Question about Jl Audio 300/4 Car Audio Amplifier
WHERE DOSE THE BLUE WIRE GO IT WAS FOR
  • 65 Answers
Blue wire is the Remote power switch. Supply this wire with posive power and it turns the amp on. Its only a "Switch" not the main power feed. There is usual a blue amp remote wire on the back of most aftermarket head units.
Posted on Oct 01, 2009
Testimonial: "awsome you guys are great "
  • 134 Answers
IF YOU TALKING ABOUT THE BLUE WIRE FROM THE RADIO CALLED THE REMOTE WIRE. IT SOULD GO BETWEEN THE POSITIVE AND NEG CABLES, OR BESIDE ONE OF THEM.
Where dose hot wire go to from coils on la145 22hp v twin
the coil wire is only a kill wire. it goes through the wiring harness through safety switches back to the ignition switch.
Nov 10, 2016 | John Deere Garden
I need to know were the yellow wire gos dose it go to the red or blue for a pioneer car stereo?
The yellow wire on a car stereo head unit is usually the keep alive 12+, which allows the stereo's memory to be set and kept. It should be connected to a constant 12+ volt source.
Oct 07, 2013 | Pioneer Car Audio & Video
My Apline CDA-9831 has no sound when trying to play regular store bought CD's. It dose have sound on Tuner.
Are you using an amplifier? If so, make sure you are using the blue/white wire (amplifier remote turn on) instead of the blue (power antenna remote turn on) to turn your amplifier on. The blue wire turns off when leaving tuner mode.
Jun 28, 2011 | Alpine CDA-9831 CD Player
My switch has only a white wire (hot) and a black wire (neutral). Witch one dose the red wire connect to?
I answer questions for free
I specialize in timers and electrical devices
If you have a different timer than the one shown below, add a comment with your timer model and I will help.
Different timers use the red wire differently.
You posted under Intermatic ST01C.
If the ST01C is your timer, then the red wire is capped off.
The black-timer wire connects to black wire.
The blue-timer wire connects to white wire.
IF the timer does not work after wiring, then try reversing the blue and black wires.
The following photo shows the EJ500 timer which is wired exactly like the ST01C
http://waterheatertimer.org/images/EJ500-wiring-full.jpg
The following link shows several wiring diagrams for the ST01C and EJ500 timers
http://waterheatertimer.org/ST01C-program.html#ST01C
Nov 02, 2010 | Intermatic Inc. ST01C Digital In-Wall...
WHERE IS THE CORONA WIRE I HAVE TO CLEAN IT?
Its on the drum at the top front there is a slide you push from side to side 2 or 3 times .All it dose is clean the toner of . ( Its blue )
Helps to charge the drum. Good luck
Jul 17, 2010 | Brother IntelliFAX 4100 Laser Fax
Windows 98 but want to put usb into tower onto the mother bord but th wires witch order do they go in or dose it matter ie red/white/ black/blue/yellow/green hae to put them onto motherboard pins it is a...
You should have 4 joined pins and 1 black ground for each usb port.
The red wire is for Pin1
White wire is for Pin2
Green is for Pin3
Then you have the Ground wire (black)
The pins on the motherboard are all numbered.
Oct 11, 2009 | Computers & Internet
1995 isuzu trooper 3.2 (3 sets of wires comming from gearbox ?) dose any one no what they are for Thanx Gordon
detent switch has two wire bullet connectors,
another detent switch which is reverse lights that also has bullet connectors.
put blue to blue and red to red if not car will not turn off with ignition key.these are on upper section of gearbox the third is a speedo sensor at rear. one oxygen sensor at front section which could be separate section of engine harness
Jun 27, 2009 | 1995 Isuzu Trooper
Bottom blower dose not go on
you should have two wires that go to a capacitor for turning the motor the right way durring start up then you should have two wires for run current. Now my motor has red and blue as the run voltage and blue and a white wire to the capacitor -6uf+/-10-5%@250AC. This cap is mounted on your fan shroud and refer to you top motor wire configuration, as both blower motors is in like the same wire colors to cap. Now my lower motor keeps blowing the thermal fuse and dose not overheat as the thermal needs at least 360 degrees of heat to blow yet my moter when running is not that hot.... I would replace the motor and cant seem to find one where did you find yours.
Apr 25, 2009 | Windchaser PAC9 Air Conditioner
I have a turner plus 3 mic with 4 wires red,black, ground and white. i need to wire it to a 5 pin uniden washington radio, looking for a wiring pattern with pin number to wire color
Here are 2 way's
1- white
2- shield
3- black
4- red
5- blue
yellow is not used.
if this dose not work try moving the red wire to pin 5 and the blue wire
to pin 4
Mar 04, 2009 | Uniden GRANTLT 40-Channels Base CB Radio
Rear speaker install
the brown wire is the LR+,yellowLR-. The drk blue is the RR+,lt blue is the RR-.If this dose not work test speakers.IF speakers work make sure you have a good output from stereo with the old speakers.Are you using the factory deck?
Dec 29, 2007 | Pioneer TS-A6962R Car Speaker
Jl Audio 300/4 Car Audio Amplifier Logo
170 people viewed this question
Top Jl Audio Car Audio & Video Experts
Mark Skinner
Tygh Duval
Tygh Duval
hoyzee1
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
