Question about Sharp XE-A404 PC Desktop
Error 75 Path/File Access error - Sharp XE-A404 PC Desktop
You will have to run the program as the Administrator.
Either Right-Click and select "Run as Administrator", or
Right-click, Properties, Compatibility tab, Privilege Level box, check the "Run this program as Administrator" box. (In Windows 7, don't know if the same for Vista or XP.)
Posted on Mar 29, 2010
CANON IR2520 SHOWING ERROR CODE 804
In my experience the 804 error code relates to the location/availability of a file. If you are trying to print/access a particular file check the path and make sure you have permission to access it.
Dec 28, 2012 | Kodak ESP 3 Multifunction Printer/ Copier/...
Tip
All Problems have ONE solution and that is: www.longPathTool.com Path too long....
<p><b><u><span>Delete An "undeletable" File</SPAN></U></B><br> <p><b><span> </SPAN></B><br> <p><span>Open a Command Prompt window and leave it open.</SPAN><br> <p><span>Close all open programs.</SPAN><br> <p><span>Click Start, Run and enter TASKMGR.EXE</SPAN><br> <p><span>Go to the Processes tab and End Process on Explorer.exe.</SPAN><br> <p><span>Leave Task Manager open.</SPAN><br> <p><span>Go back to the Command Prompt window and change to the directory the AVI (or other undeletable file) is located in.</SPAN><br> <p><span>At the command prompt type DEL &lt;filename&gt; where &lt;filename&gt; is the file you wish to delete.</SPAN><br> <p><span>Go back to Task Manager, click File, New Task and enter EXPLORER.EXE to restart the GUI shell.</SPAN><br> <p><span>Close Task Manager.</SPAN><br> <p><span>Or you can try this</SPAN><br> <p><span>Open Notepad.exe</SPAN><br> <p><span>Click File&gt;Save As..&gt;</SPAN><br> <p><span>locate the folder where ur undeletable file is</SPAN><br> <p><span>Choose 'All files' from the file type box</SPAN><br> <p><span>click once on the file u wanna delete so its name appears in the 'filename' box</SPAN><br> <p><span>put a " at the start and end of the filename</SPAN><br> <p><span>(the filename should have the extension of the undeletable file so it will overwrite it)</SPAN><br> <p><span>click save,</SPAN><br> <p><span>It should ask u to overwrite the existing file, choose yes and u can delete it as normal</SPAN><br> <p><span>Here's a manual way of doing it. I'll take this off once you put into your first post zain.</SPAN><br> <p><span>1. Start</SPAN><br> <p><span>2. Run</SPAN><br> <p><span>3. Type: command</SPAN><br> <p><span>4. To move into a directory type: cd c:\*** (The stars stand for your folder)</SPAN><br> <p><span>5. If you cannot access the folder because it has spaces for example Program Files or Kazaa Lite folder you have to do the following. instead of typing in the full folder name only take the first 6 letters then put a ~ and then 1 without spaces. Example: cd c:\progra~1\kazaal~1</SPAN><br> <p><span>6. Once your in the folder the non-deletable file it in type in dir - a list will come up with everything inside.</SPAN><br> <p><SPAN style="FONT-FAMILY: 'Tahoma','sans-serif'; FONT-SIZE: 10pt
on Dec 25, 2010 | Computers & Internet
Run time error 75
error 75 is a path/file access error try running as admin...
Apr 15, 2011 | Sharp XE-A404 PC Desktop
Run-time error 75 path/file access error
please open your application through run as option
Oct 01, 2009 | Sharp XE-A404 PC Desktop
Run time error 75 path/file access error what
yours operating system files would be courpted so kindly format yours machine with windows xp service pack 2 and then watch the performance.
Jul 18, 2009 | Sharp XE-A404 PC Desktop
Windows cannot access the specified device, path, or file. You may not have the appropriate permission to access the item
It is simple ...... u got to be an administrator to install any software ..or you should be given Rights to Install any thing in the machine ...
Till then u will recive this msg on the screen
Apr 23, 2009 | Computers & Internet
Sharp XE-A41S - Customer Support Tool Run-time error '75':
you have to run the program as administrator. left click on program icon to bring up menu
Apr 07, 2009 | Sharp XE-A404 PC Desktop
Kip 3000 plotter
voltage error 031-034 on the kip 3000
Jul 05, 2008 | Office Equipment & Supplies
Sharp XE-A404 PC Desktop Logo
150 people viewed this question
Top Sharp Retail Supplies Experts
k24674
Electroboy
Electroboy
Are you a Sharp Retail Supply Expert? Answer questions, earn points and help others
