the nozzle spray all around nooks underneath sheild the vice with a piece of cardboard os you don't spray the walls,floor or ceiling let stand 5 min. then bang with a 24" piece of 2x3 or 2x4, wrap a piece of rag around the handle base then use a 12" pipe wrench over rag/base tap & switch the wrench back & forth, "do not bang" the vice wooden handle it can brake be gentle spray & tap/bang pipe wrench make sure the handle is covered with the rag so u don't mar the wood handle with the 2x3 4, remember tap n turn the wrench around be patient, tap the back back of the vice handle while putting pressure on the wrench handle back n forth till loosened, watch where u put your fingers when doing all this, I don't want no bang " oh f k oh s t ooooooooh" good luck u can do it.
Jan 12, 2010 | Hand Tools
I have a bathroom cabinet door that came off and now I can't get the screws to stay in as the inside of the cabinet is so damaged and wood filler does not work , even glue will not hold this door back on...
Buy a dowel pin the size of the hole in the cabnet then use carpenters glue to glue the dowel pin in place where the old hole was make sure it is a good tight fit. Next saw off the dowel pin and let set over night then drill a strating hole in the dowel pin and reinstall the door works like a chanp. Hope this helps.
Sep 28, 2009 | Duravit 6130 Starck 1.2.3 Vanity Unit w/ 2...
Measuring Tools & Sensors Logo
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
