Question about Western Digital WD Passport 250GB Portable Drive 250 GB Hard Drive
WD Passport Drive running SLOWWWWW on time machine
I have the same problem. 500G WD Passport Drive, trying to backup using Time Machine and it's running extremely slow...
  • 35 Answers
USB s slow and when you have huge files it tends to bog it down. it is better to have a firewire transfer. another reason could be your computer is doing to much. leave the computer at one task. walk away and let it work. otherwise you will be using memory.
Posted on Oct 01, 2009
My WD mt passport 2TB keeps ejecting itself all the time. The problem is that I have my entire iTunes library (1tb) there. I wont to copy the library to another disk but the drive ejects itself all the...
You can disable the sleep timer in the settings menu. Details can be found on page 34 of the product manual:
http://www.wdc.com/wdproducts/library/UM/ENG/4779-705020.pdf
Passport drives are generally used for backups so they like to turn themselves off to extend their life cycle. If you want to use an external drive for frequent media use, I recommend WD Elements.
Sep 26, 2013 | Western Digital WD My Passport 2TB USB 3.0...
Tip
Western Digitial Passport Sync Software
WARNING: Do not think that theyourWD Passport, using the WD Sync software, is a backup drive; it is NOT !
As per the documentation with this device:
"synchronization software is intended to synchronize the data from a computer to the drive (WD Passport) and SHOULD NOT be used as backup software. To use this software properly, we advise that you do not wipe or
erase the data from the internal hard drive (computer) and resynchronize, as this will cause the data that WD Sync stored to the Passport to be deleted."
This is why you are hearing so many people saying that they are deleting the WD Sync software, reformatting, and using the WC Passport as a true backup drive where you can actually see the files that you are backing up, rather
than a bunch of unrecognizable sync files that likely don't have all the files that you thought you "backed up".
on Jan 18, 2009 | Western Digital Passport WDXML800UE...
Hi , I just copied my hard drives to my new Passport Essentials SE using the WD Smartware software, I do not like I have to manually switch between my two internal hard drives to back up so I would like to...
As far as I remember WD just copies the software into the PassPort drives and you don't have to install anything you can just run the software from the drive. If that is still the case then first take a backup of that software (basically copy that software folder to some place in your internal drives) then format the drive (make sure you select NTFS as the file system for the drive when formatting).
Formatting will erase all the files in the drive so make sure you have backup of you personal files also.
Formatting also resets the drive back to factory setting (if you want the WD software back then just copy it from the backup to the PassPort drive).
Sep 06, 2011 | Western Digital WD Passport 250GB Portable...
Hav e new WDElements 3TB USB ext Back up drive...fired it up 1st time, MAC desktop has the WD icon on desktop on it, but cannot copy any data to it. In the corner of the element window there is a pencil...
https://support.wdc.com/knowledgebase/answer.aspx?ID=15084
The link above states:
"My Passport for Mac and My Book for Mac are formatted with HFS+ and are Mac Ready
  1. To use the device on macOS and for Time Machine backups, format the drive as HSF+.
    For assistance formatting the drive for Mac usage, please see Answer ID 3865: How to partition and format a WD drive on Windows and macOS
  2. To use the device on macOS and Windows OS, format the drive as Answer ID 291: How to format a WD hard drive in exFAT or FAT32
  3. Click here to download WD Software for macOS
Feb 11, 2018 | Western Digital 3TB My Book Essential USB...
My passport 5oo Gig freezes my computer
Yes there is. Please note that removing the drive from your external will likely void any warranty you may have with the manufacturer.
If ok with that, remove the drive from the enclosure very carefully. Then connect the internal drive directly to a SATA connector, do not use USB and see if able to access drive. If so, backup data right away.
If this model is only USB connector, or if still not accessible when connected to SATA, then you will need a reputable data recovery service provider.
Feb 15, 2018 | Western Digital Passport WDXML800UE...
I am using the passport essential 500gb on my macbook pro. I dont use time machine...i just backup files manually. I tried to transfer an item to the passport and it told me that it couldnt be moved...
i almost have the same problem, i bought the
Western Digital My Passport Essential 500GBfrom a week ago and i left the drve connected to the laptop and copying data from an old WD drive and after couple of hours i found an error appearing.......then i clecked okay and restarted the laptop and from then my
Western Digital My Passport Essential 500GBdoesn't appear in my computer drive list nor in the device manager.
i just cut my precious data from the other drive.
PLZ help
Mar 29, 2010 | Western Digital My Passport Essential...
Can only see one WD Passport 320GB drive at a time.
This is most likely a classic case of them trying to occupy the same drive letter. If you open disk management Start > Run > type 'diskmgmt.msc' and you should see them both there - One with a drive letter and one without, simply right click on the drive which doesn't have a drive letter and select 'change drive letters and path...'. Change the drive letter to something you know doesn't really get used and they should both appear in my computer.
Hope this solves your problem.
Jan 12, 2010 | Western Digital Passport 320GB External...
Help to backup full computer programs & docs with WD Passport 160
Try going to the "Computer" icon and look for the external drive. Open the ext. drive folder and look for the InstallSeagateManager icon, the Application one. Double-click on it and it will allow you to install the software to do a backup on your new computer. First thing you should see is the Language Selection screen. I think you can take it from there!
Sep 22, 2009 | Western Digital Passport (WDXMS1600) 160...
Cannot eject western digital passport
I've had similar problems with external drives. First of all if you have OS 10.4 it will recognize and format external drives that OS 10.5 will not. However the most recent update fixed some issues, so download the most current update by going to the apple and 'software update'. Next, if time machine has stamped the drive, then it will always 'see' the WD drive as the default backup and will write data to it periodically in automatic backup mode. If there is no data on the drive, or if you don't want to save the data then you could reformat the drive (first turn OFF time machine) by going to utilities and then 'disk utility'. If not, then try going to utilities and then use the 'air port' utility to work with the drive as it should be listed on the left as a time capsule.
Jul 07, 2009 | Computers & Internet
Can I use my passport essential 2.0 to backup my work computer as well as my home computer?
You can use your WD Passport to sychronize data on multiple computers, you just need to set up the other computer name (e.g. "Work computer")using the software.
Aug 03, 2008 | Western Digital Passport WDXML800UE...
Western Digital WD Passport 250GB Portable Drive 250 GB Hard Drive Logo
1,117 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
