Question about Toshiba Office Equipment & Supplies
Toshiba e-Studio 2500C - C390Error
Getting C390 error. Always displays to call technical support. But works fine if I try switching on and off the machine for around 3 or 4 times. Can someone help me with this?
  • 653 Answers
SOURCE: C448 on Toshiba e-studio 2500c
C448 indicates Heater lamp lights continuously for a certain period of time when the pressure roller temperature during ready status is higher than the specified.
1. Clear status counter
Enter 08--> 400 --> change the value from "32" to "0", press Enter and restart MFP.
If occur again, u need to check followings:
1. Check the power supply and fuser unit
2. Check the LGC board
Posted on Mar 09, 2009
  • 653 Answers
SOURCE: Error code C380 paper feed failure
c380 indicates auto-toner error for black developer (K).
Check following:
Is the harness between the LGC board and the developer unit drawer connector open-circuited?
Is any harness inside the developer unit or the auto-toner sensor harness open-circuited?
Is the auto-toner sensor connector or the connector CN341 on the LGC board disconnected?
IF connector no problems, then u probably need to replace the auto toner sensor.
Posted on May 28, 2009
  • 653 Answers
SOURCE: toshiba 2500c Fax board
No need, just the fax board in order to do faxing. But if u have printer kit, u can do network fax.
Posted on Aug 25, 2009
tonesmaker
  • 60 Answers
SOURCE: Error code C970 on my
Check if the charger wire at the side door is broken or main charger grid is deformed.
& if any foreign matters are on the charger wire or main charger grid.
Posted on Jun 12, 2011
  • 81 Answers
SOURCE: Hi, I have a Toshiba
you seem to be having some issues ... ... ... the codes you are getting are related to the color calibration. possibly with the cyan developer unit or the high voltage board. to properly diagnose and fix the problem you will need a technican to fix the problem
Posted on Jul 28, 2011
I have toshiba e-studio 2500c error code E030. No paper jam.
Power-ON jam: The paper is remaining on the
paper transport path when power is turned ON.
Nov 27, 2016 | Toshiba E-studio 2500c Color...
How do I remove error code ce60?
Error ce60 e-Studio 2820c - Fixya
www.fixya.com/support/t17213833-error_ce60_e_studio_2820
Mar 19, 2013 - So I put in the code 8 clear/stop so it will show the error code. No error code is popping up. The number 8 just stays on the screen, like nothing ...
Jan 27, 2015 | Toshiba E Studio 2330c 2500c 2820c Copier...
Error code of C970 and call for service
Toshiba Copier Error code c 970 problem solution help: Toshiba E STUDIO 2330C, Toshiba E STUDIO 2500C, Toshiba E STUDIO 2820C, Toshiba E STUDIO 2830C, Toshiba E STUDIO 3500C, 3510C, Toshiba E STUDIO 4520C
PROBLEM:
1.The charger wire at the side door is broken. angry.gif:(" title="Angry">
2. The charge wire is vibrating. angry.gif:(" title="Angry">
3. Main charger grid could be deformed. angry.gif:(" title="Angry">
4. Broken T/S wire. angry.gif:(" title="Angry">
5. High voltage transformer abnormaility. angry.gif:(" title="Angry">
Solution:
4. Check if the spring of the high-voltage supply contact point is deformed. cheesy.gif
May 08, 2014 | Office Equipment & Supplies
Resetting the counter on a Toshiba e studio 2500c
I reached the total print counter 109219 and want to re set.
Oct 23, 2012 | Toshiba E-studio 2500 cbc939390, Copier,...
Hi, I have a Toshiba e-studio 2500c Color Copier. All of the sudden I've got a few errors. First a C390 then a CA00, but I was still able to make B&W copies, now I've got another error C970 and...
Jun 22, 2011 | Toshiba e-Studio 350 Copier
Error C467 toshiba 2500c
[C467] - Pressure roller thermistor abnormality after entering ready status (temperature abnormality at ready status).
Your copier is sensing an error in its fuser.
You can try going into (08) mode by holding 0 and 8 while turning on the copier. Once the copier starts up key in 400 and press start, input "0" and press enter. Try rebooting the copier, if this doesn't clear that call for service then you are going to need to get work done on your fuser.
Sep 10, 2010 | Toshiba E-Studio 161 Copier
Toshiba 2500c Fax board
Aug 25, 2009 | Toshiba E-Studio 3511 Color Copier
Feb 04, 2009 | Toshiba E-Studio 161 Copier
205 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
