Question about Goldstar Refrigerators
Goldstar refrigerator 131ow
What is the small black button for on the tempature dial inside for? I notice it pushes in and out.
2 Suggested Answers
  • 1833 Answers
SOURCE: pushed black "clean" button; turned dial to"
Unplug power cord, or remove circuit breaker, then waitfor the oven to cool down, if it still does not open in one hour or so, thedoor must be taken apart from the hinges, and the door lock replaced. If thetimer is bad you will have to remove the door or replace the timer and then thedoor will open automatically. Most ranges today use 3different types of door locks...one is a solenoid controlled lock ( you hear aloud buzz noise when setting or unlocking the lock and has a arm that you mustmove to set the lock )...another is a heat sensitive lock ( has a arm that youmust move to lock and un-lock, makes no noises and has a spring that slowlymoves to lock the door will the oven is heating up )...Some locks are motorized( no handle to move, the motor locks the door by its self when you set therange for self clean )... If the motorized and heat sensitive locks fails toopen after the self clean cycle, you must access the lock and move it yourselfto open the door. On the free standing ranges, most times you must lift thecook top to access the lock mechanism. On built in ovens, the oven must bepulled out to remove the top access panel to get at the lock mechanism. Somebuild in ovens can have the control console removed to access the lock system.On the heat sensitive style of lock, there are no electrical parts to operatethe lock, usually you will need to replace the lock. On the motorized style oflock, you will have to use a ohm/volt meter to test why the motor will not work.On the solenoid style of lock, the solenoid is often mounted on the back of therange and can be accessed by removing the rear panel, some may be mounted atthe front, such as in a built in oven. The failure of the solenoid style oflock is normally caused by a bad lock solenoid. In order to get your door open,you must operate the door latch mechanism manually. Unplug or remove power fromthe range. Take the rear cover off the range. Locate the door latch assemblyand operate it manually and open your door. Then check continuity of thesolenoid. Some of the latch assemblies have micro switches to supply poweralso. You may need to check them. You should be able to get the door open anduse your range until you can get a tech to repair if you cannot repairyourself.
If you've interrupted the clean cycle or have accidentally set the clean cyclewith the oven door open, the latch may have engaged and now the door can't beclosed because it will hit the latch. There may be a door activated* switch onthe front face of the oven. In this case you may need to manually press thatdoor switch with your finger while at the same time canceling the clean cycleto get the latch to retract so the door can close fully again.
*On -some- Frigidaire built ranges, the switch is located behind the right handside panel and activated by the right hand door hinge. On this model, the sidepanel may need to be removed to access a malfunctioning door switch. Hope this will help you. GoodLuck.
Posted on Jul 14, 2011
Thr fridge side is not cold the freezer side works fine
that might just mean the tempature dial needs turned up 1 number say from 4 to 5 or 5 to 6 try it and check temp in refrigerator often if that doesn't help then you might need a refrigeration serviceman
Mar 13, 2015 | Refrigerators
Frezes everthing,too cold
then turn the dial for tempature to a smaller number
Mar 07, 2015 | Amana Refrigerators
My Fridge side is not getting that cold and the Freezer works fine, not sure what to do..
there is a tempature dial in the frige side turn it to a higher number then wait and see if it gets colder
Feb 13, 2015 | Samsung RS263TD Side by Side Refrigerator
How do i set the tempature lower on a GE model GSS5QGTA side by side. I see a panel on the outside, but i am not sure what to do
If up push the button it tells you the set temperature . Push it twice and it will go into the set mode and then use the warmer or colder buttons to change the temperature. Do the same for the refrigerator
Jan 11, 2015 | Refrigerators
Set the temperature on the fridge and freezer
they should be set about midway of ur dial not to max or full the higher settings are for extreme tempature enviromental conditions
Oct 11, 2014 | Samsung RB2155 Bottom Freezer Refrigerator
I have model fs-2919 would like to know what the other dials are for i dont have the booklet thanks for your help
The three small dials on this watch are all part of a "stopwatch" system. The small dial at the 12 o'clock is for tenths of a second( each half circle completed is one second or 1 whole rotation equals 2 seconds.) the small dial at the 6 o'clock counts a full 60 seconds for each revolution, and the dial at the 9 o'clock counts minutes(one full circle equaling an hour.) when the stop watch is started the 12 o'clock and 6 o'clock dials will start at the same time. you will notice that every half turn on the top dial equals one "tick" on the bottom dial. After the first minute of timing the top dial will stop ticking as it is for more precise timing of things that take less than 1 minute. each full rotation of the bottom dial will then equate to one "tick" of the 9 o'clock dial. hence the three dials counting tenths of a second, seconds and minutes. the setting of these dials is fairly easy once you understand the purpose. on the side of the watch there are two buttons(one top and one bottom) with a setting wheel in the center. When in use the top button starts and stops the stopwatch and the bottom button resets the counters. To set the watch simply pull the center wheel away from the watch all the way(2 clicks) set your minute hand and hour hand and then tap the bottom button repeatedly until the small dials all line up straight up. once that is done push the center wheel button halfway into the watch or one click to set the date. then simply push the wheel the rest of the way in and voila!!! hope this answers some questions
Apr 05, 2011 | Fossil FS2919 Wrist Watch
Frost Developing in Freezer. Refrigerator not
If freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
Aug 17, 2009 | Refrigerators
Dispenser not functioning & control panel inside turned off
you have a bad control board in the rear of the unit ...>>>>> To verify this check for 13.5 vdc on red and black going into the display board?? since your dispenser is not working the control board is most likely not working. puill the refrig from the wall and remove the cover plate it is square about 5"X6" you will see the control board thew part # for this is WR55x10552 if you need to replace it let me know
Apr 01, 2008 | GE PSS26SGR Stainless Steel Side by Side...
Tempature on fridge won't stay @ 38
might be freezing on the evaporator faulty defrost timer or drain is blocked water should run down back bottom tray
May 10, 2007 | Samsung RS2630SH Side by Side Refrigerator
Refrigerators Logo
66 people viewed this question
Top Goldstar Refrigerators Experts
AJMAL KHAN
Tom Chichester
Are you a Goldstar Refrigerator Expert? Answer questions, earn points and help others
