Question about Xerox WorkCentre M20 Black and White Copier
My document feeder will not pull the paper all the way in. It pulls it about 1/3 of the way and stops, then reads document jam.
    President:
  • 3,085 Answers
Open the doc feeder and clean the rollers with alcohol.
Posted on Oct 02, 2009
How to reset error 5100
Jams in the Document Tray
When a document jams or misfeeds in the Document Tray, <OPEN COVER> and <SEE FIG. 1> <!!CHECK!! 5100> are displayed on the LCD.
Note
You do not need to unplug the fax when clearing document jams.
* When <OPEN COVER> and <SEE FIG. 1> are displayed alternatively
1. Press [Stop].
Important
Do not pull out the jammed paper manually at this point.
2. Hold down [Start/Copy] for a few seconds.
* The document will be fed out automatically.
* If the document is not fed out, gently pull the document out of the fax.
* When <!!CHECK!! 5100> is displayed
1. Check if any paper is jammed.
If jammed, make sure to take out all the jammed paper.
2. After taking out jammed paper, turn the fax off, then turn it back on with [ON/OFF].
Jams in the Multi-Purpose Tray
If paper jams in the Multi-Purpose Tray, <CLEAR PAPER JAM> is displayed on the LCD.
1. Gently pull any jammed paper out of the fax as shown, then press [Stop].
* Pull it gently in either direction.
* If you cannot pull the paper out, continue with the steps below.
2. Open the Printer Cover.
3. Gently remove the jammed paper inside the fax.
4. Press [Stop].
The fax returns to standby mode.
Sep 24, 2013 | Canon FAX-JX200
Trying to fax, scan or copy and anytime I try the erro message Document in ADF press OK to discharge document
Hi sdrnjen977,
Here's what you can do to address the issue and clear error message: Document in ADF.
If you press the Stop button during scanning, Document in ADF. Redo operation after checking document in ADF and pressing OK. appears on the LCD. Press OK button so that the remaining document is automatically fed out.
Removing the jammed document from the Document Tray:
1. If printing is in progress, press the Stop button.
2. Turn off the machine.
3. If a multi-page document is loaded, remove any pages other than the jammed page from the ADF, then open the Document Feeder Cover.
4. Raise the Paper Release Lever, then remove the jammed page from under the roller to the Document Feeder Cver side.
5. Pull out the jammed document from the ADF.
6. Press down the Paper Release Lever, close the Document Feeder Cover, then turn on the machine.
Removing the jammed document from the inner side of the Document Cover:
3. If a multi-page document is loaded, remove any pages other than the jammed page from the ADF.
4. Open the Document Output Slot.
5.Open the Document Cover.
6. Insert your hand into the Document Output Slot, then while pushing up the paper output rollers inside the Document Output Slot with your fingers, pull out the document from the inner side of the Document Cover.
7.Close the Document Cover.
8. Close the Document Output Slot, then turn on the machine.
Hope this helps.
Thank you for using FixYa.
Jun 30, 2011 | Canon PIXMA MX860 OFFICE AIO-2.5IN LCD...
Cannot clear error message "Document
Hi nigel_lester,
This error message "Document in ADF" that you are getting means that you need to remove foreign object from the Automatic Document Feeder (ADF). Kindly follow the procedure below in clearing document jams:
Document jams in the ADF (Document Tray)
1. First, press Stop/Reset.
2. If a multi-page document is loaded, remove any documents other than the jammed page from the ADF. 3. Then, open the Feeder Cover.
4. From under the roller to the Feeder Cover side, remove the jammed page.
5. If a document is not jammed, check the document feed area if there's foreign material. If there's any, carefully remove it.
6. Close the Feeder Cover.
NOTE:
  • If documents remain in the ADF after pressing during scanning, [Document in ADF] will appear on the LCD. Press so that the remaining document is automatically fed out.
  • When rescanning the document after clearing the error, rescan it from the first page.
Document jams in the ADF (inner side)
1. Press Stop/Reset.
2. If a multi-page document is loaded, remove any documents other than the jammed page from the ADF, then open the Feeder Cover.
3. Raise the paper release lever (A) then remove the jammed page from under the roller to the Feeder Cover side.
4. Open the Document Cover and pull out the document from the inner side.
5. Close the Document Cover.
Note: When rescanning the document after clearing the error, rescan it from the first page.
Hope it helps.
Thank you for using Fixya.
Apr 02, 2011 | Canon Office Equipment & Supplies
The belt inside my scanjet 4200c has come off. How do I reattach it? I have opened the scanner. It looks to be relatively easy but I don't know how to attach the belt to the motor etc
Instructions
1 Lift the hatch on the feed tray and pull up the large green tab to the left of the roller. Remove any jammed or torn paper from under the roller and around the feed tray.
2 Pull the input feed tray out of the automatic document feeder. Grasp the feed tray with both hands and pull it straight out.
3 Check the interior of the automatic document feeder for jammed paper. Remove any jammed paper, then reinsert the feed tray into the automatic document feeder. Push down the feeder cover until you hear a click.
Mar 08, 2011 | HP Scanjet 4200c Flatbed Scanner
The paper keeps jamming, I cant see anything in the way. any help is appreciated.
If paper doesn't feed correctly when printing, remove it and fan the edges of the paper to separate the sheets. Reload the paper against the right side and slide the edge guide against it. Do not load too many sheets at once.
If paper has jammed: 1. Press x Start to eject the jammed paper. 2. If paper is still jammed, gently pull it out from the output tray or sheet feeder. If paper is stuck inside, press the P On button to turn off the printer. Then lift the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the printer back on.
If documents don't feed correctly in the Automatic Document Feeder, make sure the corners of the paper are not bent, folded, or curled up. Do not load more than 10 sheets of legal-size paper at a time. If documents have jammed: 1. Open the ADF cover and pull any paper out to the left. Caution: Do not try to remove the paper without opening the ADF cover first, or you could damage the mechanism. 2. Select Yes or press OK to clear any messages on the display screen. 3. Reload the paper.
Feb 28, 2011 | Epson WorkForce 600 All-In-One InkJet...
I have a Cannon Pixma MX320 all in one printer and I cant get it to stop saying document in ADF
Issue: ERROR LCD: DOCUMENT IN ADF
Solution: Remove foreign object from the Automatic Document Feeder (ADF) - MX310
Check the Automatic Document Feeder (ADF) for obstructions
Follow this procedure to check the ADF for obstructions. You do not need to turn off the power when clearing document jams.
  1. Press <Stop/Reset>.
  3. Remove the jammed page from under the roller to the Feeder Cover side.
  4. Pull out the jammed document from the ADF. If the document cannot be easily pulled out, proceed to section Document jams in the ADF (inner side).
  5. After removing the jammed document or if a document is not jammed, check the document feed area to make sure there is no foreign material. If you find foreign material, carefully remove it.
    Note : If documents remain in the ADF after pressing the Stop/Reset button during scanning, "DOCUMENT IN ADF" appears on the LCD. Press the OK button so that the remaining document is automatically fed out.
    Note: The document may not feed properly depending on the media type, or your environment, such as when the temperature and humidity are either too high or too low.
    In this case, reduce the number of document pages to approximately half of the loading capacity. Another alternative is to scan from the platen glass
  • If documents remain in the ADF after pressing <Stop/Reset> during scanning, [Document in ADF] will appear on the LCD. Press <OK> so that the remaining document is automatically fed out.
Document jams in the ADF (Document Output Slot)
If the document is jammed in the Document Output Slot, pull it out.
pulloutofslot.gif Note: When rescanning the document after clearing the error, rescan it from the first page.
Trust this is helpful. Please vote. :)
Dec 12, 2010 | Canon PIXMA MX310 All-In-One Printer
The printer is constantly sending a message- 'paper jam'
HP Officejet 7200, 7300, and 7400 Series - 'Paper Jam: Clear jam, and then press Enter' Message Displays on the Control Panel Display
Issue
During printing, the paper becomes stuck in the all-in-one and the error message 'Paper Jam: Clear jam, and then press Enter' displays on the control panel display.
Solution
Use the following instructions to clear a paper jam from the product:
Step one: Check for and remove any loose paper from the In tray
Do not try to remove jammed paper from the In tray. First remove any loose paper from the In tray to avoid worsening the jam.
CAUTION: Always try to remove jammed paper from the back of the printer first to avoid mechanical damage.
Step two: Clear the jam from the back of the printer
Follow these instructions to clear jammed paper from the back of the product. If the product is equipped with a two-sided printing accessory, skip to that section.
Remove the rear access door to clear the paper jam
1. Remove the rear access door by pressing the buttons on the side of the door and pulling it toward you.
Figure 1: Removing the rear access door
Rear access door
2. Gently pull the jammed paper out of the rollers.
WARNING: If the paper tears while removing it from the rollers, check the rollers and wheels for torn pieces of paper that might remain inside the product. If all the pieces of paper are not removed from the product, more paper jams might occur.
3. Replace the rear access door. Gently push the door into the all-in-one until it snaps firmly into place.
Remove the two-sided printing accessory to clear the paper jam
1. Remove the two-sided printing accessory by pressing in the buttons on the sides and then pulling the accessory toward you.
Figure 2: Removing the two-sided printing accessory
2. Gently remove any jammed paper.
WARNING: If the paper tears while removing it from the rollers, check the rollers and wheels for torn pieces of paper that might remain inside the accessory. If all the pieces of paper are not removed from the accessory, more paper jams might occur.
3. Press the button on top of the two-sided printing accessory to open the door.
Figure 3: Opening the two-sided printing accessory door
4. Gently pull the jammed paper out of the rollers.
5. Close the accessory door.
6. Reinstall the two-sided printing accessory.
Step three: Clear the jam from the automatic document feeder (ADF)
1. Remove the document feeder tray from the product by gently pulling it.
2. Lift the cover of the automatic document feeder by pulling it outward.
Figure 4: Lifting the cover of the automatic document feeder
Automatic document feeder (ADF) door
3. Gently pull the jammed paper out of the rollers.
WARNING: In the rare occurrence of a severe paper jam, you might need to remove the face plate from the front of the automatic document feeder and lift the pick assembly to remove torn pieces of paper from deep inside the automatic document feeder.
4. Close the cover of the automatic document feeder, and then reattach the document feeder tray.
Step four: Verify that the print carriage can move freely
Follow these steps to try to move the print carriage.
CAUTION: Do not force the print carriage to move if it is out of plain view or feels stuck. Forcing it may damage the printer.
1. With the product turned on, open the print cartridge access door. The print carriage might try to move into the access area. If so, allow it to move to that position.
2. Without turning off the product, unplug the power cord from the back of the product. Unplug the power cord from the power source. The power cord must be unplugged to allow the parts to be moved by hand and to reset the paper feed mechanism, without the risk of an electrical shock.
3. Looking in through either the print cartridge access door or the output paper tray, make sure the print cartridges are locked into the carriage and have not come loose. Also, make sure that there are no obstructions under or around the carriage to block it from moving.
4. Make sure the print carriage can move freely across the width of the product by gently pushing the carriage to the left and then to the right. Clear any obstructions found.
You may have to reach through the output paper tray to access the print carriage.
5. Close the print cartridge access door and plug the power cord back to the back of the product. Plug the power cord into the power source.
6. Press the On button to turn on the product.
Step five: Reload and test the printer
After you have removed the jammed paper, make sure the product is still functioning properly.
1. Reload the product with plain paper.
2. Peform a self-test by pressing and holding the RESUME button on the control panel until the product begins printing. A test page prints.
Step six: Service the printer
If you have completed all the steps listed above and are still experiencing a problem, service the product.
Dec 30, 2009 | HP DeskJet 3745 Printer
Document feeder
Most likely there is something in the path.
That feeder is easy to service. But first of all I would take a manila folder adn try and push it through the feeder paper path to clear it of any blockage.
Oct 01, 2009 | Xerox WorkCentre M20 Black and White...
Scanning / faxing problem
you will need to replace the adf assembly or the portion of adf roller which was dameged.
typically one should open th ecover and take out the jam inth direction of papermovement only
happy faxing
omnipresent
Oct 17, 2007 | Samsung SCX-4216F All-In-One Laser Printer
Xerox WorkCentre M20 Black and White Copier Logo
110 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
