I have to roll window down to open driver side door. i went to the dealership and they told me that i would have to replace the entire driver side door panel to fix. is this the only solution or should i get a 2nd opinion and if so, where can i go or search for in regards to the parts needed to fix my door?
That is not true.
The handle fell off on the inside. You can remove all the screws, remove window and lock controls. Then take a large flat-tipped screwdriver gently pry off door panel. Pull up and off when loose. You will now have access to inside off door and put the rod back in the handle hole. If the plastic holder piece is broke you will need another one. Cheap.
