Question about Garden
Robin engine for 27 ton log splitter..starting problems
Robin engine for 27 ton log splitter..starts on second/third pull..then stops in about 5/10 seconds pretty much everytime but,.once I got it going but soon as any pressure for the split was needed it would die off..been left outside but covered with tarp..drained some gas.changed spark plug..what's up?? it worked great just a couple months ago..will sometimes stay running at very low rpm if I try to increase speed..it stops..you have to wait a bit to make the next attempt possible or you'll be pullin on that thing all night without any success..
  • 65 Answers
Remove the float bowl from the carburator and clean it out. Either the float is stuck of the needle valve is gummed up. Both the float and needle valve together regulate the fuel allowed into the bowl, if they dont allow fuel in or allow it in fast enough, the engine dies. Also check for a fuel Screen in the fuel tank, it may be plugged up.
Posted on Oct 01, 2009
Timber tuff 5 ton eletric log splitter will not move
check/replace the start/run capacitor/s
check that the hydraulic pump is not seized
Oct 26, 2015 | Timber Tuff 5-Ton Electric Log Splitter
My log splitter wont stay running, gas getting to carb and thats as far as it goes. It does start ann runs till primer is empty. The splitter is 2 yrs old. Can you help please?
I suspect that the main jet in the carby is blocked
It could be that the needle in the carby is stuck closed
There could be water in the carby
I would pull the carby and have it overhauled / cleaned out
Oct 03, 2015 | Tools & Hardware - Others
20 ton mtd log splitter won't start, any suggestions?
Do a compression check. If there is no resistance when pulling engine over then you have major problems. ( new engine)
Aug 12, 2014 | Garden
Motor seems to be seized
ensure that the motor oil in it was not presivation oil. some machines have a thick oil put in it to stop the engine rusting if stored for a long time this needs to be replaced before starting the engine. if the engine oil is dark and very thick this may be the case and the engine will need to be stripped to dislodge the piston. but that usually happens in a longer time than 10 seconds.
if not then suspect the motor has had some major mechanical failure such as a crank shaft break. remove the injectors or plugs to see if the motor will crank round without compression.
Jan 01, 2010 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Swisher 22-Ton 7 HP Log Splitter #LS722
For all swisher log splitter problems go to swisherinc.com.
Dec 10, 2008 | Garden
Sanyo DS27880 27" TV, Dish signal lost after tv turned off, doesn't return
checks should on your tv tuner it could be bad.IF circuit should also be check and the video section call in the tech to make checks on your tv.and to do repairs on your tv.
Jan 19, 2007 | Sanyo DS27820 27" TV
Garden Logo
204 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
