Question about Vizio Televison & Video
47" LCD Vizio won't turn on. I have had this for less than 2 years. Worked fine the day before. My boyfriend tried to turn it on and play the Wii the next day and the Wii logo came up. Then he ejected the game that was in the Wii and there were blue, green, and red flashes darting across the screen. Now it won't power on at all. Orange VIZIO logo on bottom of TV frame comes on but dims after a second or two. We think it's the power supply, but not sure. VIZIO just tells me I should have gotten the extended warranty. I am being quoted almost $500 to have it fixed, but the part is only $81.00 online.
  • 92 Answers
SOURCE: vizio 47" lcd no picture no sound has power
this could be one of two problem. first, check if you have back light. If you do then the problem is with the M/B. Second, if you don't have back light then the inverter is bad and needs to be replace.
Posted on May 20, 2009
  • 2976 Answers
SOURCE: need to register vizio tv
Here's the link to register
http://www.vizio.com/support.aspx
Posted on Feb 06, 2009
SOURCE: no picture or sound, light comes on in the front and have to unplug tv to turn it off.
I had this exact problem on my Vizio 47" HDTV. I removed the speakers and all the screws on the back cover. Took the cover off and located the fuses on the largest circuit board. The are in the upper right hand corner of the board. There are 3 of them in a row labeled LF 1.5, LF 3.0 and LF 3.0. The are white in color with copper ends. I took a volt meter and measured continuity across all fuses individually and found the LF 1.5 to be blown. The guy at the electronics store sold me a barrel 1.5A fuse and told me to soldier it across the top of the blown fuse. It took an extra set of hands but the TV works perfectly.
Posted on Jun 23, 2009
djchillsnyc
  • 151 Answers
SOURCE: Power is there, but TV won't turn on
stored voltages are high no touching these circuts becuase they hold charges and alot of screws.
fualty capacitors you say after a while it stays on theres a full charge in the unit theres some type of discharging effect on the set after its off for a while. voltage goes to low or unstable after it is off for a while. your better off getting the service docs for this set if you want to diy..other wise get a tv tech to check it for you. hope this helps
Posted on Jun 25, 2009
SOURCE: Vizio SV470M, picture is moving too fast
This is often called the "Soap Opera" effect...I had a similar problem and found that changing the settings helped tremendously. Here are the settings I use:
Picture Mode: Movie
Backlight: 18
Brightness: 49
Contrast: 52
Color: 42
Tint: 2
Sharpness: 3
Advanced Video
Noise Reduction: strong
Color enhancement: off
Advanced Adaptive Luma: Off
Enhanced Contrast Rato: off
Color Temperature: Normal
Red: 121
Green: 128
Blue: 118
Smooth Motion Effect: low
Real Cinema Mode: Precision
Also, there's a great thread on the Soap Opera effect here:
http://www.hometheaterforum.com/forum/thread/291611/the-soap-opera-effect-on-modern-displays
Posted on Mar 18, 2010
When I turn on my 42" vizio all I get is the vizio screen no sound and the remote will not work to turn it off.after being unplugged for awhile (days) i tried it again and it worked fine until i shut
You will need to get a diagnosis done on the set. It could be a power supply issue or a main board issue. Your problem is between one of those two boards.
Apr 04, 2013 | Vizio VW42LF 42 in. LCD HDTV
Vizio sv41xvt flashing logo. won't power up
Sounds like either a power circuit board or mainboard failure. I'm going through same problems, mine is power board failure.
Jan 11, 2013 | Vizio SV471XVT 47 in. LCD TV
My vizio VO47 L has a black screen and sound. I do get a light on the vizio logo on the front. I see no illumination coming out of the back of the unit. what is wrong?
Power Supply popped a cap and fried the metal resistor bank. Replace the cap C241 and solderer the resistor bank. Worked for two months then pop out again. This time the resistor bank burnt through. Bought a new power supply DPS-38cp-1a from ShopJimmi.com $56.00 Replace supply which lasted 1 year 1 day and the same thing happen. Same components. Got this TV free but its costing me time and money now.
Oct 24, 2012 | Vizio VO47L 47 in. LCD TV
Vizio 47
It sounds that the main board has got faulty. Seek check support.
Jun 07, 2012 | Vizio E470VL 47 in. HD-Ready LCD TV
47" Vizio Flat screen HD LCD freezes up and remote will not work.
could it be Ch 9's digital signal is not broadcasting right? what is your refresh rate on your tv? 60 or 120hz? if its 120hz, then its more then likely the digital broadcast, if its 60hz I think its your tv can't keep up with their signal that may be at 120hz. Make since??
Jun 16, 2009 | Vizio VO47L 47 in. LCD TV
Keeps turning off
I am having the same problem, is there any solution for this problem?
Apr 11, 2008 | LG 47LC7DF 47 in. LCD HDTV
Vizio GV42L LCD TV screen black when turn TV on first time
If you are using a set top box this might be caused by turnig the box on at the same tie as you turn the tv on or slightly after you turn the tv on.  If you are using compnent or HDMI inputs the set needs to see the signal as it is turned on to know what formt the signal is in.
Oct 15, 2007 | Vizio P2 42 in. HD-Ready Plasma Television
Television will not turn on
My 47" Vizio wouldnt turn on this morning.....had a similair problem 3 yrs ago.....this is what i did and fixed the problem myself.....apparently you have to reset TV. Here is what has worked for me. So unplug tv power cord from the tv. Hold the power button and imput button together ( located on side panel ) for approx 45 sec......plug cord back into tv. Press power button on tv and voila !!!!! Tv came back on!!! I have had my Vizio almost 5 yrs. But have to call the unhelpful customer service atleast once a year.... I hope this works for you :)
May 03, 2007 | Vizio L32 32 in. LCD HDTV
Televison & Video Logo
249 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
