Carrier 58PAV070 doesn't make a sound or attempt to fire up at all on first use after summer.
  • 24 Answers
Thermostats call for the heater relay to engage, try jumpering the W and R terminal at the furnace with all other wires disconnnected from cuirciut board, if heat comes on your t-stat is bad.
Posted on Oct 01, 2009
Can I fix my Carrier Heat Recovery Ventilator HRV?
Check to see if the thermostat is set for blower .if thermostat is off unit would not do anything
Jun 01, 2017 | Carrier Heating & Cooling
Doesn't fire flash
Which flash, which camera, how are you attempting to fire the flash.
Feb 20, 2013 | Nikon Cameras
SOLEUS KFHHP-22 - Heater doesn't blow air at all, warm or cold. Cooling works great but no heat.
Doesn't matter how hot it was when installed, there still should have been proper start up performed. That means running unit thru all cycles and checking charge. If it was installed this summer then installer should warranty service to return and complete install properly.
Nov 15, 2012 | Soleus Air KFHHP-22 22000 BTU Mini Split...
S2046 low battery tried to start. Replaced battery now no sound, no start. Yes did hook up correct cables. Where can I find images of safety switches?
When trying to start with a low battery the engine Sometimes will stop on the top of the firing stroke putting it under extreme compression..almost like being stuck..you must turn tne engine backward a little just enough to get it off the compresdion stroke then try and start..This very same no click no nothing even when jump start happened to my cub cadet this summer after trying to start with a low battery...i used a pipe wrench and turned the dry shaft back and it started..then and all summer...give it a try good luck..
Nov 14, 2012 | Briggs & Stratton Starter Scott's Equip...
Carrier High Efficiency Weather Maker 38TZA024320 8 summers No Cold air controls are working the fan turns on when the compressor tries to start you here a short buzz repeats every couple seconds over the...
Hello
It would be worth a try to put a new start capacitor on.Also check the compressor contactor for burt or pitted contacts and replace if needed.
If this is a three phase unit be sure you dont a one blown fuse in the disconnect box.
Aug 03, 2011 | Carrier Heating & Cooling
Attempting to light valor homeflame fire the pilot jets ignite but when i attempt to put fire on to full flame, jets go out.
Sounds like it could be your thermo-couple.
or the microswitch you will find the number for valor here
Valor Gas Fires
Jan 14, 2011 | Valor Toys
Loud Noise from 76081 AC
The chances are you are damaging your A/C with each use that makes that loud sound. What kind of loud sound is it? Is it like a rattling sound? Here's a great, handy diagnostic article on that, specifying probable causes of it:
http://yourhandymanzone.com/Your_Handyman_Zone_How_To_Pages_Home_Improvement_Zone_Cooling_Ventilation_Systems_Central_Air_Conditioning_Making_Rattling_Sound.htm
You also might want to take advantage of the text-link that offers up to four (4) free A/C contractor estimates from those in your area--you can "pick their brains" as to what they think is specifically going on with your A/C and attempt to then use their information to fix the A/C on your own, or, altogether, and for the better, pick the best-priced estimate and have it resolved this hot summer season before more damage is done.
Brad
Jun 25, 2009 | Kenmore 76081 Wall/Window Air Conditioner
Blower has stopped working.
is the outside unit running and the light that is on is that normal as in has power or calling for a/c
May 03, 2009 | Heating & Cooling
Carrier Heater less than 5 years old--shutdown
sounds like the igniter is not glowing to start the flame let me know if this helps
Jan 11, 2009 | Carrier 38CKC036 Air Conditioner
Heating & Cooling Logo
136 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
