Question about Goodman Heating & Cooling
Do you know how I can get a Goodman Ht pmp Manual
Do you know how I can get a Goodman Heat pump Manual for Model CK36-1? Thanks
  • 24 Answers
This manual willl not help your system perform better , have a qualified tech check your sub-cooling. temp diff, and match your piston with your coil. many goodman systems may say they are 3 or 4 ton but are half a ton smaller than advertised at the compressor. a three ton system will have a two and a half ton compressor
Posted on Oct 01, 2009
I have a goodman electric furnace. Model no AR32-1, where can I get a manual. My furnace is making a grinding/squeak noise. Is it okay to run it until it's fixed?
I'm not sure you have a true Electric Furnace or a Heat Pump, since both are electric.
In any event, Goodman has Owners manuals that you can download in a pdf format. Just look for your model #.
http://www.goodmanmfg.com/SearchResults/tabid/37/Default.aspx?Search=Owners+Manual
Feb 04, 2011 | Goodman Heating & Cooling
I have a Chinese made heat transfer machine model # HT-E15 but no name brand the auxiliary field fuse gets extremly hot but it is not blowing the fuse and also the temp get close to the desired setting and...
hello I have a ht-e15 model heat press machine that I bought off of ebay I just took it out of the box and cant get it to come on it didn't come with a manual so I don't know if I am doing something wrong could you please help me
Jan 07, 2011 | Kitchen Appliances - Others
I have a heat pump model ARUF 042-00A-1A. There is only air blowing but no heat comming out. What can we do? Thanks
Heat pumps are like a refrigerator. Check the "pump" part is working properly. and is cooling one side, heating the other.
If not - maybe run out of gas (needing technical repair and refill) - or a motor fault.
Dec 27, 2010 | Goodman Heating & Cooling
I need to find a parts dealer for goodman heat pumps.
let me know where you live and I'll find you a dealer
Jun 16, 2009 | Goodman CKL60AR60 Air Conditioner
Need to know unit size
ckl60 5 ton about a 2003 model on most ac heat pumps the model number reflects the ton sized by 12000 btus per ton also as for the indoor unit cfm rating 400 cfm per ton
May 14, 2009 | Goodman CKL60AR60 Air Conditioner
Connecting new 5 wire low volt to an old 4 wire L/Volt
You will have to change out the thermostat wire if you do not have another wire in the sheath you can use.
You must have 2 wires for 24 volts hot and neutral. Usually red and blue.
Yellow for the compressor contactor.
Orange for the reversing valve.
White for the indoor heat coil relay.To bring on indoor coil when in defrost mode.
Apr 28, 2009 | Heating & Cooling
Service manual for Goodman Heater # PGB036100-1
sounds like that model # is for the A/C coil or its a heat pump air handler. In any event I am not aware of any "repair manual" that is put out by Goodman to the public. They have classes on their equipment but they are geared to the professional serviceman.
If you would like to descrobe the problem, I will try to help you.
Nov 03, 2008 | Goodman GMS90703BXA Heater
Heat Pump or not???
This is an air conditioner. Based on the numbers you gave me, this is what I come up with. Thanks.
C= Split system
KL= Air conditioner
30= 2.5 ton
1= 208 230 v
D= Revision
Jun 23, 2008 | Goodman CKL49AR49 Air Conditioner
Heating & Cooling Logo
239 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
paulcarew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
