Question about Kodak EASYSHARE M1063 Digital Camera
The button at the top where you swap from auto, to close up..etc does not work anymore, i can not swap views. Is there something i can do
Tv code for one for all remote. Sylvania 19 in. tv
Here are several codes I pulled of the Internet for you , All codes are for Sylvania Televisions , you will have to try one by one Sorry, most universal remotes these days have a Auto tune function , something like hold volume key up & menu button down for 5 seconds , every remote is different , but a light will flash , point it at your tv , when it turns your tv off or on , you click store , or what ever button your remote has , this will stop auto tuning , here are some codes 186,054,030,024,020,187,065 Let me know if you need anymore help tuning etc.
Dec 02, 2015 | Sylvania Televison & Video
I have Panasonic TH-50PZ700U and the viewing screen is small and never goes back to full screen. Tried checking all options and none make screen go back to full
Are you sure you have tried the aspect button, usually the one top left on remote, press it and select ( with arrow buttons from auto 14.9 16.9 4.3 zoom 1 2 3 etc this will fill out screen,
pete
Nov 15, 2010 | Panasonic (TH-50PZ700U) Television
Hi, My Olympus SP570u. camera was working fine until few days ago. the knob on top with the Auto, movie, Guide etc options has no effect. Regardless of what it is turned to, the camera just takes a...
Sounds to me like a circuitry issue if the camera has not been dropped or been in prolonged contact with moisture. An authorized Olympus camera repair shop is the only option I can offer. You might try resetting it by removing the battery for thirty minutes. Then reinsert the battery and try again. If there is no change, head for the shop or contact Olympus directly through www.olympus.com/contact
Oct 30, 2010 | Olympus SP-570UZ Digital Camera
I have a Jacuzzi Z110 hot tub. the top control is broke (pn 51422). Can i use a digital top control PN 33334.
When dealing with a big manufacturer like Jaccuzzi, it is unwise to swap top side controls. They make theirs proprietary on purpose so that swapping is more difficult (especially jacuzzi).
If you use the wrong one, the buttons on the controls will be misleading (such as temp up button cycling jets, or the ozone button cycling the lights, etc)
I would use manufacturer part.
Oct 01, 2010 | Qca Spas Jewel Series Topaz Plus Hot Tub
How do i swap from eye view to screen for picture taking where is the button located to swap from one view to the other i dont have the manual cannon eos rebel xt
There is no such button. The Rebel XT operates as SLRs have operated for half a century: you compose through the viewfinder, the mirror flips up when you press the shutter button, etc.
You can download a manual from http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=ModelFeaturesTabAct&fcategoryid=215&modelid=11209#DownloadDetailAct
Dec 25, 2009 | Canon Rebel XT / EOS 350D Digital Camera
1994 chevy s10 .. moter swapped to carburated and
Actually, I recommend putting an after-market ratchet shifter on the transmission. This sounds weird, but we purposely cut the TPS out of my TH350 for street / strip racing. A ratchet B&M shifter or something similar will work, but it makes destination driving (I.E groceries, family, etc) a bit more of a pain.
Nov 06, 2009 | 1994 Chevrolet S-10
Also have a sunroof stuck open
while pushing auto button manipulate sunroof, lubricate and clean once closed
Sep 12, 2009 | 2003 Kia Sedona
'02 BMW 330 convertible top (fully automatic) stopped working while putting it down today. How do I repair it?
I would start by checking the pertaing fuses and relay. To check the relay swap one from another accessory that you don't imediately need.If you top operates then you just need to replace that relay. Keep in mind you have power centers under the hood, under the dash and sometimes under the rear seat.If the roof is stuck halfway and is dangerous to drive with there should be an emergency release located between the hydraulic pistons it is usually in the for of a T-handle.
Aug 16, 2009 | 2003 BMW 330
Set auto view text
push the messages button (the bottom left corner in landscape view) - this takes you to the menue
push the same button again - this enters settings
push down and ok - this goes to text message settings
push ok - selects auto text
push up, then ok - changes from "off" to "on" then selects
that should do it!
Apr 19, 2009 | Samsung SCH-u740 Cellular Phone
Kodak EASYSHARE M1063 Digital Camera Logo
Top Kodak Cameras Experts
Tony
Jerry Greenberg
Jerry Greenberg
Are you a Kodak Camera Expert? Answer questions, earn points and help others
