Question about Sport & Outdoor - Others
OIl in airintake line.
I Have a 09 rhino and got water in engine through air box. I changed oil 5 times oil is fine but my air intke line had some oil in it when i drained the lines. Why is it oil and not water? What should i do?
    Habit-Forming:
  • 55 Answers
Not a pro with rhinos but sounds like you got oil from crank case. like if you have a seal broken, hope not but my car had same problem and I had a cracked gasket. good luck. you can check the oil to see if it looks milky
Posted on Oct 01, 2009
2009 Yamaha yBR125 has oil in the air box
Hi, Rachel and the usual suspects are:
1. Oil tank/system overfilled.
2. Faulty breather valve.
3. Engine breather hose bent, pinched, kinked etc.
4. Air filter has too much "pre-oil".
5. Crankshaft seal failure allowing transmission fluid to migrate.
6. Blow by drain tube cracked/split or filled to capacity.
For more information about your question and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
https://www.singaporebikes.com/forums/showthread.php/315645-Engine-Oil-in-Air-Filter-box
oil in air box
Yamaha YBR 125 Service Manual
https://www.partsfish.com/page/oem-parts-for-yamaha
2009 Yamaha YBR125 Owner Manual
Mar 02, 2018 | 2009 Yamaha yBR125
The oil motor stop running
not a clear question but the pump or drive is broken or your filter is plugged
Jan 04, 2015 | Rhino-Rack Hyundai Entourage 07-09 SXB3
Blinking dash
I have a problem, my citroen Picasso 2002 diesel 2.0. The dashboard keeps flashing and it says overspeed inactive and I don't know how to fix it.
May 19, 2013 | Tusk Yamaha Rhino 700 Fi 4x4 Auto 08-09...
Does the 4x4 fully disengage on a 2008 Yamaha Rhino?
Have you tried putting it in reverse after dis engaging? Then forwards.
Apr 07, 2013 | Tusk Yamaha Rhino 700 Fi 4x4 Auto 08-09...
My Toyota With 1HZ motor has engine oil in coolant what is the cause?
possiable intke manifold crack or head gasket if car has been ran hot or water pump failer has happend that could have caused it
Sep 27, 2012 | 1994 Toyota Land Cruiser
I have oil blowing out my air cleaner on 09 FLHX 96 inch. I ride the bike hard - could it need different valves?
Hi Anonymous, oil leaking from your air cleaner is caused by oil carryover from the engine. For what ever reason the breather system is not seperating enough oil mist and air from the piston downstroke. There are cheap and quick easy fixes and there are more exspensive ones. Start by trying the following:
1. Run your oil level half way between the add and full mark when hot.
2. Run oil breather lines from head into a TEE fitting below carb/induction module then a single line into a mini filter under frame.
3. Purchase Arlen Ness Super Sucker.
4. Replace umbrella valves and realign oil pump
5. Upgrade oil pump and cam plate
Good luck
Sep 03, 2012 | Harley Davidson FLHX Street Glide...
Yamaha rhino 700 problem
ehhhh what kind of sound? consistent knocking sound (gets louder more frequent the faster engine revs) piston rod has come loose from crankshaft or you spun a bearing most likely from over revving engine in neutral, scrapping noise? clarify the sound
Jul 09, 2012 | Tusk Yamaha Rhino 700 Fi 4x4 Auto 08-09...
During an oil change at jiffy lube, the car drove in fine, but once the oil change was done the car wouldn't start. The engine would turn over and it looked like the engine was shaking around a lot. They...
Many times when oil appears in your air intake and in the air filter this is usually caused by a plugged pcv valve Positive crankcase ventilation valve it costs anywhere from 3-10 dollars.As far as it not starting my guess is they checked the air filter and left a vacuum hose or airbox open.Some of these vehicle will barely run if an air leak is present at the airbox containing the air filter.Would double check for any vacuum lines that may have been disconnected around the air box and that the box is shut and sealed properly.
Nov 29, 2010 | 1997 Subaru Legacy
Craftsman air compressor, oil build up in the air line
worn compressor rings, not a real issue, I assume it is more of a build up over time, say a gram of oil is blown into the lines every year, well one gram would not be noticed nor two but since it soes not evaporate it builds up to the point that you can see it, some oil is blown by brand new compressors and over time gets to be more and more, but as long as you are still getting full pressure you do not have to service the compressor, but since this is being used on water pipes I would install a trap inline to catch the oil
Oct 13, 2008 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Sport & Outdoor - Others Logo
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
