Question about Ruud Heating & Cooling
HOW DO YOU ADJUST THE GAS VALVE? - Ruud Heating & Cooling
    President:
  • 2,976 Answers
The valve is either open or shut. To adjust the flame, you must open or shut the air ports until just the tip of the flame is white.
Posted on Oct 01, 2009
Where are the gas pressure tabs located in the honeywell vr 8304k 4822 gas valve ? This is the manufacturer's reference number. The pressure tabs are to read/adjust the gas inlet and outlet pressure
being gas and you are not a qualified gas fitter, the sensible thing to do is to get a gas fitter in to adjust /fix the unit
of course the unsafe thing to do is to try and do it yourself
Dec 30, 2016 | Honeywell Water Heaters
How to adjust pilot lite on a furnace
Select thermostat to off. Take front upper panel off of furnace. Looking at gas valve you should see a flat head or straight slot screw. This is the cap to access the adjustment. Look at the body of the gas valve real close. You may need to put on your glasses or use magnifying glass. It should say pilot in very small raised letters. Remove the cap. Look down into access hole and you will see the adjustment screw. It is a nylon screw so be careful not to strip it out. Place the correct screw driver, should be a small phillips or straight head. Turn gas valve to pilot and depress. Light pilot. While holding down, adjust nylon screw clockwise until flame envelopes 3/8 to 1/2 inch around thermocouple. Replace cap. Select heat and verify pilot stays lit. If the flame doesn't stay lit most likely your thermocouple is defective. You can purchase at your local hardware or Home Depot. Length doesn't matter.The thermocouple is heated and sends a DC signal back to the gas valve. There is another screw cap on the gas valve that adjusts gas pressure. Do not try to adjust the gas pressure to the gas valve because you need a special instrument (manometer) to adjust pressure. This device measures the water colume of the gas. A qualified technician would adjust this to 3.5" WC. for natural gas or 11" for propane.
Dec 09, 2013 | GPS
A.O. Smith promax electronic controller is not working
Question is not clear.
Do you want instructions to replace valve or want a service manual to test out the parts?
Open following link to help identify gas valve and download possible service manual that applies to that gas valve.
http://waterheatertimer.org/How-to-adjust-temperature-on-water-heater.html#intelli
It is usually recommended that a professionally trained person replace the gas valve.
If you have the intellivent gas valve, then it usually has identifying marks on side of valve, or call AO Smith with the model and serial number from label on side of tank.
Turn off gas and disconnect gas line from side of valve.
The manifold tube and wires are disconnected.
The gas valve unscrews counterclockwise.
If you want more details as the project requires, add a comment with specifics and that sends email that I will answer.
Oct 07, 2011 | Water Heaters
Re model737AN--the spark from igniter appears to be too far in advance[2 or so seconds] off gas valve.--- any way to adjust this?
spark should be ahead of gas valve sensor should pick up ignition sequence open gas valve and ignition accurs if gas comes on first combustion chamber fills with gas then ignition not a good look if you still have a house.
May 21, 2011 | Sunbeam Heating & Cooling
My White Rodgers Gas Valve 37C72U keeps going out. It burns well for ten to twenty minutes and then just shuts off. It lights first press but goes out again after the above time. All flames appear good....
have you replaced the thermocouple connected to the gas valve?if they get bad they will shut off gas flow,and no you cannot adjust the pilot flame size which is controlled by the valve also
Mar 27, 2011 | Water Heaters
I want to know how to adjust a gas valve on a gas furnace supply pressure is 11 inches of water column and manifold side is 2 inches of water column i want to adjust it to 3and a half inches of water...
There is small cap on top of valve that is slotted for screwdriver. Take off cap small spring underneath. Hook op manomiter to valve. Small allen screw on outlet off valve unscrew puy your manomiter fitting there. Turn on funace and turrn adjustment screw with small allen wrench or small screwdriver. Very easy ..Rus
Mar 20, 2010 | Heating & Cooling
Adjust pilot light
Adjust? What do you mean? The flame relationship to the T-couple? Or is the flame too low?
Low flame can be adjusted on some gas valves but mostly it requires special tools and knowledge of the gas valve. Most times it's a sign the GV is going.
Mar 01, 2009 | Water Heaters
Rheem gas valve for furnance
It is intentional. It's a slow close valve. There is no adjustment. You can usually replace it with an instant open/close valve.
Jan 18, 2009 | Heating & Cooling
Kenmore gas range
You need to turn the orifice on the safety valve down (clockwise) and this will make the flame smaller. The orifice is what the burner for the oven sits on at the bottom. The valve is # 214 on this diagram. http://www3.sears.com/imaging/ImagePageJava.shtml?productTypeID=0124111&brandID=0582&modelDesc=GAS%20RANGE&modelNumber=3627331890&documentID=10033508&documentTypeID=PLDM&documentClassCode=PM&titleType=BURNER%20SECTION&titleID=00001&. Hope this helps.
Nov 04, 2007 | Kitchen Ranges
Heating & Cooling Logo
63 people viewed this question
Top Ruud Heating & Cooling Experts
Donni Steen
Bill Long
Tim Whalen
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
