Question about Patton U2-1487 Floor / Box Fan
Are replacements for the plastic control knob available for Patton electric fans? (I need to use pliars to adjust the setting since the knob cracked)
    President:
  • 2,976 Answers
Knobs for almost anything electric or electronic are available at Allied Electronics. Here's the link.
http://www.alliedelec.com/
Posted on Oct 01, 2009
Can I buy a heating element for this heater?
On google
Patton replace heating element Heaters Questions ... - Fixya
www.fixya.com > Forum > Tags > replace heating element > Heaters
Patton heaters replace heating element related questions and answers. Ask yourPatton ... I can't seem to find a phone number for the manufacturer to call for parts. Any help? ... Question about PQH307UM Electric Utility Heater. 1 Answer ...
Patton PQH307UM Electric Utility Heater Quartz elements ...
www.fixya.com > ... > Patton > Patton PQH307UM Electric Utility Heater
Patton PQH307UM Electric Utility Heater, quartz elements replacement related ...Element. Where can I find replacement quartz tube heating. Element Infrared ...
Patton PQH307UM Electric Utility Heater Element ... - Fixya
Patton PQH307UM Electric Utility Heater, element related issues. Get free help, solutions & advice from top Patton experts. ... The heating element is above the thermostat, and all you will see is a round disc with two wires attaching to. Ad.
Patton PUH680-U Utility Heater Replacement fan motor ...
Jan 19, 2016 | Patton PQH307UM Electric Utility Heater
Are the thermostat knobs replacable?
Yes, they should have a set screw built in, or they will simply pull off without much effort. If the knob does not pull off without much resistance, then look around it for a hole with a allen screw inside. If this is the case, just loosen the screw and the knob will come off no problem.
Mar 03, 2011 | Patton Electric Patton PUH680-U Electric...
I have a u2-1887. the speed control knob has broken off. i need a new speed control switch and knob
SAME THING HAPPENED TO MINE...THE SWITCH BROKE APART IN PIECES...WHERE CAN YOU GET ANOTHER SWITCH?
Oct 12, 2010 | Patton U2-1887HO Floor / Box Fan
I have a patton puh682 1500 watt heater and after a while it just seems to turn off is there some kind of timer or heat control?
Under the main black knob is a bi-metal switch which shuts down the heat at various temps depending on your setting. Their is no timer.
Sep 21, 2010 | Patton Electric Patton PUH680-U Electric...
The knob on the heater control is loose and I can't adjust the temperature. Will replacing the knob work or do I have to bring the car to the service department for it to be fixed?
You can try a Salvage yard or just order the knob at a Dealer. I went through the same thing with my 1999. If you look behind the knob you will probably see a crack where the metal clip sits.
My Salvage yards do not want to sell the Knob separate from the whole control unit. Yours may. It will be available at a Dealer and with Patience you can replace it yourself. You will see an irregular clear plastic shape behind the knob and that is all that needs lining up.
Sep 21, 2010 | 2002 Ford Escape
Model PT 268 heater doesn't work at all but seems to have voltage
Yes it would seem that the thermostat or the knob would be the problem...when checking for voltage you need to check for 220v across the two terminals for the heating element. You will have 120 feeding back and forth all over the place but the fan and element will only work if they have 220... so you can have voltage and it still not work...
heatman101
Apr 23, 2010 | Patton Electric Patton PUH680-U Electric...
Need new motor for Patton High Velocity Air Circulator Model G-1272, 110 current. After about 27 years, the motor quit. This fan is a wall mount behind my wood/coal stove facing the stove pipe. It has 3...
Do you know where I can get a replacement knob that goes on the back for low, medium and high setting? It came off when I was moving and is difficult to turn without it (i use a screwdriver at the moment).
Jan 11, 2010 | Patton (HASF1016UC) Stand (Pedestal) Fan
Looking to replace Patton fan motor, model 1010mp, style TJ74SP
If you are up to disassembling your motor, you will find a thermal cutout near the windings which frequently fails open. Replacements are readily available, or just jumper it out. If the bearings are shot or the windings burned you're out of luck. Trust me, a new motor will cost more than a whole new fan.
Jan 01, 2009 | Patton (HASF1016UC) Stand (Pedestal) Fan
Fan switch
I would go to an ACE hardware or any other hardware store, bring in the old knob if you had it to find another that would match the shaft which it connects to, another place might be Radio Shack.
Jun 19, 2008 | Patton Electric U2-20 Box Fan
Patton U2-1487 Floor / Box Fan Logo
794 people viewed this question
Top Patton Dryers Experts
Tom Chichester
Are you a Patton Dryer Expert? Answer questions, earn points and help others
