Question about Panasonic PT-D5600U DLP Projector
After a few min it shuts down just replaced lamp
  • 11,896 Answers
There may be an overheated or bad capacitor in the unit. You can test with an ohmmeter to determine if there is a bad one. Do check ballast that lamp connects to for power with voltmeter as well.
Posted on Oct 01, 2009
After watching short time minutes overheats, then shuts off. powering back on will play few more min, then again shuts down.
1.Internal power supply- Replace all Electrolyte Capacitors.
2. If it is an LCD with florecent lamps - they might be worneout.
Oct 16, 2015 | Televison & Video
Heater fan runs for a few min then shuts down
Check the afc Automatic fan control is shut off too soon .
Apr 29, 2017 | Vulcan Heating & Cooling
Tv shuts off, when turned back on, the green light keeps blinking and tv wont come back on. if you leave off for a few min. the tv will come back on. then the tv will shut off again after a few min.
One of two things...first hold power button while you hold the up button on your remote, this will reset your tv to manufacturer's settings....you could have sleep timer on.....if this does not work, you have to replace the lamp, my tv did the same thing and it happened to be the lamp. Hope this helps, good luck
Aug 05, 2012 | Sony Grand WEGA KDF55E2000 55" Projection...
My LG REAR PROJECTION DLP keeps on shutting off i change the lamp a year ago and dont know what the problem is
Check the Lamp Fan, if it is defective set will work for a few mins then shut down.Watch the Fan if it starts to run ,then stops when set is trying to come on with lamp then you need to replace the Fan.
Jun 09, 2011 | LG RU-60SZ30 60" Rear Projection...
It started 3 days ago the picture started getting darker and darker everyday then last night after turning the tv off which was off for several hours I turned it back on and a few min later there was a...
REPLACE THE LAMP IT IS LOCATED IN THE BACK OF THE TV THERE ARE INSTRUCTIONS IN THE OWNERS MANUAL FOR REPLACEMENT IT IS CONSIDERED CUSTOMER REPLACEABLE ITEM.
PART NUMBER 915B403001 Lamp (180W)
Dec 16, 2010 | Mitsubishi WD-65736 Television
Infocus LP 280 runs for 1 min then shuts down, runs again then
are the leds on the top lit or blinking? it could be the lamp, the ballast, or the fans. check the lamp. if there are black spots or bulges in the lamp, replace it. if not, make sure the fans are running. if they are, replace the ballast.
Jun 09, 2009 | InFocus LP 130 Multimedia Projector
Tv not working after lamp replacement
CK Fan if it is going bad set will shut down.
Feb 06, 2009 | Televison & Video
Rear Projection TV shuts down after a few minutes.
My science teacher had the same problem.
After, he replaced the lamp it stoped over heating.
witch is most likelywhy the tv is over heating
Jan 21, 2009 | Zenith D52WLCD 52" Rear Projection...
SAMSUNG TV MODEL HLR5067W
Sounds like the lamp to me. The projection lamps get hotter as they age and the TVs have a sensor to monitor the temp and shutdown the TV if it get too high
Projection TV makers charge an arm and a leg for their replacement lamps. They make it easy to do but as a result the custom lamp assy is expensive. The trick is to buy just the bulb for your model TV from any number of us aftermarket sources at a fraction of the lamp price and install it in the old lamp yourself. Really easy.
Jan 05, 2008 | Samsung HLR5067WX 50" Rear Projection HDTV
Panasonic PT-D5600U DLP Projector Logo
165 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
