Question about Frigidaire ATF6000ES Front Load Washer
Washer wants to creep across the floor? - Frigidaire ATF6000ES Front Load Washer
  • 11,896 Answers
Try putting foam pads or the rubber pads they sell underneath the feet.
Posted on Oct 01, 2009
The washer was working great for most the year, all of a sudden it seems to be off balance and now on the spin cycle it vibrates so much that the washer itself creeps across the floor. the clothes are...
A few things I did and it solved my problem of the same nature.
First:
Run a cycle with nothing in the washer. Some models have have a water tank on the outside of the drum that fills to balance the drum. Running a cycle without anything in the drum may allow this small tank to fill back up.
Second:
Grasp the agitator at the top and near the base and move the whole drum around side to side and up and down. This may realign the the skid pads with the drum feet (not the terms that I remember from talking to a repair man I know but doing this may help)
Third:
There may be springs that help keep the drum balanced and centered. If one of these has broken. This would cause the same problem.
Locate them on the inside of the cabinet near the sides and attached to the bottom of the cabinet. (that's where they were for my washer).
Mine were fine so that wasn't the problem.
The first two items fixed it for me.
Hope This Helps!
Jan 27, 2014 | Washing Machines
My Frigidaire Affinity dryer has started vibrating more and more during operation. Is the motor going bad or is there another problem?
Hi
Try the following to reduce the noise--
Washer is not resting firmly on floor. Move washer so it rests firmly on floor. Adjust leveling legs. NOTE: Some shaking of the washer is normal without moving across the floor.
• Shipping bolts and foam blocks have not been removed during installation. Check out the installation instructions for removing shipping bolts and foam blocks.
• Wash load unevenly distributed in drum. Stop washer and rearrange wash load.
Please post back for any further assistance.
Daniel
Jul 24, 2010 | Frigidaire Affinity ATF7000ES Front Load...
Unit shimmy's across floor
Remove the two support bars from below the washer drum from the front as instructed in the installation manual
Jan 18, 2010 | Frigidaire GLEH1642DS Front Load Stacked...
Matag washer travels across the floor.
Velcro is a silly idea, what you want it to rest the washer on a rubber membrane as this will absorb all vibrations and kinetic energy thus stopping it from moving.
http://www.gkacoustics.com/anti_vibration_rubber_mats.htm this place sells them (aswell as other places) Neoprene Rubber and MLC Closed Cell Rubber is your best bet.
Hope this helps
Jan 03, 2010 | Maytag Neptune MAH5500B Front Load Washer
WHEN IT SPINS IT WILL WALK ACROSS THE FLOOR
the washer is not getting a balanced load need to adjust the clothes inside so it wont jog
Jun 02, 2009 | Washing Machines
Maytag front loader MAH-3 vibrates. Level & on concrete floor.
THERE ARE SHOCK ABSORBERS IN THIS UNIT,SOUNDS LIKE ONE OF THEM IS BROKEN.HOPE THIS HELPS
Nov 16, 2008 | Maytag EPIC MFW9700S Front Load Washer
Front loading lg washer
if you have the spin sense option, try enbaling that on the washer
Oct 25, 2008 | LG WM-2277HW Front Load Washer
Admiral clothes washing machine AAV7000AW
Hello calmtouch,
You said,
When in spinning cycle, the barrel begins to move all over banging the washer across the floor. I don't even know what to look for.
Help.
sounds like the coupling connecting the tub to the transmission may be loose and throwing the wash tub out of rotation causing the banging and walking washer.
Bless You
Huuum
Sep 19, 2008 | Admiral AAV7000A
HE4t King Size Washer Balance Problem
remove the lower acess panel ( 3 screws across bottom) check for broen suspension/shock absorbers
Mar 02, 2008 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
67 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
