I have a 'vintage' (70's) Pioneer sx 535. What is the simplest way to hook up an FM antenna?
  • Ben Dobil Oct 02, 2009
    Do I need to 'ground' the FM antenna?...if so, why?and lastly...how do I do that?
    Thank you much.
    President:
  • 1,114 Answers
Depends on the connection on the back. Most older receivers used unbalanced 300ohm connections. In short, any speaker wire will do. Newer models used a "F" type connection (Coax end) which you can still cheat and get a 75 to 300 adapter at radio shack or any other local electronics store. Hope this helps.
Posted on Oct 01, 2009
Testimonial: "Informative. Thanks. "
No FM in vintage technics receiver
Connect a long wire/antenna wire to the respected fm antenna screw on the back of the receiver.
Mar 11, 2014 | Panasonic Vintage Technics Stereo Sa-500...
How to hook-up an AM antenna to pioneersx2300
go to the part store and get an antena it plugs into the system giving you am and fm frequencys
Jul 22, 2012 | Pioneer Sx-2300 Am/fm Stereo Receiver With...
I have a old pioneer stereo double cassette deck reciever model # RX-Z15, i dont understand the bal/unbal fm antenna hook ups cant get reception , need to know where to hook up the antenna or what kin
Buy a 300ohm FM Y antenna wire screw the spade ends into the balance hookup and fasten the Y section on your wall, "higher the better" this will improve reception. The antenna can be purchased at Radio Shack or Tv repair shop.
Apr 20, 2012 | Pioneer Audio Players & Recorders
Power switch on my Pioneer SX-950 receiver is hard to move.
Buy some electronic contact cleaner in a spray can, attach straw, "unplug receiver" and spray the power button, you may have to remove to be more effective.
Apr 15, 2012 | Pioneer Vintage Sx-980 Sx 980 Receiver
How do i hook up an antenna to the pioneer sx-950
There are two antenna sources on the Pioneer SX-950.
Both of these outputs are located on the rear panel of the receiver. The AM is a permanent mount. The FM is standard RF/Coax which will run to your antenna.
Antenna Inputs: FM 75 ohm, FM 300 ohm
Am Ferrite Bar Antenna
Hope this helps,
TechGuy21
A
s
Jul 04, 2011 | Audio Players & Recorders
Pioneer Avic D3 has poor fm reception when the car is on. It works fine when the car is off. Any ideas?
Your power antenna wire maybe hooked up to ignition. So when you turn off the car no more voltage is going to your antenna wire so your power antenna goes down causing a poor reception. You must hook up the blue wire on the radio harness to the power antenna wire.
Apr 10, 2010 | Pioneer AVIC-D3 Car DVD Player
Where can I buy a replacement FM antenna
Depending on where you live, Radio Shack or any local Audio Video store. Hope this helps
Jan 26, 2010 | Pioneer SX-315
My turntable works on old reciever and not new one
A traditional turntable only works on Phono (which contains special preamplification and equalization circuitry designed to raise the the level and flatten out the response of a phono cartridge).
After you do that, iIf you're not having hum problems I wouldn't worry about the ground. Or try it again on the FM Ground.
Feb 20, 2009 | Sherwood RX-4105 Receiver
I just bought an old vintage pioneer sx 737 receiver and cannot get NO fm reception, and only 2 or 3 on am....HELP!!!!! I have used antennas as well...Charlie
Even with just a short wire, this model should be receiving a number of stations. Is there an IC inside marked LA7001 or something similar? If so, it is probably defective. This is a common failure. I'll look up your specific model later to confirm.
Dan
Jun 01, 2008 | Pioneer Audio Players & Recorders
643 people viewed this question
 Grubhead
Grubhead
