Acer Aspire 3680 PC Notebook
Problem for Acer Aspire 3680 PC Notebook
How do you install the operating system on an Acer
By 82893hb on Oct 01, 2009
how do you install the operating system on an Acer Aspire Notebok 3680? I Have the recovery CD.
Solution #1
posted on Oct 01, 2009
Not Rated)
drifterK
Rank: Guru  Acer Computer Hardware  Expert
Rating: 86%, 359 votes
it depends of what op system you want to install ...you can use the recovery CD ...and ussually it will reinstall the OS ..and the drivers ..but Im not sure if it formating the C partition ...and if you want to get rid of bugs ..this would not help you much cauze they may came back in a week or so ...but ...you can get a boot-able cd with vista os or xp ...and reinstall it clean ...:
first ..remove or back up all data you do not want to loose fromthe C partition ..( you can move them into the other partitions if you have space ..
second ..insert the disk ...and restart ..if the boot order is already set from bios to boot from cd first ..it will prompt you to press any key to boot from cd ..
after that it will search for previous installations ...and prompt ya for an action ...usually is best to choose that you dont want to recover..(press esc) and delete the C partition and reformat ..after that it will load the installation files..and restart ...after restart ..things will go at it own ...until you have to enter the product key and select the time zone ..language and ..network type ..
after finishing the actual windows installation you have to enter all drivers for the devices you have ...
in this point ..you can actually insert the recovery cd ...( if you installing the same OS as in original ) and even if it will reinstall the windows too ..at least will be on a clean install ...it will install all your drivers also ....
if you want to change from vista in xp or the other way ..and dont have the drivers ...let me know...
Was this helpful?
Yes
No
Solution #2
Not Rated)
gsimon5661
Rank: Guru  Computer Hardware  Expert
Rating: 88%, 29 votes
Place the disk in the drive starting with disk one if there are more than one disk, and reboot the computer. when prompt to press any key to boot from CD do so. and the CD should run. just follow all instructions from there. This should work as long as it is a recovery disk. if its a fresh installation of the OS, thew steps are a bit different. Of course if the computer does run the disk you may need to change the bios setting to boot from CD drive, but this may not be necessary.
Was this helpful?
Yes
No
Solution #3
Not Rated)
danikress
Rank: Wiz  Computer Hardware  Expert
Rating: 88%, 7 votes
insert the cd- rebot computer -wait for prompt screen to press any key and do -then go through the step by step.
Reformatting hard drive and such. but it might be easier if you use the partition that is on the computer and reboot off that. it is much more user friendly and most likley won't cause a head ache. ALT+ F10 key on first boot screen.
Was this helpful?
Yes
No
Solution #4
Not Rated)
MNfisherman
Rank: Wiz  Acer Computer Hardware  Expert
Rating: 85%, 2688 votes
When computer very very first boots up, press F2 I believe. F8 if it doesn't work. Then you will get into bios settings. You can see a section that says boot up device options. you will want to choose your cd rom as first boot up and then hard drive as second. Then save settings, put disc in pc and restart it. It will then instantly read and run disc first thing.
Was this helpful?
Yes
No
Popular Solutions for Acer Aspire 3680 PC Notebook
Questions and Unsolved Problems for Acer Aspire 3680 PC Notebook
Do you recommend Acer Aspire 3680 PC Notebook?
Answer
Answer
why does the netbooks allow games to be played and how can i speed it up on the wi-fi.My netbook... (More)
Answer
i can not get it to boot of the windows xp installation disk.(this is a bootabl disk) i have change... (More)
Answer
Registeration of new product
Answer
i need 2 find the code for penguins
Answer
are there any lacations in orlando fl where the 1st year warrenty repair can be done?? i have lost... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Acer Aspire 3680 PC Notebook:
Top PC Laptop Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more PC Laptop Experts
Top Computer & Laptop Repair
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
