Question about Coleman Powermate 60 Gallon Air Compressor
Need to know how the wires go on a kobalt 230 volt air copressor
The switch is broke off and need to know how the wires hook up to it
    Problem Solver:
  • 10 Answers
When looking at the switch it self, There will be 4 contacts. On the switch 2 will be labeled Line (Power in) and 2 will be labeled Motor (power out to motor) . Hook the black and white wires from the power cord to the line side (Either contact, it does not matter). Hook the 2 black and white wires from the motor to the contacts labeled Motor on the switch. The remaining 2 green wires (one from the motor and one from the cord) are to be grounded to the case on the switch.
Posted on Oct 31, 2009
I have a haldex 1hp 115/208-230 volt motor ac. i need to make sure i hook it up right for 230 power. the diagram just confuses me and im a mechanic. white wire, black wire, push button switch, and 7
the spade terminals in the wiring box are marked the chart tells where the color wire goes to what terminal for what voltage then l1 and l2 is the incoming power hookups
Sep 09, 2014 | Heating & Cooling
Wire 230 volt air compressor wiring diagrams
On 230 volts you have 3 wires 2 are 115 volt and the third wire is ground. As long as you hook the ground wires together correctly the other wires don't matter. Usually the ground wire is either white or green. The black wires are hot (115 volts).
Feb 11, 2014 | Air Tools & Compressors
Wiring a 230/115 1 hp 56y pool pump motor
please verify the name plate to be 115 230 volt motor.there will be a schematic that shows you exactly how to hook up this motor depending on the voltage being supplied to it. The main thing is switching between 115 and 230 volts this is a selector switch this very easily forgotten about. Please make sure to check that and double check that to make sure its on the proper selected switch. Good luck
A thumbs up would be greatly appreciated if this answer is helpful to your free Fixya question
Jun 30, 2012 | AO Smith 1 hp 3450rpm 56Y Frame 115230...
T-30 wiring changing from 460 volts to 230 volt 3 phase
There are several items that will need to be changed or replaced. First rewire motor. Remove weather head cover. On the motor will be a tag that shows how to wire for 460 volts and 230 volts.Check the tag and present wiring to make sure they match. Then look at the 230 wiring and change wiring per motor tag. Again check the motor tag to see max amps at 460 volts and 230 volts. 230 volts will be higher than 460 volts. Check the starter (if so equiped) to see how many amps its rated for. You will probably have to replace the starter. Make sure it has a 230 volt coil. Next size the overload heaters for your amperage. This conversion is not a simple task unless you're familiar with electrical . Good luck!!!
Next the starter coil will need to be replaced with a 230 volt coil
Nov 27, 2011 | Ingersoll Air Tools & Compressors
I NEED THE WIRING DIAGRAM TO HOOK-UP AN INGERSOLL-RAND TYPE 30, MODEL V 234 N4, SER. # 30T 37128 I UNDERSTAND THAT IT CAN BE WIRED FOR 110 VOLT OR 220 VOLT POWER.
The wiring diagram is on the outside of the
motor case, on most motors,on the label
Also on the inside of the wiring connection
cover
May 25, 2011 | Ingersoll Rand Type 30 Reciprocating Air...
Have tri zone 36k elect. 230/208 we only have 115/230 the connection says line ground natural thats 115, were do I hook the other 115 to get 230.
Hi, I am not quite sure of what kind of set-up you are saying you have when you say it says line ground natural? If you have a 115/230 volt power supply, this should be very easy to tie into. Look at the wiring diagram on the new unit real good and locate the 2- hot wires that should say line one or L-! and L-2. Your 230 volt wires will connect one to each side of those 2 connections, and will have a ground wire that grounds to a metal lug or screw on the unit. Look over the diagram for field wiring connections for high voltage and this will tell you where you need to hook your 230 volt wires and ground to. If this new unit is 208/230 volts, you should have connections like I have said either L-1 or t-1 and L-2 or T-2 that you will tie in your 230 volts to. Just look over the diagram and you will see where the beginning of the 2 hot wires come into the unit. There should be either 2 good sized black hot wires that are for your incoming hot wires to connect to, or they are already connected to the contactor, and you will need to connect yours to the line side of the contactor. I see what you are saying now, that they are only showing you 1- 115 volt connection to the new unit so you will have only 115 volts to run it. You want to know where the other 115 volt conductor hooks up for 230 volts. This is why you need to look at the schematic and wiring diagram that shows both of the 208/230 volt connections on this new unit so you can connect both hot wires to it. I can't pull up a picture of this on the Internet, but it will show you on the schematic on where they connect. This line ground neutral connection sounds as though its not for a hot wire, but for your ground, or if you happen to have a neutral wire that is being used for a ground. Please keep looking for the 2- line in connections as this is what you will need to find and where both 115 volt wires connect. They are your line voltage wires, so they need to connect to the load voltage hot wires at the L-1 and L-2 connections of this unit. This should be fairly laid out for you, but sounds like they have made it difficult? Look for what I have said and the schematic drawing and you will find the connections. Please don't forget to rate me as I know you will be kind. I will be checking back with you as I keep all of your information on file so I can look you back up if I need to. You can contact me by my user name below if you need me also. I wish you the best and follow my instructions and I know you will get it right.
Sincerely,
Shastalaker7
A/C, Heating, & Refrigeration Contractor
Sep 02, 2010 | LG Heating & Cooling
I'd like to know how to change a 115/230 volt pool pump motor to run on 115 volts after I've already change to internal possition to 115 volts
IF YOU SEE ON THE LABEL ON THE MOTOR HOW TO CHANGE FROM HI - LO VOLTS . THATS ALL YA GOT TO DO ..THE WIRES HOOK UP NORMALY
May 21, 2010 | Hayward 3/4hp Super Pump Inground Pool...
Compressor won't switch on, have tried reset switch and circuit breaker, but though the wall unit comes on the compressor wont..anything I can do? This has three phase power Mitsubishi..Mr Slim
If you have any experience in working with electrical systems, you can, but if not you should call a service technician.
First being very careful, check to make sure contactor is engaging.
Then check to see if you have the same voltage across all three wires on the compressor side of the contactor, assuming this is 230 volts, check T1 to T2 should have 230 volts, then check T2 to T3 should have 230 volts then check T1 to T3 should have 230 volts. If you have 230 volts to all 3 wires then the compressor is bad probably an open winding and needs replaced. Before replacing the compressor you need to check the resistance (with an ohmmeter) between all 3 terminals at the compressor. In order to do this you need to disconnect all power to the unit and ohm the compressor terminals from T1 to T2, T2 to T3 and T1 to T3 they should all have the same resistance if they do then the windings are good and the compressor is locked up, if one of the the windings is different then the windings are bad, either way the compressor needs replaced.
Nov 08, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
I need a wiring diagram for a kobalt 60 gallon air compressor
If it's a 220 volt motor, hook l1 and l2 (220 volts) to the line terminals. If it's a'dual voltage' motor (120 or 220)and you want to use 120, hook 120 to the terminals marked 'line'. Make sure the motor is connected for the voltage you're using if it's dual voltage.
Jul 21, 2009 | Air Tools & Compressors
I have 1 black, 1 white and 1 green ground on pressure switch. ?
Black & White would both be 115v on a single phase 230 circuit, green would be ground.
Jul 20, 2009 | Ingersoll Rand - Rand Type - 30...
Coleman Powermate 60 Gallon Air Compressor Logo
351 people viewed this question
Top Coleman Air Tools & Compressors Experts
John Trevino
elunsford
JOHN LAPIER
Are you a Coleman Air Tool and Compressor Expert? Answer questions, earn points and help others
