Question about Canon PowerShot A95 Digital Camera
I turn the camera on and it starts to focus, then shuts down displaying e34 on the screen
I have a Sony DSC-W50 Cybershot camera that won't take pictures or videos anymore. It powers up fine and the screen works, but when I hold down the shutter button all the way, it focuses and nothing more.
I have a Sony DSC-W50 Cybershot camera that won\'t take pictures or videos anymore. It powers up fine and the screen works, but when I hold down the shutter button all the way, it focuses and nothing displayed
Mar 07, 2011 | Sony Cyber-shot DSC-W50 Digital Camera
When I turn on a scanner it displays error
E34 refers to abnormalities in the Shading Solenoid Connection.(Lower side). If you open the scanner top cover and press the 'start' button, you will see two white strips (plastic) coming out. If it does not come out there is a problem. (This is used for Color balancing). Check if the connection to this are perfect. You may need to remove the plastic cover near ****** roller (The one which is in the bottom). Ensure that the plastic is not damaged.
S. Mohan Chennai, India
Oct 08, 2009 | Canon DR-9080C Path-Through Scanner
Battery level don't show on display.
hi friend,
follow these steps
  1. Turn off your LCD display screen. I know this is hard—who likes shoving their face against the camera to compose a shot through the little viewfinder? But the LCD screen single-handed-ly drains a lot of power.
  2. Minimize the picture preview to the least amount of time possible—usually one second. This uses less LCD screen time, thus less power.
  3. Dim the brightness on your LCD screen. A dimmer display extends battery life by consuming less power to light the screen. This might make the display harder to see, but usually only in direct sunlight.
  4. Set the power saver to the least amount of time. Power saver lets your digital camera “sleep” when not in use, but doesn’t shut it down entirely. To “wake up” your digital camera, simply click the shutter button.
  5. Use your zoom as little as possible. The motor that moves the lens uses power. This also goes for repeatedly turning your digital camera on and off if it has an extend able lens.
  6. Turn off the continuous focus. Again, constantly using motors and electronics to ready your shot drastically minimizes battery life.
  7. Don’t push the shutter button half-way down until you’re ready to shoot. Pushing the shutter button (constantly resetting and refocusing) will drain battery life.
  8. Use the flash only when necessary. Your digital camera’s “auto flash” option should take care of this, but make sure your flash isn’t going off in broad daylight.
  9. Don’t delete pictures from your digital camera unless necessary. This consumes power. Wait until you download the pictures to your computer before deleting.
  10. This one’s basic, but charge your battery often. Lithium ion batteries, which most digital cameras use, don’t have “battery memory” like older alkaline. In fact, lithium ions work better and last longer if charged completely and regularly.
thank u for using fixya
regards,
sivaranjini
Aug 11, 2009 | Kodak EASYSHARE M1063 Digital Camera
Camera turns on then shuts down
hi...ensure  that the camera is turned on. If applicable, ensure the lens cover has been removed before taking pictures. the LCD backlight is turned on by pressing the DISPLAY button several times until the screen appears.  Depending on the camera model, the DISPLAY button may be labeled as DISP or with a display icon. This button could be a standalone button or it depends upon the camera model.....
If operating the camera with a battery, ensure the battery is fully charged.
Ensure the battery is inserted properly in the camera.
If operating the camera with the power adapter, ensure it is plugged into a working AC outlet.
Ensure no Audio/Video (A/V) cables are connected for viewing pictures on a TV; the LCD screen will not display when an A/V cable is connected.
Perform a reset procedure on the camera....
thank u rate me!!!!
Feb 10, 2009 | Canon PowerShot A300 Digital Camera
Pictures are blur
Your pictures are blurry because the camera did not focus properly on the subject.
First, turn on the camera in any picture taking mode (or video mode), then look at the screen or viewfinder. There should be four white corners in the center of the camera display. This is your targeting area.
1. Aim the camera at your subject so this center area is directly on it.
2. Press the shutter button lightly, not all the way down. Wait for a second or two WITHOUT RELEASING YOUR FINGER. If the white corners turn green, keep the finger on the button and press it all the way.
(Once the screen flashes black, a picture is taken and you can release the finger).
If the targeting area turns red and blinks, then the camera has not focused. You can to try to focus again by following step 1 and 2. If a picture is taken when the targeting area is red, then the picture will be blurry.
If there is no targeting area, then you can still focus by aiming the camera at your subject. Now follow step 2. A green box will appear on the subject, then a sharp picture can be taken.
The red arrow that flashes means that the pictures or videos are being written onto the memory card.
Also, try to be steady when taking pictures, because slight hand movement can cause blurry images too.
Page 25 in the DMC-FZ7's english manual will also explain how to focus.
Jul 18, 2008 | Panasonic Lumix DMC-FZ7 Digital Camera
FE-280 Wont Focus and Shust Off
I have the same problem, but my display doesn't show anything. It is just black.
Dec 10, 2007 | Olympus FE-280 Digital Camera
Camera keeps shutting off
Have you fully charged the new batteries
Nov 03, 2007 | Fuji FinePix A345 Digital Camera
Camera error
The problem is the internal focus lens is either stuck, or knocked out of alignment. The lens will need to be serviced, or replaced with a new (not cost effective), or good used lens assembly.
Aug 07, 2007 | Sony Cyber-Shot DSC-W1 Digital Camera
Canon PowerShot A95 Digital Camera Logo
46 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
